Shelly Binding
If you connected the motion detector to the relay’s input you could just watch the input channel of the specific relay
  • link an item to the relay’s input channel
  • when Item xxx changed to ON
thanks for the fast answer … does this work when i have configured the shelly in detached mode?
do you mean an item with {channel=“shelly:shelly25-relay:xxxxxx:relay1#input”} ?
The input channel is available independent from the device mode,
yes
Maybe the discovery is trying a little bit to hard?
[discovery.ShellyDiscoveryParticipant] - Unsupported Shelly Device discovered: pioneer vsx-1131 (mode )
Openhab 2.5.0 on Rpi 3b+ with 2.4.0.201911011055 Shelly Binding.
Please use the 2.5 final version, which comes with OH 2.5 or the latest DEV build. 2.4 is no longer supported.
Just upgraded to OH 2.5 and loving the Shelly Binding, really great integration!
I’m experiencing an unexpected behaviour with the RGBW2… in white mode. When using MQTT and/or HTML the ON/OFF function and BRIGHTNESS functions are separate. I.e. you can change the brightness setting when the channel is OFF and nothing happens. When using the Shelly binding if the brightness is changed on a channel, it automatically turns ON as well. Just wondering if there is anyway to change that behaviour or if i need to switch back to MQTT for now?
(Use case… I have a motion sensor changing the brightness from Low to High and back again. I have a separate rule linked to the Astro binding so the lights are only on at night. During the day, the motion sensor is (was) still changing the brightness in the background, but as the lights were off, there was no change to the lights.)
Cheers!
This has been discussed here: [shelly] FTR: Control Auto-ON when setting Dimmer brightness · Issue #6608 · openhab/openhab-addons · GitHub
a) The release implementation follows the standard OH paradigm
- brightess = 0 sets also device OFF
- brightness > 0 automatically turns on the device
b) The DEV build includes a new thing config option to disable the Auto-ON so you could set brightness without turning ON the device
Brightness and state could be controlled by linking 2 items(Switch for ON/OFF, Number for brightness-%) to the same brightness channel.
i have a lamp and a motion detector on a shelly 2.5. basically the control works, but i have a problem with the reaction time.
the motion detector is supposed to switch on the lamp immediately. but the lamp is only switched on up to 8s after the motion detector has been switched on.
am i the only one with this problem, or has anyone else noticed it?
shelly.things
Thing shelly:shelly25-relay:xxxxxx "EgHaustuer" [deviceIp="xxx.xxx.xxx.xxx", userId="", password=""]
items
Switch Eg_Haustuer_Bewegungsmelder "Haustuer Bewegungsmelder" <motion> {channel="shelly:shelly25-relay:xxxxxx:relay1#input"}
Switch Eg_Haustuer_Licht "Haustuere Licht" <switch> {channel="shelly:shelly25-relay:xxxxxx:relay1#output"}
rule
rule "Licht Haustuer ein"
	Item Eg_Haustuer_Bewegungsmelder changed to ON
	sendCommand(Eg_Haustuer_Licht, ON)
logfile
2019-12-28 22:01:33.225 [vent.ChannelTriggeredEvent] - shelly:shelly25-relay:690a17:relay1#button triggered LONG_PRESSED
2019-12-28 22:01:37.941 [vent.ItemStateChangedEvent] - Eg_Haustuer_Bewegungsmelder changed from OFF to ON
2019-12-28 22:01:37.992 [ome.event.ItemCommandEvent] - Item 'Eg_Haustuer_Licht' received command ON
2019-12-28 22:01:38.003 [nt.ItemStatePredictedEvent] - Eg_Haustuer_Licht predicted to become ON
2019-12-28 22:01:38.032 [vent.ItemStateChangedEvent] - Eg_Haustuer_Licht changed from OFF to ON
openhab 2.5.0 stable on raspberry pi 3
try to
  • enable button events and
  • disable push events in the thing config
  • clear the push action url in the Shelly Web App (this is not yet automatically done by the binding)
Maybe the push event url overwrites the button event url = when the push urls are set the device doesn’t provide the regular button urls
Problem behind: Shelly does not provide up-to-date documentation, so the exact behavior is not specified
You could also try to enable CoIoT for the device. Send me a PM with the TRACE log and I check what we can do.
i have implemented the advice. currently it takes 1.5-5 seconds from switching the motion detector to switching the relay for the light. in my opinion this time is still much too high.
thing-file:
Thing shelly:shelly25-relay:xxxxxx "EgHaustuer" [deviceIp="1xx.xxx.xxx.xxx", userId="", password="", eventsButton=true, eventsPush=false, eventsCoIoT=true]
item-file:
rule-file:
    if(Astro_Daylight_On.state != ON)
events.log:
events.log (402 Bytes)
obenhab.log:
openhab.log (76.4 KB)
grafik
grafik
grafik
many thanks for your support
Together with @Kellermeister I’m working on optimizing the event handling
  • Speed up input/output event signalling
  • Work around/Fix for reported input channel by CoIoT events
  • Disabling push events by default (activating them disables btn_on/off events)
Details: [shelly] Optimize event handling to directly update input/output channels · Issue #6706 · openhab/openhab-addons · GitHub
I may change the binding to register push events only in momentary switch mode and otherwise register button events. However, this might remove flexibility, because you loose full control, which event types to register (e.g. having a momentary switch in detached mode). What do you think?
Update 12/30:
Done.
@Kellermeister finished testing, we are now down to
  • input channel update by http events: around 900-100ms
  • by CoIoT/Coap event: about 700ms (Coap update comes a little quicker compared to http event)
This is a really good result, also relevant for detached mode.
fyi: Together with @dilisi we identified a problem that sensor things (e.g. HT) stay in status UNKNOWN after a OH restart when a thing was added manually in PaperUI or defined in a .things file.
details: [shelly] Sensor thing stays in state UNKNOWN after OH restart when thing was added manually · Issue #6707 · openhab/openhab-addons · GitHub
Update 12/30:
Done
@dilisi confirmed that the problem is solved with the DEV build, also verified with password protected devices
Updated DEV build: https://github.com/markus7017/myfiles/blob/master/org.openhab.binding.shelly-2.5.0-SNAPSHOT.jar?raw=true
Thanks Markus! I’m a bit novice to try the DEV build i think! I currently have 2 items defined for each channel on the RGBW2 (power channel - switch ON/OFF and Brightness channel - dimmer %), but the power channel still changes to ON when brightness channel is changed.
Looking forward to the thing config to disable the Auto-ON :slight_smile: I will hold off reconfiguring back to MQTT for now! Cheers!
let me know if you need support on installing the DEV build
This is already implemenrted. Go to the thing configuration there is a Switch “Brightness Auto-ON”, set this to OFF. Make sure you deleted the thing and re-discovered (Item linkage will be restored)
Does anybody has a Shelly EM and could verify with the latest DEV build that all channels get their value including the proper units?
A user has the problem that the channels get the values, but some of them don’t show the unit. I check channel definition and code, which looks good and even more strange meter1 shows the V on voltage, but meter 2 doesn’t even it uses exactly the same channel definition.
![71625234-fddfda80-2be6-11ea-9e93-a3150daa0b7a|274x500 (upload://53ky5qUtuenzBHLHJvD8f0T65HB.png)
The trace shows the correct channel update from the binding, but then the item doesn’t receive the unit (I also checked the display pattern definition).
shellyem-b9f299: Channel meter1#voltage updated with 234.35 V (type class org.eclipse.smarthome.core.library.types.QuantityType).
ShellyemB9f299192168048_Meter1_Voltage changed from 233.03 to 234.35
It seems like the californium libs donot survive a clean-cache and reboot.
Does anybody can point me to a jar to be placed in the addon folder? (or is there a way to install it permanentely in the karaf console?)
Reboot yes, clean-cache no. A clean-cache removes all dependencies, which are no longer use. In our situation the Californium libs are install aside from the binding jar, the framework doesn’t detect this dependency and removes the openhab-transport-coap feature.
see Shelly Binding - #729 by markus7017 “Installung DEV/SNAPSHOT build” to get the URLs for GSon (OH 2.4 only) and Californium. Copying those to the addons folder make them resistent to a clean-cache.
This doesn’t apply for the release version, because there the framework knows that dependency.
great binding!
I just stumbled over the “Temperature Sensor Addon for Shelly 1/1PM” in the shelly shop.
Are these already supported?
In theory yes, but nobody had one so far. If you provide me the JSON from /settings and /status it should be easy to integrate.
Hi Markus,
i ordered the Addon yesterday for my Shelly1 probably i can provide you the JSON then.
BR Peter
