Hi. Since I upgraded to 3.4.0.M3 the communication with Shelly1 seems one way OH-> Shelly. For example, if I program locally the device in auto off, OH items does not update the status, it stays on.
Hi Markus,
there is internalTemp
channel missing for dimmers.
Not important or urgent - just like to let you know.
Hi Markus,
I reported a issue with battery powered Shelly devices after a OH3 (current used versie 3.4.0.M1) restart. There was a link to this page so let me explain again.
My issue is that the button2 and dw2 are not working after a restart. Both devices stay in pending config mode. The only way to get for instance button2 working is attaching a external USB power supply and disable/enable the binding.
Any idea how to solve this? / troubleshoot this?
Or is for this no solution?
All other Shelly devices work perfect after a OH restart.
Isnât this intended for battery operated shelly devices?
It is the same for my buttons, ht and flood sensor.
They all stay in config pending until the first wakeup.
Yes that is the case but normal events are received and after a restart I donâsee any events.
Ive got two Shelly Plus H&T
Not all devices provide internal temp. Usually the binding detects availability of optional properties dynamically. Some of the devices have inconsistent APi structures and need special handling
I need to check why this is not detected
Which firmware are you using?
Check with Shelly Manager if the counter for protocol messages is increasing. If bot post a DEBUG log of the initialization to see if the binding is receiving CoAP events
urg, thatâs an exception in the Californium framework I use to handle CoAP. M3 brings a new version (2.7.3 vs. 2.0) of the jar, which was changed.
Iâm traveling this week and try to find some time at the weekend
Okay thank you very much!
The protocol counter is always zero
Hi all, for some reason there is no registration anymore for triggering SHORT_PRESSED, so my rules arent working anymore.
Did i miss something after an update?
tried to apply eventsPush=true to the thing file, but that didnât change anything.
Have you changed anything? WiFi, FirmwareâŠ
Maybe a reboot of the Shelly will helpâŠ
Greets
The shellyâs got updated a while back, didnt noticed that it didnt work anymore just recent.
Wifi didnt change, and i reboot the shelly a couple of times now, just checked some other 1L that i have same thing, then i tried a 1pm and 2.5, didnât register it either.
Saw some posts that used eventcount or lastevent, but thats too slow.
In your Event.log nothing?
[openhab.event.ChannelTriggeredEvent ] - shelly:shellyix3:68c63afa98b2:status1#button triggered SHORT_PRESSED
Which openhab version are you using?
correct and dimmer does (and already did in the past).
Using FW version 1.8 and 1.12
I did some research on missing internal temperature channel.
Devices with available internal temperature have the following attributes:
"temperature": 37.04,
"overtemperature": false,
"tmp": {
"tC": 37.04,
"tF": 98.67,
"is_valid": true
whereas dimmers have the following:
"tmp": {
"tC": 37.04,
"tF": 98.67,
"is_valid": true
Donât know if it is a bug or by intention that the attribute temperature
is missing. However, all devices seem to have tmp.tC
Both devices report the following CoIoT device description (/cit/d):
{"I":3104,"T":"T","D":"deviceTemp","U":"C","R":["-40/300","999"],"L":4}
Hello!
Might be a dumb question, but:
Can I stop Shelly Plugs (S in my case) from reporting Power every 5 seconds (or somehow set the threshold on when they will report?)
They are really spamming my OpenHAB Logs
Bye, Fridolin.
No, you canât. Any change of status is logged.
Greetings
Thank you!
Bye, Frido.
