WIth shelly dimmer i have the problem does the dimmer recognizes a long pressed but send no trigger LONG_PRESSED
2020-06-29 21:41:13.523 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer- d45ff6: 11 CoAP sensor updates received
2020-06-29 21:41:13.526 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[0]: id=111, Value=57.0 (Brightness, Type=S, Range=0/100, Link=0: Dimmer)
2020-06-29 21:41:13.529 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[1]: id=121, Value=1.0 (State, Type=S, Range=0/1, Link=0: Dimmer)
2020-06-29 21:41:13.533 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[2]: id=131, Value=1.0 (Input, Type=S, Range=0(off)/1(on)/2(longpush), Link=0: Dimmer)
2020-06-29 21:41:13.535 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[3]: id=141, Value=0.0 (Input, Type=S, Range=0(off)/1(on)/2(longpush), Link=0: Dimmer)
2020-06-29 21:41:13.539 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[4]: id=211, Value=0.0 (Energy counter 0 [W-min], Type=S, Range=null, Link=0: Dimmer)
2020-06-29 21:41:13.542 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[5]: id=212, Value=0.0 (Energy counter 1 [W-min], Type=S, Range=null, Link=0: Dimmer)
2020-06-29 21:41:13.546 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[6]: id=213, Value=0.0 (Energy counter 2 [W-min], Type=S, Range=null, Link=0: Dimmer)
2020-06-29 21:41:13.549 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[7]: id=214, Value=1705.0 (Energy counter total [W-min], Type=S, Range=null, Link=0: Dimmer)
2020-06-29 21:41:13.553 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[8]: id=311, Value=45.75 (Temperature C, Type=T, Range=-40/300, Link=0: Dimmer)
2020-06-29 21:41:13.556 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[9]: id=312, Value=114.36 (Temperature F, Type=T, Range=-40/300, Link=0: Dimmer)
2020-06-29 21:41:13.559 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[10]: id=313, Value=0.0 (Overtemp, Type=S, Range=0/1, Link=0: Dimmer)
2020-06-29 21:41:13.563 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer-d45ff6: Channel relay#brightness$Switch updated with ON (type class org.eclipse.smarthome.core.library.types.OnOffType).
2020-06-29 21:41:13.570 [DEBUG] [lly.internal.util.ShellyChannelCache] - shellydimmer-d45ff6: Channel relay#brightness$Value updated with 57 % (type class org.eclipse.smarthome.core.library.types.QuantityType).
2020-06-29 21:41:13.575 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: 2 channels updated from CoIoT status
2020-06-29 21:41:13.579 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: CoIoT Message from /192.168.177.20:5683 (MID=27404): {"G":[[0,111, 57],[0,121, 1],[0,131, 1],[0,141, 0],[0,211,0.000],[0,212,0.000],[0,213,0.000],[0,214,1705],[0,311,45.75],[0,312,114.36],[0,313,0]]}
2020-06-29 21:41:13.582 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Serial 15626 was already processed, ignore update
2020-06-29 21:41:13.922 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellydimmer-d45ff6: Updating status
2020-06-29 21:41:13.923 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellydimmer-d45ff6: HTTP GET for http://192.168.177.20/status
2020-06-29 21:41:14.007 [TRACE] [ng.shelly.internal.api.ShellyHttpApi] - shellydimmer-d45ff6: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"MosHome","ip":"192.168.177.20","rssi":-73},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"21:41","unixtime":1593466874,"serial":1,"has_update":false,"mac":"F4CFA2D45FF6","lights":[{"ison":true,"has_timer":true,"timer_started":1593466874,"timer_duration":181,"timer_remaining":181,"mode":"white","brightness":57}],"meters":[{"power":0.00, "is_valid":true, "timestamp":1593466874,"counters":[0.000, 0.000, 0.000],"total":1705}],"inputs":[{"input":1,"event":"L","event_cnt":87},{"input":0,"event":"","event_cnt":0}],"tmp":{"tC":45.75,"tF":114.36, "is_valid":true},"calib_progress":0,"overtemperature":false,"loaderror":false,"overload":false,"update":{"status":"idle","has_update":false,"new_version":"20200601-123355/v1.7.0@d7961837","old_version":"20200601-123355/v1.7.0@d7961837"},"ram_total":48024,"ram_free":36860,"ram_lwm":29912,"fs_size":233681,"fs_free":131524,"uptime":194333}
2020-06-29 21:41:14.016 [TRACE] [.internal.handler.ShellyRelayHandler] - shellydimmer-d45ff6: Updating 1 dimmers(s)
2020-06-29 21:41:14.021 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellydimmer-d45ff6: Updating relay#input1 with ON, input2 with OFF
2020-06-29 21:41:14.024 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellydimmer-d45ff6: Updating 1 standard meter(s)
2020-06-29 21:41:14.029 [TRACE] [y.internal.handler.ShellyBaseHandler] - shellydimmer-d45ff6: 0 more updates requested
2020-06-29 21:41:14.387 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: CoIoT Message from /192.168.177.20:5683 (MID=27405): {"G":[[0,111, 57],[0,121, 1],[0,131, 2],[0,141, 0],[0,211,0.000],[0,212,0.000],[0,213,0.000],[0,214,1705],[0,311,45.75],[0,312,114.36],[0,313,0]]}
2020-06-29 21:41:14.390 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: CoIoT Sensor data {"G":[[0,111, 57],[0,121, 1],[0,131, 2],[0,141, 0],[0,211,0.000],[0,212,0.000],[0,213,0.000],[0,214,1705],[0,311,45.75],[0,312,114.36],[0,313,0]]}
2020-06-29 21:41:14.393 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: 11 CoAP sensor updates received
2020-06-29 21:41:14.396 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[0]: id=111, Value=57.0 (Brightness, Type=S, Range=0/100, Link=0: Dimmer)
2020-06-29 21:41:14.399 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[1]: id=121, Value=1.0 (State, Type=S, Range=0/1, Link=0: Dimmer)
2020-06-29 21:41:14.403 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[2]: id=131, Value=2.0 (Input, Type=S, Range=0(off)/1(on)/2(longpush), Link=0: Dimmer)
2020-06-29 21:41:14.406 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[3]: id=141, Value=0.0 (Input, Type=S, Range=0(off)/1(on)/2(longpush), Link=0: Dimmer)
2020-06-29 21:41:14.409 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[4]: id=211, Value=0.0 (Energy counter 0 [W-min], Type=S, Range=null, Link=0: Dimmer)
2020-06-29 21:41:14.413 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[5]: id=212, Value=0.0 (Energy counter 1 [W-min], Type=S, Range=null, Link=0: Dimmer)
2020-06-29 21:41:14.416 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[6]: id=213, Value=0.0 (Energy counter 2 [W-min], Type=S, Range=null, Link=0: Dimmer)
2020-06-29 21:41:14.420 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[7]: id=214, Value=1705.0 (Energy counter total [W-min], Type=S, Range=null, Link=0: Dimmer)
2020-06-29 21:41:14.424 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[8]: id=311, Value=45.75 (Temperature C, Type=T, Range=-40/300, Link=0: Dimmer)
2020-06-29 21:41:14.428 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[9]: id=312, Value=114.36 (Temperature F, Type=T, Range=-40/300, Link=0: Dimmer)
2020-06-29 21:41:14.431 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: Sensor value[10]: id=313, Value=0.0 (Overtemp, Type=S, Range=0/1, Link=0: Dimmer)
2020-06-29 21:41:14.579 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shelly1-8caab50558d3: CoIoT Message from /192.168.177.16:5683 (MID=26810): {"G":[[0,112,0],[0,118,0]]}
2020-06-29 21:41:14.581 [TRACE] [elly.internal.coap.ShellyCoapHandler] - shelly1-8caab50558d3: Serial 1280 was already processed, ignore update
2020-06-29 21:41:16.636 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: CoIoT Message from /192.168.177.20:5683 (MID=27406): {"G":[[0,111, 57],[0,121, 1],[0,131, 0],[0,141, 0],[0,211,0.000],[0,212,0.000],[0,213,0.000],[0,214,1705],[0,311,45.75],[0,312,114.36],[0,313,0]]}
2020-06-29 21:41:16.638 [DEBUG] [elly.internal.coap.ShellyCoapHandler] - shellydimmer-d45ff6: CoIoT Sensor data {"G":[[0,111, 57],[0,121, 1],[0,131, 0],[0,141, 0],[0,211,0.000],[0,212,0.000],[0,213,0.000],[0,214,1705],[0,311,45.75],[0,312,114.36],[0,313,0]]}
