Shelly Binding
Ok, thanks for testing this out :slight_smile:
Thanks for your answer, I have removed everything again also the binding and installed again. But unfortunately I can’t get any further than the “CONFIGURATION_PENDING”.
2022-08-02 17:37:07.167 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'shelly:shellyplusht:441793d0e730' to inbox.
2022-08-02 17:37:07.167 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery result with UID 'shelly:shellyplusht:441793d0e730' was added.
2022-08-02 17:38:02.118 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery result with UID 'shelly:shellyplusht:441793d0e730' was removed.
2022-08-02 17:38:25.808 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusht:441793d0e730' changed from UNINITIALIZED (DISABLED) to INITIALIZING.
2022-08-02 17:38:27.822 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusht:441793d0e730' changed from INITIALIZING to UNKNOWN (CONFIGURATION_PENDING): Initialization or device in sleep mode.
Exception:java.lang.NullPointerException
Check openHAB.log for details.
2022-08-02 17:58:05.534 [WARN ] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplusht-441793d0dbc0: Device requires restart to activate changes
2022-08-02 17:58:08.630 [WARN ] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplusht-441793d0dbc0: Device requires restart to activate changes
2022-08-02 17:58:08.673 [INFO ] [y.internal.handler.ShellyBaseHandler] - shellyplusht-441793d0dbc0: INFO: Neue Firmware verfĂŒgbar: aktuelle Version: v0.11.0, neue Version: vplushtprod1
2022-08-02 17:58:08.715 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusht:441793d0dbc0' changed from UNKNOWN (CONFIGURATION_PENDING): Initialisierung oder GerÀt im Schlafmodus. to ONLINE
2022-08-02 17:58:08.826 [WARN ] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplusht-441793d0dbc0: Device requires restart to activate changes
2022-08-02 17:59:18.541 [WARN ] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplusht-441793d0e730: Device requires restart to activate changes
2022-08-02 17:59:21.674 [WARN ] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplusht-441793d0e730: Device requires restart to activate changes
2022-08-02 17:59:21.749 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyplusht:441793d0e730' changed from UNKNOWN (CONFIGURATION_PENDING): Initialisierung oder GerÀt im Schlafmodus. to ONLINE
2022-08-02 17:59:21.896 [WARN ] [g.shelly.internal.api2.Shelly2ApiRpc] - shellyplusht-441793d0e730: Device requires restart to activate changes
what can i do?
send a proper extract if the log, esp. the lines following the exception
This line shows a status change from CONFIG PENDING to ONLINE
that was all that was in the log with the devices (I have 2). The funny thing is I have updated the firmware to the latest beta and since then the devices are switched to online.
The funny thing is it seems to go now only goes the shelly manager no longer, there comes appears The error message:
but in the log is nothing, I can attach you gladly with logs.
openhab.log (240.9 KB)
events..log (563.6 KB)
This is not funny. The firmware for PlusHT still has issues and the binding requires at least 0.11. They still have a bug, which causes the device to switch to setup mode and using the new communication channel.
The Exception is not related to the Shelly binding. Shelly Manager for Gen2 is not completed it might have issues.
fyi: currently the gen2 build is broken. I’m working with Igor on improved TRV support and better Plus/Pro device handling. I let you know when the next stable build is available
In don’t know if is a bug or a feature request.
I have a Shelly 1 Plus PM.
If i remove power to the shelly the binding still report the power consumptio that was in use when the shelly was powered.
This make sense if the shelly loose connection for some time.
But if the shelly is not powered is better to change it to 0watt.
Maybe an option to choose how should be reported?
how to differ between „Shelly is disconnected for a while“ and Shelly has no power?
You could verify the thing status to see if it‘s ONLINE
I updated the Gen2 build
  • fixes the issue that meters are not created when using the Pro 4PM with auth enabled @waitz_sebastian
  • optimized WebSocket connections (doesn’t create WS on initialization, but on demand when needed)
  • filter for unexpected Notifications
  • Notifications will not be requested on device discovery
  • Shelly Pro 3 is already supported
For TRV we have a breaking change:
  • Channel device#schedule has been moved to control#schedule (enable/disable scheduled profiles)
  • Channel control#selectzedProfile now has the selected profile id as raw information. The binding dynamically retries the profile list and provides a list to the UI (e.g. profile “1” will be mapped to Bathroom"
3.4.0-Gen2 build for Plus/Pro+Gen1 | 3.4.0-DEV Gen1 stable build
README | READMEbeta for more info on first installation
Avdanced Users - Shelly Manager - Bugs/Features - API Doc
Gen1: Firmware Index - Firmware Archive
fyi:
Today Allterco released Gen2 0.11.0-beta3 (beta) which contains (official change log), esp. the fixes for Plus HT are important. Keep in mind, it’s a beta
  • MQTT: Retain LWT messages
  • Scripts: fix crash on MQTT unsubscribe when MQTT is disabled
  • Incorrect ACL when authenticaion is disabled
  • Erroneous overpower events on Plus1PM and PlugUS devices
More detailed/extended change log:
Platform:
  • Fix incorrect ACL when authenticaion is disabled
  • Range extender: proper status updates for ap_client_count
  • Range extender: fix logic when AP is disabled
  • Outbound websocket: fix device crash due to disconnect on reboot
  • Retain MQTT LWT
Plus1PM, PlugUS:
  • Plus1PM, PlugUS: fix erroneous overvoltage and overpower events
PlusHT:
  • PlusHT: improve webhook invocation reliability
  • PlusHT: fix unreasoned transition to SET mode
  • PlusHT: fix duplicated status notifications
  • PlusHT: fix display RSSI indication when there is no STA connection
  • PlusHT: fix humidity reports for prod. batch 2220-Broadwell
  • PlusHT: fix OTA trigger from cloud
Scripts:
I just upgraded from 3.3.0 to 3.4.0-M1
My Shelly UNI device which has been working fine till the upgrade would not come online
UID: shelly:shellyuni:98cdac2c6bf2
label: Shelly UNI (shellyuni-98cdac2c6bf2@10.163.199.230)
thingTypeUID: shelly:shellyuni
configuration:
  eventsCoIoT: true
  deviceIp: 10.163.199.230
  eventsSwitch: false
  updateInterval: 60
  eventsButton: false
  eventsPush: false
Tried:
Manual disable and re-enable
Delete and recreate
Delete and rediscover via scan
None of which worked.
Rebooted the UNI, reste the coloT etc. All not helped.
Device stays UNINITIALIZED
15:09:55.512 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyuni:98cdac2c6bf2' changed from INITIALIZING to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
15:10:09.263 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyuni:98cdac2c6bf2' changed from UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode. to UNINITIALIZED
15:10:09.281 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyuni:98cdac2c6bf2' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
15:10:14.424 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyuni:98cdac2c6bf2' changed from UNINITIALIZED (DISABLED) to INITIALIZING
Any suggestions? I have cut back to 3.3.0 and UNI is back online.
Mark
  • PlusHT is now working with firmware 0.11-beta3 (could be installed from UI, previous versions are not supported)
  • Shelly i4DC is already supported (same as Pro 3), both coming the next weeks
  • Gen2: Improvements for WebSocket handling
  • Gen2: irregular RESTARTED alarms are fixed
  • Gen2: NPE on rollerPos udpates fixed
  • Gen2: Model IDs for hardware generation 2 (which brings VDE certification) added
@Sni Please verify the latest Gen2 build with 0.11beta3, this should turn your PlusHT in a working setup
@Zylle I need the DEBUG log. please try the current gen 2 build (check how to install)
@waitz_sebastian Did you verified the Pro 4PM with auth enabled working?
@DaveL Status based on the latest build?
@Thinqer Please try the latest gen2 build with the TRV (new profile handling)
Note: The DEV build is always newer than the version in the official Distro or the Milestone builds check [here]
In response to:
The debug logs looks as follows (when I disabled and re-enabled the UNI):
2022-08-13 17:48:21.475 [DEBUG] [enhab.binding.shelly.internal.ShellyHandlerFactory] - Shelly UNI (shellyuni-98cdac2c6bf2@10.163.199.230): Create new thing of type shelly:shellyuni using ShellyRelayHandler
2022-08-13 17:48:21.490 [DEBUG] [enhab.binding.shelly.internal.ShellyHandlerFactory] - Thing handler for uid shelly:shellyuni:98cdac2c6bf2 added, total things = 4
2022-08-13 17:48:23.504 [DEBUG] [.binding.shelly.internal.handler.ShellyBaseHandler] - shellyuni-98cdac2c6bf2: Device config: IP address=10.163.199.230, HTTP user/password=admin/***, update interval=60
2022-08-13 17:48:23.504 [DEBUG] [.binding.shelly.internal.handler.ShellyBaseHandler] - shellyuni-98cdac2c6bf2: Configured Events: Button: false, Switch (on/off): false, Push: false, Roller: true, Sensor: true, CoIoT: true, Enable AutoCoIoT: true
2022-08-13 17:48:23.504 [DEBUG] [.binding.shelly.internal.handler.ShellyBaseHandler] - shellyuni-98cdac2c6bf2: Start initializing thing Shelly UNI (shellyuni-98cdac2c6bf2@10.163.199.230), type shellyuni, ip address 10.163.199.230, CoIoT: true
2022-08-13 17:48:23.652 [DEBUG] [.binding.shelly.internal.handler.ShellyBaseHandler] - shellyuni-98cdac2c6bf2: Unable to initialize: Device unreachable or API Timeout (), retrying later
2022-08-13 17:48:23.652 [DEBUG] [.binding.shelly.internal.handler.ShellyBaseHandler] - shellyuni-98cdac2c6bf2: Update status job started, interval=20*3=60sec.
Seems to inicate and access issue
 But it works with 3.3.0 and I can access the device from the openHAB server:
I also tried the GEN2 build but got lots more errors.
@Mark_VG I updated the gen2 build, UNI is working again (JSON format changed)
Thanks Marcus.
All my devices are back online with the latest build I found in your repo.
On each openHAB restart I however now get the following:
javax.servlet.ServletException: servlet already registered with a different alias
        at org.ops4j.pax.web.service.spi.model.ServerModel.addServletModel(ServerModel.java:119) ~[?:?]
        at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:246) ~[?:?]
        at org.ops4j.pax.web.service.internal.HttpServiceStarted.registerServlet(HttpServiceStarted.java:395) ~[?:?]
        at org.ops4j.pax.web.service.internal.HttpServiceProxy.registerServlet(HttpServiceProxy.java:504) ~[?:?]
        at org.ops4j.pax.web.extender.whiteboard.internal.element.ServletWebElement.register(ServletWebElement.java:102) ~[bundleFile:?]
        at org.ops4j.pax.web.extender.whiteboard.internal.WebApplication.registerWebElement(WebApplication.java:392) [bundleFile:?]
        at org.ops4j.pax.web.extender.whiteboard.internal.WebApplication.addWebElement(WebApplication.java:188) [bundleFile:?]
        at org.ops4j.pax.web.extender.whiteboard.internal.tracker.AbstractTracker.addingService(AbstractTracker.java:191) [bundleFile:?]
        at org.ops4j.pax.web.extender.whiteboard.internal.tracker.AbstractTracker.addingService(AbstractTracker.java:44) [bundleFile:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:943) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:871) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:903) [osgi.core-7.0.0.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:956) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:495) [org.eclipse.osgi-3.17.200.jar:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1271) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1222) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) [bundleFile:?]
        at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
        at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
        at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
        at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
        at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
        at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
        at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
        at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
        at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:944) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.17.200.jar:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.17.200.jar:?]
Any idea what the cause/solution would be?
275 | Active |  80 | 2.0.0                  | Californium (Cf) Element Connector
276 | Active |  80 | 2.0.0                  | Californium (Cf) Core
277 | Active |  80 | 3.4.0.202208132110     | openHAB Add-ons :: Bundles :: Shelly Binding
In case I have attached a debug log?
shelly.log (708.4 KB)
Mark
this was fixed yesterday evening, please update
Hi Markus
Thanks, updated the the latest download:
278 | Active |  80 | 3.4.0.202208141105     | openHAB Add-ons :: Bundles :: Shelly Binding
Still get the same:
14:32:57.885 [ERROR] [er.whiteboard.internal.WebApplication] - Registration skipped for [ServletWebElement{mapping=DefaultServletMapping{httpContextId=null,urlPatterns=[/shelly/event, /shelly/wsevent],initParams={},servlet=org.openhab.binding.shelly.internal.api.ShellyEventServlet@62ed1978, alias=null, servletNamenull}}] due to error during registration
        at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) [org.eclipse.osgi-3.17.200.jar:?]
        at org.apache.karaf.bundle.command.Start.executeOnBundle(Start.java:38) [bundleFile:?]
        at org.apache.karaf.bundle.command.BundlesCommand.doExecute(BundlesCommand.java:65) [bundleFile:?]
        at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:55) [bundleFile:?]
        at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) [bundleFile:4.3.7]
        at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) [bundleFile:4.3.7]
        at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) [bundleFile:4.3.7]
        at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) [bundleFile:4.3.7]
        at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) [bundleFile:4.3.7]
        at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) [bundleFile:4.3.7]
        at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) [bundleFile:4.3.7]
        at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) [bundleFile:4.3.7]
        at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) [bundleFile:4.3.7]
sorry, update again
I lost changes from yesterday evening and need to do it again
Thank you. Seems fixed is:
279 | Active |  80 | 3.4.0.202208141309     | openHAB Add-ons :: Bundles :: Shelly Binding
Much appreciated
Hi there,
as @markus7017 proposed, im posting my problem here.
Im running openHAB openHAB 3.3.0 Release Build on TrueNAS-SCALE-22.02.4-MASTER-20220805-041141 from within TrueCharts Docker-Compose app.
I only own 2 times the new Shelly H&T Plus and installed the following software on it:
  1. Shelly = 0.11.0-beta3
  2. Shelly = plushtprod1.2
I installed the openHAB Shelly-Binding version 3.3.0
I used the Shelly app to initiate the Shelly devices, connected them to my network and i am able to reach both devices via the WebUI via entering their IP adress.
Bluetooth and Cloud is deactivated.
I did not set a password / activated the “Auth” option.
When i try to discover these devices via Shelly-Binding, i can not find them
Procedure:
  • Long-Press button of the shelly devices
  • Shelly devices reboot and show “Set”
  • Web UI is permanently reachable
  • In openHAB i go to Things > Add > Shelly > “Scan”-Button
Nothing gets discovered.
I am absolutely new to this Shelly-thing so maybe im doing something wrong
Additionally to that, it seems that if i have the Cloud-Option disabled, after around 1 Day i can also not discover the devices via app anymore
I have to use the WebUI to activate Cloud again and then the app recognizes the values/devices again.+
Regarding Debug-Logs:
  • I do not have a Script-Button on the WebUI
  • I activated Debugging on Web-Socket
  • The only thing i can see in frontail is 2022-08-15 10:53:09.208 [INFO ] [shelly.internal.ShellyHandlerFactory] - Shelly Manager started at http(s)://192.168.48.1:8,080/shelly/manager"
Sorry i have no idea or did find a documentation how to provide/activate further logging options
Could you please give me a quick hint where to look at?
Thank you very much for taking the time for this
