Log
2023-03-06 21:55:27.816 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly device discovered: IP-Adress=192.168.101.194, type=shellybutton1
2023-03-06 21:55:27.823 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=34358): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,165],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 21:55:27.824 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 21:55:27.824 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,165],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 21:55:27.934 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Using CoAP device description from successful HTTP /cit/d
2023-03-06 21:55:27.934 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Device Description for shellybutton1-3c6105f44d2d: {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 21:55:27.935 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=1: sensor_0
2023-03-06 21:55:27.936 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=2: device
2023-03-06 21:55:27.936 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Adding 7 sensor definitions
2023-03-06 21:55:27.936 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9103: cfgChanged, Type=EVC, Range=U16, Links=2
2023-03-06 21:55:27.937 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2102: inputEvent, Type=EV, Range=S/L/SS/SSS;, Links=1
2023-03-06 21:55:27.937 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2103: inputEventCnt, Type=EVC, Range=U16, Links=1
2023-03-06 21:55:27.938 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3115: sensorError, Type=S, Range=0/1, Links=1
2023-03-06 21:55:27.938 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3112: charger, Type=S, Range=0/1;-1, Links=2
2023-03-06 21:55:27.938 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3111: battery, Type=B, Range=0/100;-1, Links=2
2023-03-06 21:55:27.939 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9102: wakeupEvent, Type=EV, Range=battery/button/periodic/poweron/sensor/ext_power;unknown, Links=2
2023-03-06 21:55:27.939 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Device description for SHBTN-2#3C6105F44D2D#2 restored: {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 21:55:27.939 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Device Description for SHBTN-2#3C6105F44D2D#2: {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 21:55:27.940 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=1: sensor_0
2023-03-06 21:55:27.940 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=2: device
2023-03-06 21:55:27.940 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Adding 7 sensor definitions
2023-03-06 21:55:27.940 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9103: cfgChanged, Type=EVC, Range=U16, Links=2
2023-03-06 21:55:27.941 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2102: inputEvent, Type=EV, Range=S/L/SS/SSS;, Links=1
2023-03-06 21:55:27.941 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2103: inputEventCnt, Type=EVC, Range=U16, Links=1
2023-03-06 21:55:27.941 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3115: sensorError, Type=S, Range=0/1, Links=1
2023-03-06 21:55:27.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3112: charger, Type=S, Range=0/1;-1, Links=2
2023-03-06 21:55:27.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3111: battery, Type=B, Range=0/100;-1, Links=2
2023-03-06 21:55:27.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9102: wakeupEvent, Type=EV, Range=battery/button/periodic/poweron/sensor/ext_power;unknown, Links=2
2023-03-06 21:55:27.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 21:55:27.943 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 21:55:27.943 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
2023-03-06 21:55:27.943 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 5 channels updated from CoIoT status, serial=256
2023-03-06 21:55:27.984 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly settings : {"device":{"type":"SHBTN-2","mac":"3C6105F44D2D","hostname":"shellybutton1-3C6105F44D2D","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellybutton1-3C6105F44D2D","key":""},"wifi_sta":{"enabled":true,"ssid":"Link","ipv4_method":"static","ip":"192.168.101.194","gw":"192.168.101.22","mask":"255.255.255.0","dns":"192.168.101.22"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellybutton1-3C6105F44D2D","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":false},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"multimedia-button.wohnzimmer.i","fw":"20221027-094830/v1.12.1-ga9117d3","discoverable":true,"build_info":{"build_id":"20221027-094830/v1.12.1-ga9117d3","build_timestamp":"2022-10-27T09:48:30Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":null,"lat":500.000000,"lng":500.000000,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-10","batch_id":1},"sleep_mode":{"period":12,"unit":"h"},"led_status_disable":false,"longpush_duration_ms":{"max":800},"multipush_time_between_pushes_ms":{"max":500},"remain_awake":0,"inputs":[{"name":null}]}
2023-03-06 21:55:27.985 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Adding Shelly multimedia-button.wohnzimmer.i, UID=shelly:shellybutton2:3c6105f44d2d
2023-03-06 21:55:28.032 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly settings : {"device":{"type":"SHBTN-2","mac":"3C6105F44D2D","hostname":"shellybutton1-3C6105F44D2D","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellybutton1-3C6105F44D2D","key":""},"wifi_sta":{"enabled":true,"ssid":"Link","ipv4_method":"static","ip":"192.168.101.194","gw":"192.168.101.22","mask":"255.255.255.0","dns":"192.168.101.22"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellybutton1-3C6105F44D2D","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":false},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"multimedia-button.wohnzimmer.i","fw":"20221027-094830/v1.12.1-ga9117d3","discoverable":true,"build_info":{"build_id":"20221027-094830/v1.12.1-ga9117d3","build_timestamp":"2022-10-27T09:48:30Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":null,"lat":500.000000,"lng":500.000000,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-10","batch_id":1},"sleep_mode":{"period":12,"unit":"h"},"led_status_disable":false,"longpush_duration_ms":{"max":800},"multipush_time_between_pushes_ms":{"max":500},"remain_awake":0,"inputs":[{"name":null}]}
2023-03-06 21:55:28.033 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=34359): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,165],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 21:55:28.033 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Adding Shelly multimedia-button.wohnzimmer.i, UID=shelly:shellybutton2:3c6105f44d2d
2023-03-06 21:55:28.033 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,165],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 21:55:28.034 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 21:55:28.068 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=56836): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,165],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 21:55:28.069 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,165],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 21:55:28.069 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 21:55:28.184 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly settings : {"device":{"type":"SHBTN-2","mac":"3C6105F44D2D","hostname":"shellybutton1-3C6105F44D2D","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellybutton1-3C6105F44D2D","key":""},"wifi_sta":{"enabled":true,"ssid":"Link","ipv4_method":"static","ip":"192.168.101.194","gw":"192.168.101.22","mask":"255.255.255.0","dns":"192.168.101.22"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellybutton1-3C6105F44D2D","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":false},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"multimedia-button.wohnzimmer.i","fw":"20221027-094830/v1.12.1-ga9117d3","discoverable":true,"build_info":{"build_id":"20221027-094830/v1.12.1-ga9117d3","build_timestamp":"2022-10-27T09:48:30Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":null,"lat":500.000000,"lng":500.000000,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-10","batch_id":1},"sleep_mode":{"period":12,"unit":"h"},"led_status_disable":false,"longpush_duration_ms":{"max":800},"multipush_time_between_pushes_ms":{"max":500},"remain_awake":0,"inputs":[{"name":null}]}
2023-03-06 21:55:28.185 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Adding Shelly multimedia-button.wohnzimmer.i, UID=shelly:shellybutton2:3c6105f44d2d
2023-03-06 21:55:28.191 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly settings : {"device":{"type":"SHBTN-2","mac":"3C6105F44D2D","hostname":"shellybutton1-3C6105F44D2D","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellybutton1-3C6105F44D2D","key":""},"wifi_sta":{"enabled":true,"ssid":"Link","ipv4_method":"static","ip":"192.168.101.194","gw":"192.168.101.22","mask":"255.255.255.0","dns":"192.168.101.22"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellybutton1-3C6105F44D2D","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":false},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"multimedia-button.wohnzimmer.i","fw":"20221027-094830/v1.12.1-ga9117d3","discoverable":true,"build_info":{"build_id":"20221027-094830/v1.12.1-ga9117d3","build_timestamp":"2022-10-27T09:48:30Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":null,"lat":500.000000,"lng":500.000000,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-10","batch_id":1},"sleep_mode":{"period":12,"unit":"h"},"led_status_disable":false,"longpush_duration_ms":{"max":800},"multipush_time_between_pushes_ms":{"max":500},"remain_awake":0,"inputs":[{"name":null}]}
2023-03-06 21:55:28.191 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Adding Shelly multimedia-button.wohnzimmer.i, UID=shelly:shellybutton2:3c6105f44d2d
2023-03-06 21:55:28.701 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Status update triggered thing initialization
2023-03-06 21:55:28.701 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Start initializing for thing Wohnzimmer, Multimedia Button, type shellybutton1, IP address 192.168.101.194, Gen2: false, CoIoT: true
2023-03-06 21:55:28.702 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Stopping CoAP Listener
2023-03-06 21:55:28.702 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoAP Request was canceled
2023-03-06 21:55:28.703 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoAP Request was canceled
2023-03-06 21:55:28.703 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Starting CoAP Listener
2023-03-06 21:55:28.752 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Using CoAP device description from successful HTTP /cit/d
2023-03-06 21:55:28.753 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Device Description for shellybutton1-3c6105f44d2d: {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 21:55:28.754 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=1: sensor_0
2023-03-06 21:55:28.754 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=2: device
2023-03-06 21:55:28.755 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Adding 7 sensor definitions
2023-03-06 21:55:28.755 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9103: cfgChanged, Type=EVC, Range=U16, Links=2
2023-03-06 21:55:28.756 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2102: inputEvent, Type=EV, Range=S/L/SS/SSS;, Links=1
2023-03-06 21:55:28.756 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2103: inputEventCnt, Type=EVC, Range=U16, Links=1
2023-03-06 21:55:28.756 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3115: sensorError, Type=S, Range=0/1, Links=1
2023-03-06 21:55:28.757 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3112: charger, Type=S, Range=0/1;-1, Links=2
2023-03-06 21:55:28.757 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3111: battery, Type=B, Range=0/100;-1, Links=2
2023-03-06 21:55:28.757 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9102: wakeupEvent, Type=EV, Range=battery/button/periodic/poweron/sensor/ext_power;unknown, Links=2
2023-03-06 21:55:28.905 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Auto-CoIoT is enabled, disabling action urls
2023-03-06 21:55:28.906 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Starting CoIoT (autoCoIoT=true/true)
2023-03-06 21:55:28.906 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Stopping CoAP Listener
2023-03-06 21:55:28.907 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Starting CoAP Listener
2023-03-06 21:55:28.940 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Using CoAP device description from successful HTTP /cit/d
2023-03-06 21:55:28.940 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Device Description for shellybutton1-3c6105f44d2d: {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 21:55:28.941 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=1: sensor_0
2023-03-06 21:55:28.941 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=2: device
2023-03-06 21:55:28.941 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Adding 7 sensor definitions
2023-03-06 21:55:28.941 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9103: cfgChanged, Type=EVC, Range=U16, Links=2
2023-03-06 21:55:28.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2102: inputEvent, Type=EV, Range=S/L/SS/SSS;, Links=1
2023-03-06 21:55:28.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2103: inputEventCnt, Type=EVC, Range=U16, Links=1
2023-03-06 21:55:28.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3115: sensorError, Type=S, Range=0/1, Links=1
2023-03-06 21:55:28.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3112: charger, Type=S, Range=0/1;-1, Links=2
2023-03-06 21:55:28.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3111: battery, Type=B, Range=0/100;-1, Links=2
2023-03-06 21:55:28.942 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9102: wakeupEvent, Type=EV, Range=battery/button/periodic/poweron/sensor/ext_power;unknown, Links=2
2023-03-06 21:55:28.943 [DEBUG] [.shelly.internal.api1.Shelly1HttpApi] - shellybutton1-3c6105f44d2d: Set Sensor Reporting URL
2023-03-06 21:55:28.943 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Initializing device shellybutton1-3c6105f44d2d, type SHBTN-2, Hardware: Rev: prod-2020-10, batch 1; Firmware: v1.12.1-ga9117d3 / 20221027-094830
2023-03-06 21:55:28.943 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Shelly settings info for shellybutton1-3c6105f44d2d: {"device":{"type":"SHBTN-2","mac":"3C6105F44D2D","hostname":"shellybutton1-3C6105F44D2D","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellybutton1-3C6105F44D2D","key":""},"wifi_sta":{"enabled":true,"ssid":"Link","ipv4_method":"static","ip":"192.168.101.194","gw":"192.168.101.22","mask":"255.255.255.0","dns":"192.168.101.22"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellybutton1-3C6105F44D2D","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":false},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"multimedia-button.wohnzimmer.i","fw":"20221027-094830/v1.12.1-ga9117d3","discoverable":true,"build_info":{"build_id":"20221027-094830/v1.12.1-ga9117d3","build_timestamp":"2022-10-27T09:48:30Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":null,"lat":500.000000,"lng":500.000000,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-10","batch_id":1},"sleep_mode":{"period":12,"unit":"h"},"led_status_disable":false,"longpush_duration_ms":{"max":800},"multipush_time_between_pushes_ms":{"max":500},"remain_awake":0,"inputs":[{"name":null}]}
2023-03-06 21:55:28.943 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Device hasRelays:false (numRelays=0),isRoller:false (numRoller=0),isDimmer:false,numMeter=0,isEMeter:false), ext. Switch Add-On: n/a,isSensor:true,isDS:false,hasBattery:true (low battery threshold=20%),isSense:false,isMotion:false,isLight:false,isBulb:false,isDuo:false,isRGBW2:false,inColor:false,alwaysOn:false, updatePeriod:43260sec
2023-03-06 21:55:28.944 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Thing successfully initialized.
2023-03-06 21:55:29.025 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 21:55:29.026 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
[ Button pressed ]
2023-03-06 21:55:59.719 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=26997): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,166],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 21:55:59.720 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 21:55:59.721 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,166],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 21:55:59.722 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 21:55:59.723 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 2 channels updated from CoIoT status, serial=256
2023-03-06 21:55:59.921 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=26998): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,166],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 21:55:59.922 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,166],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 21:55:59.922 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
[ Button pressed ]
2023-03-06 21:56:17.030 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 21:56:20.409 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
k2023-03-06 21:56:26.489 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 21:56:29.561 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 21:56:35.641 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 21:56:38.713 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 21:56:44.793 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 21:56:47.865 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
[ Button pressed ]
2023-03-06 21:57:00.252 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=49265): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,167],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 21:57:00.252 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,167],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 21:57:00.252 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 21:57:00.252 [DEBUG] [y.internal.api1.Shelly1CoIoTProtocol] - shellybutton1-3c6105f44d2d: Trigger event S
2023-03-06 21:57:00.253 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Update button state with S/SHORT_PRESSED
2023-03-06 21:57:00.253 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Send event status#button to channel SHORT_PRESSED
2023-03-06 21:57:00.253 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 1 channels updated from CoIoT status, serial=256
2023-03-06 21:57:00.254 [INFO ] [g.openhab.core.model.script.MMButton] - Pressed
2023-03-06 21:57:00.463 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=49266): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,167],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 21:57:00.463 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,167],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 21:57:00.463 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
Log
[ Button pressed ]
2023-03-06 22:02:28.903 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly device discovered: IP-Adress=192.168.101.194, type=shellybutton1
2023-03-06 22:02:28.904 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly device discovered: IP-Adress=192.168.101.194, type=shellybutton1
2023-03-06 22:02:28.908 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=59567): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,168],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:02:28.908 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 22:02:28.909 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,168],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 22:02:29.014 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Using CoAP device description from successful HTTP /cit/d
2023-03-06 22:02:29.014 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Device Description for shellybutton1-3c6105f44d2d: {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 22:02:29.015 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=1: sensor_0
2023-03-06 22:02:29.016 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=2: device
2023-03-06 22:02:29.016 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Adding 7 sensor definitions
2023-03-06 22:02:29.017 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9103: cfgChanged, Type=EVC, Range=U16, Links=2
2023-03-06 22:02:29.017 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2102: inputEvent, Type=EV, Range=S/L/SS/SSS;, Links=1
2023-03-06 22:02:29.017 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2103: inputEventCnt, Type=EVC, Range=U16, Links=1
2023-03-06 22:02:29.018 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3115: sensorError, Type=S, Range=0/1, Links=1
2023-03-06 22:02:29.018 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3112: charger, Type=S, Range=0/1;-1, Links=2
2023-03-06 22:02:29.018 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3111: battery, Type=B, Range=0/100;-1, Links=2
2023-03-06 22:02:29.019 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9102: wakeupEvent, Type=EV, Range=battery/button/periodic/poweron/sensor/ext_power;unknown, Links=2
2023-03-06 22:02:29.019 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Device description for SHBTN-2#3C6105F44D2D#2 restored: {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 22:02:29.019 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Device Description for SHBTN-2#3C6105F44D2D#2: {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 22:02:29.019 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=1: sensor_0
2023-03-06 22:02:29.020 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=2: device
2023-03-06 22:02:29.020 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Adding 7 sensor definitions
2023-03-06 22:02:29.020 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9103: cfgChanged, Type=EVC, Range=U16, Links=2
2023-03-06 22:02:29.021 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2102: inputEvent, Type=EV, Range=S/L/SS/SSS;, Links=1
2023-03-06 22:02:29.021 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2103: inputEventCnt, Type=EVC, Range=U16, Links=1
2023-03-06 22:02:29.021 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3115: sensorError, Type=S, Range=0/1, Links=1
2023-03-06 22:02:29.021 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3112: charger, Type=S, Range=0/1;-1, Links=2
2023-03-06 22:02:29.022 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3111: battery, Type=B, Range=0/100;-1, Links=2
2023-03-06 22:02:29.022 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9102: wakeupEvent, Type=EV, Range=battery/button/periodic/poweron/sensor/ext_power;unknown, Links=2
2023-03-06 22:02:29.022 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:02:29.023 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 22:02:29.023 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
2023-03-06 22:02:29.024 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 5 channels updated from CoIoT status, serial=256
2023-03-06 22:02:29.117 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=59568): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,168],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:02:29.118 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,168],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 22:02:29.118 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:02:29.215 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly settings : {"device":{"type":"SHBTN-2","mac":"3C6105F44D2D","hostname":"shellybutton1-3C6105F44D2D","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellybutton1-3C6105F44D2D","key":""},"wifi_sta":{"enabled":true,"ssid":"Link","ipv4_method":"static","ip":"192.168.101.194","gw":"192.168.101.22","mask":"255.255.255.0","dns":"192.168.101.22"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellybutton1-3C6105F44D2D","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":false},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"multimedia-button.wohnzimmer.i","fw":"20221027-094830/v1.12.1-ga9117d3","discoverable":true,"build_info":{"build_id":"20221027-094830/v1.12.1-ga9117d3","build_timestamp":"2022-10-27T09:48:30Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":null,"lat":500.000000,"lng":500.000000,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-10","batch_id":1},"sleep_mode":{"period":12,"unit":"h"},"led_status_disable":false,"longpush_duration_ms":{"max":800},"multipush_time_between_pushes_ms":{"max":500},"remain_awake":0,"inputs":[{"name":null}]}
2023-03-06 22:02:29.216 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Adding Shelly multimedia-button.wohnzimmer.i, UID=shelly:shellybutton2:3c6105f44d2d
2023-03-06 22:02:29.238 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=61628): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,168],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:02:29.239 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,168],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 22:02:29.240 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:02:29.245 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly settings : {"device":{"type":"SHBTN-2","mac":"3C6105F44D2D","hostname":"shellybutton1-3C6105F44D2D","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellybutton1-3C6105F44D2D","key":""},"wifi_sta":{"enabled":true,"ssid":"Link","ipv4_method":"static","ip":"192.168.101.194","gw":"192.168.101.22","mask":"255.255.255.0","dns":"192.168.101.22"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellybutton1-3C6105F44D2D","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":false},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"multimedia-button.wohnzimmer.i","fw":"20221027-094830/v1.12.1-ga9117d3","discoverable":true,"build_info":{"build_id":"20221027-094830/v1.12.1-ga9117d3","build_timestamp":"2022-10-27T09:48:30Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":null,"lat":500.000000,"lng":500.000000,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-10","batch_id":1},"sleep_mode":{"period":12,"unit":"h"},"led_status_disable":false,"longpush_duration_ms":{"max":800},"multipush_time_between_pushes_ms":{"max":500},"remain_awake":0,"inputs":[{"name":null}]}
2023-03-06 22:02:29.246 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Adding Shelly multimedia-button.wohnzimmer.i, UID=shelly:shellybutton2:3c6105f44d2d
2023-03-06 22:02:29.372 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly settings : {"device":{"type":"SHBTN-2","mac":"3C6105F44D2D","hostname":"shellybutton1-3C6105F44D2D","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellybutton1-3C6105F44D2D","key":""},"wifi_sta":{"enabled":true,"ssid":"Link","ipv4_method":"static","ip":"192.168.101.194","gw":"192.168.101.22","mask":"255.255.255.0","dns":"192.168.101.22"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellybutton1-3C6105F44D2D","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":false},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"multimedia-button.wohnzimmer.i","fw":"20221027-094830/v1.12.1-ga9117d3","discoverable":true,"build_info":{"build_id":"20221027-094830/v1.12.1-ga9117d3","build_timestamp":"2022-10-27T09:48:30Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":null,"lat":500.000000,"lng":500.000000,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-10","batch_id":1},"sleep_mode":{"period":12,"unit":"h"},"led_status_disable":false,"longpush_duration_ms":{"max":800},"multipush_time_between_pushes_ms":{"max":500},"remain_awake":0,"inputs":[{"name":null}]}
2023-03-06 22:02:29.373 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Adding Shelly multimedia-button.wohnzimmer.i, UID=shelly:shellybutton2:3c6105f44d2d
2023-03-06 22:02:29.375 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Shelly settings : {"device":{"type":"SHBTN-2","mac":"3C6105F44D2D","hostname":"shellybutton1-3C6105F44D2D","sleep_mode":true},"wifi_ap":{"enabled":false,"ssid":"shellybutton1-3C6105F44D2D","key":""},"wifi_sta":{"enabled":true,"ssid":"Link","ipv4_method":"static","ip":"192.168.101.194","gw":"192.168.101.22","mask":"255.255.255.0","dns":"192.168.101.22"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.33.3:1883","user":"","id":"shellybutton1-3C6105F44D2D","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":0,"retain":false,"update_period":30},"coiot": {"enabled":true,"update_period":15,"peer":""},"sntp":{"server":"time.google.com","enabled":false},"login":{"enabled":false,"unprotected":false,"username":"admin"},"pin_code":"","name":"multimedia-button.wohnzimmer.i","fw":"20221027-094830/v1.12.1-ga9117d3","discoverable":true,"build_info":{"build_id":"20221027-094830/v1.12.1-ga9117d3","build_timestamp":"2022-10-27T09:48:30Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":null,"lat":500.000000,"lng":500.000000,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":false,"tz_dst_auto":true,"time":"","unixtime":0,"led_status_disable":false,"debug_enable":false,"allow_cross_origin":false,"actions":{"active":false,"names":["shortpush_url","longpush_url","double_shortpush_url","triple_shortpush_url"]},"hwinfo":{"hw_revision":"prod-2020-10","batch_id":1},"sleep_mode":{"period":12,"unit":"h"},"led_status_disable":false,"longpush_duration_ms":{"max":800},"multipush_time_between_pushes_ms":{"max":500},"remain_awake":0,"inputs":[{"name":null}]}
2023-03-06 22:02:29.375 [DEBUG] [discovery.ShellyDiscoveryParticipant] - shellybutton1-3c6105f44d2d: Adding Shelly multimedia-button.wohnzimmer.i, UID=shelly:shellybutton2:3c6105f44d2d
2023-03-06 22:02:31.886 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Status update triggered thing initialization
2023-03-06 22:02:31.887 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Start initializing for thing Wohnzimmer, Multimedia Button, type shellybutton1, IP address 192.168.101.194, Gen2: false, CoIoT: true
2023-03-06 22:02:31.887 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Stopping CoAP Listener
2023-03-06 22:02:31.889 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoAP Request was canceled
2023-03-06 22:02:31.889 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Starting CoAP Listener
[ Just wait ]
2023-03-06 22:03:01.891 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
[ Button pressed ]
2023-03-06 22:03:27.212 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=59924): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,169],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:03:27.213 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 22:03:27.213 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,169],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 22:03:27.214 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:03:27.215 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 22:03:27.216 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
2023-03-06 22:03:27.217 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 5 channels updated from CoIoT status, serial=256
2023-03-06 22:03:27.413 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=59925): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,169],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:03:27.414 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,169],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 22:03:27.415 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:03:28.894 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Status update triggered thing initialization
2023-03-06 22:03:28.894 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Start initializing for thing Wohnzimmer, Multimedia Button, type shellybutton1, IP address 192.168.101.194, Gen2: false, CoIoT: true
2023-03-06 22:03:28.895 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Stopping CoAP Listener
2023-03-06 22:03:28.895 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoAP Request was canceled
2023-03-06 22:03:28.896 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Starting CoAP Listener
2023-03-06 22:03:43.899 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
[ Button pressed ]
2023-03-06 22:04:02.228 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=24166): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,170],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:04:02.229 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 22:04:02.229 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,170],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 22:04:02.230 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:04:02.231 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 22:04:02.231 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
2023-03-06 22:04:02.232 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 5 channels updated from CoIoT status, serial=256
2023-03-06 22:04:02.433 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=24167): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,170],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:04:02.434 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,170],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 22:04:02.435 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:04:04.901 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Status update triggered thing initialization
2023-03-06 22:04:04.902 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Start initializing for thing Wohnzimmer, Multimedia Button, type shellybutton1, IP address 192.168.101.194, Gen2: false, CoIoT: true
2023-03-06 22:04:04.902 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Stopping CoAP Listener
2023-03-06 22:04:04.904 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoAP Request was canceled
2023-03-06 22:04:04.904 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Starting CoAP Listener
[ Button pressed ]
2023-03-06 22:04:19.436 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=56722): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,171],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:04:19.437 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 22:04:19.437 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,171],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 22:04:19.438 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:04:19.439 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 22:04:19.440 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
2023-03-06 22:04:19.440 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 5 channels updated from CoIoT status, serial=256
2023-03-06 22:04:19.637 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=56723): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,171],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:04:19.638 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,171],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 22:04:19.638 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:04:19.907 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 22:04:19.931 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=61631): {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 22:04:19.932 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Device Description for SHBTN-2#3C6105F44D2D#2: {"blk":[{"I":1,"D":"sensor_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":2102,"T":"EV","D":"inputEvent","R":["S/L/SS/SSS",""],"L":1},{"I":2103,"T":"EVC","D":"inputEventCnt","R":"U16","L":1},{"I":3115,"T":"S","D":"sensorError","R":"0/1","L":1},{"I":3112,"T":"S","D":"charger","R":["0/1","-1"],"L":2},{"I":3111,"T":"B","D":"battery","R":["0/100","-1"],"L":2},{"I":9102,"T":"EV","D":"wakeupEvent","R":["battery/button/periodic/poweron/sensor/ext_power","unknown"],"L":2}]}
2023-03-06 22:04:19.932 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=1: sensor_0
2023-03-06 22:04:19.933 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id=2: device
2023-03-06 22:04:19.933 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Adding 7 sensor definitions
2023-03-06 22:04:19.933 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9103: cfgChanged, Type=EVC, Range=U16, Links=2
2023-03-06 22:04:19.934 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2102: inputEvent, Type=EV, Range=S/L/SS/SSS;, Links=1
2023-03-06 22:04:19.934 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 2103: inputEventCnt, Type=EVC, Range=U16, Links=1
2023-03-06 22:04:19.934 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3115: sensorError, Type=S, Range=0/1, Links=1
2023-03-06 22:04:19.935 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3112: charger, Type=S, Range=0/1;-1, Links=2
2023-03-06 22:04:19.935 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 3111: battery, Type=B, Range=0/100;-1, Links=2
2023-03-06 22:04:19.936 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: id 9102: wakeupEvent, Type=EV, Range=battery/button/periodic/poweron/sensor/ext_power;unknown, Links=2
2023-03-06 22:04:22.911 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Status update triggered thing initialization
2023-03-06 22:04:22.912 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Start initializing for thing Wohnzimmer, Multimedia Button, type shellybutton1, IP address 192.168.101.194, Gen2: false, CoIoT: true
2023-03-06 22:04:22.913 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Stopping CoAP Listener
2023-03-06 22:04:22.913 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoAP Request was canceled
2023-03-06 22:04:22.914 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Starting CoAP Listener
[ Button pressed ]
2023-03-06 22:04:47.456 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=45564): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,172],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:04:47.456 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 22:04:47.457 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,172],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 22:04:47.457 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:04:47.457 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 22:04:47.457 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
2023-03-06 22:04:47.458 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 5 channels updated from CoIoT status, serial=256
2023-03-06 22:04:47.661 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=45565): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,172],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:04:47.662 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,172],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 22:04:47.663 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:04:52.915 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 22:04:55.916 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Status update triggered thing initialization
2023-03-06 22:04:55.917 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Start initializing for thing Wohnzimmer, Multimedia Button, type shellybutton1, IP address 192.168.101.194, Gen2: false, CoIoT: true
2023-03-06 22:04:55.917 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Stopping CoAP Listener
2023-03-06 22:04:55.919 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoAP Request was canceled
2023-03-06 22:04:55.919 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Starting CoAP Listener
[ Button pressed ]
2023-03-06 22:05:09.305 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 22:05:09.717 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=55498): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,173],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:05:09.718 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 22:05:09.719 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,173],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 22:05:09.719 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:05:09.720 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 22:05:09.721 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
2023-03-06 22:05:09.722 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 5 channels updated from CoIoT status, serial=256
2023-03-06 22:05:09.918 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=55499): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,173],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:05:09.918 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,173],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 22:05:09.918 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:05:12.307 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Status update triggered thing initialization
2023-03-06 22:05:12.308 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Start initializing for thing Wohnzimmer, Multimedia Button, type shellybutton1, IP address 192.168.101.194, Gen2: false, CoIoT: true
2023-03-06 22:05:12.308 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Stopping CoAP Listener
2023-03-06 22:05:12.309 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoAP Request was canceled
2023-03-06 22:05:12.310 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Starting CoAP Listener
2023-03-06 22:05:25.689 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
[ Button pressed ]
2023-03-06 22:08:35.331 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=9892): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,174],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:08:35.332 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 22:08:35.332 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,174],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 22:08:35.333 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:08:35.334 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 22:08:35.335 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
2023-03-06 22:08:35.335 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 5 channels updated from CoIoT status, serial=256
2023-03-06 22:08:35.501 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=9893): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,174],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:08:35.502 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,174],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 22:08:35.503 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:08:37.712 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Status update triggered thing initialization
2023-03-06 22:08:37.713 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Start initializing for thing Wohnzimmer, Multimedia Button, type shellybutton1, IP address 192.168.101.194, Gen2: false, CoIoT: true
2023-03-06 22:08:37.713 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Stopping CoAP Listener
2023-03-06 22:08:37.714 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoAP Request was canceled
2023-03-06 22:08:37.714 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: Starting CoAP Listener
[ Button pressed ]
2023-03-06 22:08:42.641 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=24546): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,175],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:08:42.642 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Version 2 detected
2023-03-06 22:08:42.642 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,175],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 22:08:42.642 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:08:42.643 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ereignis gefiltert: BUTTON
2023-03-06 22:08:42.643 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Channel battery#batteryLevel updated with 79 % (type class org.openhab.core.library.types.QuantityType).
2023-03-06 22:08:42.643 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 5 channels updated from CoIoT status, serial=256
2023-03-06 22:08:42.845 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=24547): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,175],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:08:42.846 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,175],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=512)
2023-03-06 22:08:42.846 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
[ Button pressed ]
2023-03-06 22:08:52.717 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Ignore API Timeout, retry later
2023-03-06 22:08:52.744 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Message from /192.168.101.194:5683 (MID=7972): {"G":[[0,9103,0],[0,2102,"S"],[0,2103,176],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]}
2023-03-06 22:08:52.745 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: CoIoT Sensor data {"G":[[0,9103,0],[0,2102,"S"],[0,2103,176],[0,3115,0],[0,3112,0],[0,3111,79],[0,9102,["button"]]]} (serial=256)
2023-03-06 22:08:52.746 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 7 CoAP sensor updates received
2023-03-06 22:08:52.746 [DEBUG] [y.internal.api1.Shelly1CoIoTProtocol] - shellybutton1-3c6105f44d2d: Trigger event S
2023-03-06 22:08:52.747 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Update button state with S/SHORT_PRESSED
2023-03-06 22:08:52.747 [DEBUG] [y.internal.handler.ShellyBaseHandler] - shellybutton1-3c6105f44d2d: Send event status#button to channel SHORT_PRESSED
2023-03-06 22:08:52.748 [DEBUG] [lly.internal.api1.Shelly1CoapHandler] - shellybutton1-3c6105f44d2d: 1 channels updated from CoIoT status, serial=256
2023-03-06 22:08:52.778 [INFO ] [g.openhab.core.model.script.MMButton] - Pressed
If it helps, I can also activate TRACE log, just let me know.
In some post above, I read that the Shelly binding is associating coap messages with the OH things according to their IP address. Therefore, I tried reconfiguring a button thing in OH and directly use it’s IP instead of its local DNS name, but this didn’t help (fourth button press was registered and there seemd to be a bigger delay between button presses and logging in OH).
