I use also with static IPs without any problems.
yep, how should the device report an push event when the button is detached?
you need to delete and re-discover thing when the IP changes, the binding def. works with devices using a static ip
If you want to use the action urls you need to disable CoIoT events
- binding config
- thing config
the binding will reinitialize the thing and set the urls, which you also see in the device ui
I did it already. I see in the logs that it goes through the various devices but the action URLs are not touched. They are not removed when you activate COAP and they are not set when you deactivate it. Iâve only being able to have them set at the initial inclusion (that was probably before COAP/CoIoT support).
But the button IS reporting events. Iâm using the input channel to switch my hue lights on and off when the button is pressed. As far as I know the detached mode means that button events are not directly reported to output but are still reported by the Shelly device. The only thing that is not working for me is the trigger.
we are talking about different things
- In general Coap and action urls are independent from each other. However, the binding does not register action urls if Coap is enabled, because Coap is event driven and provides more information than those urls. The binding has the AutoCoToT feature in the binding settings to activate Coap automatically when firmware 1.6+ is detected.
- When AutoCoIoT and Coap events are disabled the binding registers the selected action urls at thing initialization. If this is not working something musst be wrong. Delete the thing and re-discover.
- You need to select momentary button mode to receive the push events. The device doesnât generate those in detached mode. However, you could do the mentioned trick and trigger when the output is switched so the event gets fired on the output side, not on the input side. In this case you canât use the trigger channel, but the rule could trigger when the output item changes on/off.
- The input channel represents the on/off status of the SW connector. In switch mode this corresponds to the on/off state of the input Atem. In momentary button mode you get on top the push events (short, long, 2xs etc)
Ig you disable Coap, enable the action urls and donât see the url registration in the DEBUG log something is wrong. Please provide the log extract showing the complete thing initialization.
Voltage reading from Shelly1PM and Shelly 2.5.
I would like to monitor the current (not just power) from these devices. The voltage is available in the Shelly UI (and the binding has it available in the EM) but the binding doesnât make it available. Is there any possibility of including it?
Iâd also like a bit more granularity in the RSSI value. Again the dBm value is available in the UI but the binding only gives 0-4
This is not available, one reason for the EM
No plans
Sorry, itâs my fault: i have textual config files and defined the things with their domainnames. After changing the Shelly to a static IPs it is required to restart the dns-server (Fritzbox in my case). Otherwise the dns-server answered with wrong IPs and therefor the binding canât work.
Is there a list what Shelly devices are supported in what version of the shelly binding. I have OH 2.5 but that version is not supporting the Shelly button 1 and the window sensor.
Is shelly motion integrated in the last snapshot for 2.5?
Greets
Just got the new Shelly Bulb RGBW GU10 . OpenHAB is detecting it (PaperUI/inbox), but shows as âshelly:shellyunknownâ under device. Realise this is a very new device, anything information i can post to help integration of this new device? (I.e. information i can provide given that i have the bulb that will help).
Quick data point: i manually configured the âThingâ using âshelly:shellybulb:xxxâ and this seems to work. The binding doesnât detect the GU10 as a âshellybulbâ, but it seems to use the same commands.
you habe to switch to the DEV build, the release version is based on OH 2.5. There is no way to get additional features into that stream. The DEV build is pretty sable
Check README for a list of supported devices
â
Latest DEV build: 2.5.13 - 3.1.0 - README - Installation - Bugs/Features - Firmware Index - Firmware Archive - API Doc
Note: The binding version included in the final OH 3.0 distro is significantly older than the DEV build. I canât make it in-time. Make sure you deleted older versions of the binding when installing the 2.5.13-SNAPSHOT or 3.1.0-SNAPSHOT if you are already on OH 3.
same; switch fi the DEV build, G10 is supported
same for Shelly Motion
added today my new ShellyMotion (OH3.1M1, Shelly Dev-Binding)
Log says Firmware too old - but device is already on latest firmware.
Maybe a small bug or improvement for/within the binding, Markus?
[WARN ] [y.internal.handler.ShellyBaseHandler] - shellymotionsensor-60a4XXXXXX: WARNING: Firmware might be too old, installed: v1.0.3/20210211-193341 (770a8cb1), required minimal v1.5.7.
latest firmware for Motion is 1.0.4, Iâm not site if this is in the official repo, let me know
ok, itâs simpel
Motion is a completely new firmware starting with 1.0.x and this is of course < 1.5.7
Let me check if I could detect the hardware generation and then allow 1.0+
I updated the DEV build, please check
Hi Markus,
Thanks for your perfect information.
It is working fine.
