the thing isnât protected by password,
where can i find the log?
is this enough info:
23:01:35.439 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly4pro-4d02ec: Status update triggered thing initialization
23:01:35.441 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly4pro-4d02ec: Start initializing thing shelly4pro-4d02ec, type shelly4pro, ip address 192.168.0.212, CoIoT: true
23:01:35.442 [TRACE] [ing.shelly.internal.api.ShellyHttpApi] - shelly4pro-4d02ec: HTTP GET for http://192.168.0.212/shelly
23:01:35.756 [TRACE] [ing.shelly.internal.api.ShellyHttpApi] - shelly4pro-4d02ec: HTTP Response 200: {"type":"SHSW-44","mac":"E415F64D02EC","auth":false,"fw":"20201019-110845/v1.6.6_4Pro@bad181e4","num_outputs":4, "num_meters":4, "num_rollers":0}
23:01:35.758 [TRACE] [ing.shelly.internal.api.ShellyHttpApi] - shelly4pro-4d02ec: HTTP GET for http://192.168.0.212/settings
23:01:36.147 [TRACE] [ing.shelly.internal.api.ShellyHttpApi] - shelly4pro-4d02ec: HTTP Response 200: {"device":{"type":"SHSW-44","mac":"E415F64D02EC","hostname":"shelly4pro-4D02EC","num_outputs":4, "num_meters":4, "num_rollers":0},"wifi_ap":{"enabled":false,"ssid":"shelly4pro-4D02EC","key":""},"wifi_sta":{"enabled":true,"ssid":"Home_WIFI","ipv4_method":"static","ip":"192.168.0.212","gw":"192.168.0.1","mask":"255.255.255.0","dns":"8.8.8.8"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.0.172:1883","user":"jeroenvdd","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"will_topic":"shellies/shelly4pro/online","will_message":"false","max_qos":0,"retain":false,"update_period":30},"sntp": {"server":"time.google.com"},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"IrwKzy","coiot_execute_enable":true,"name":"","fw":"20201019-110845/v1.6.6_4Pro@bad181e4","build_info":{"build_id":"20201019-110845/v1.6.6_4Pro@bad181e4","build_timestamp":"2020-10-19T11:08:45Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":"Europe/Brussels","lat":50.860149,"lng":4.358050,"tzautodetect":true,"time":"23:01","hwinfo":{"hw_revision":"prod-2020-04-24","batch_id":1},"lat":50.860149,"lng":4.358050,"relays":[{"name":null,"ison":false,"has_timer":false,"overpower":false,"default_state":"off","btn_type":"toggle","auto_on":0.00,"auto_off":0.00,"max_power":2300,"schedule":false,"schedule_rules":[]},{"name":null,"ison":false,"has_timer":false,"overpower":false,"default_state":"off","btn_type":"toggle","auto_on":0.00,"auto_off":0.00,"max_power":2300,"schedule":false,"schedule_rules":[]},{"name":null,"ison":false,"has_timer":false,"overpower":false,"default_state":"off","btn_type":"toggle","auto_on":0.00,"auto_off":0.00,"max_power":2300,"schedule":false,"schedule_rules":[]},{"name":null,"ison":false,"has_timer":false,"overpower":false,"default_state":"off","btn_type":"toggle","auto_on":0.00,"auto_off":0.00,"max_power":2300,"schedule":false,"schedule_rules":[]}],"meters":[{"power":0.0,"is_valid":true,"timestamp":1614466897,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.0,"is_valid":true,"timestamp":1614466897,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.0,"is_valid":true,"timestamp":1614466897,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.0,"is_valid":true,"timestamp":1614466897,"counters":[0.000, 0.000, 0.000],"total":0}]}
23:01:36.158 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly4pro-4d02ec: Initializing device shelly4pro-4d02ec, type SHSW-44, Hardware: Rev: prod-2020-04-24, batch 1; Firmware: v1.6.6_4Pro / 20201019-110845 (bad181e4)
23:01:36.160 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly4pro-4d02ec: Shelly settings info for shelly4pro-4d02ec: {"device":{"type":"SHSW-44","mac":"E415F64D02EC","hostname":"shelly4pro-4D02EC","num_outputs":4, "num_meters":4, "num_rollers":0},"wifi_ap":{"enabled":false,"ssid":"shelly4pro-4D02EC","key":""},"wifi_sta":{"enabled":true,"ssid":"Home_WIFI","ipv4_method":"static","ip":"192.168.0.212","gw":"192.168.0.1","mask":"255.255.255.0","dns":"8.8.8.8"},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt": {"enable":false,"server":"192.168.0.172:1883","user":"jeroenvdd","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"will_topic":"shellies/shelly4pro/online","will_message":"false","max_qos":0,"retain":false,"update_period":30},"sntp": {"server":"time.google.com"},"login":{"enabled":false,"unprotected":false,"username":"admin","password":"admin"},"pin_code":"IrwKzy","coiot_execute_enable":true,"name":"","fw":"20201019-110845/v1.6.6_4Pro@bad181e4","build_info":{"build_id":"20201019-110845/v1.6.6_4Pro@bad181e4","build_timestamp":"2020-10-19T11:08:45Z","build_version":"1.0"},"cloud":{"enabled":false,"connected":false},"timezone":"Europe/Brussels","lat":50.860149,"lng":4.358050,"tzautodetect":true,"time":"23:01","hwinfo":{"hw_revision":"prod-2020-04-24","batch_id":1},"lat":50.860149,"lng":4.358050,"relays":[{"name":null,"ison":false,"has_timer":false,"overpower":false,"default_state":"off","btn_type":"toggle","auto_on":0.00,"auto_off":0.00,"max_power":2300,"schedule":false,"schedule_rules":[]},{"name":null,"ison":false,"has_timer":false,"overpower":false,"default_state":"off","btn_type":"toggle","auto_on":0.00,"auto_off":0.00,"max_power":2300,"schedule":false,"schedule_rules":[]},{"name":null,"ison":false,"has_timer":false,"overpower":false,"default_state":"off","btn_type":"toggle","auto_on":0.00,"auto_off":0.00,"max_power":2300,"schedule":false,"schedule_rules":[]},{"name":null,"ison":false,"has_timer":false,"overpower":false,"default_state":"off","btn_type":"toggle","auto_on":0.00,"auto_off":0.00,"max_power":2300,"schedule":false,"schedule_rules":[]}],"meters":[{"power":0.0,"is_valid":true,"timestamp":1614466897,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.0,"is_valid":true,"timestamp":1614466897,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.0,"is_valid":true,"timestamp":1614466897,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.0,"is_valid":true,"timestamp":1614466897,"counters":[0.000, 0.000, 0.000],"total":0}]}
23:01:36.161 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly4pro-4d02ec: Device hasRelays:true (numRelays=4),isRoller:false (numRoller=0),isDimmer:false,numMeter=4,isEMeter:false),isSensor:false,isDS:false,hasBattery:false,isSense:false,isMotion:false,isLight:false,isBulb:false,isDuo:false,isRGBW2:false,inColor:false,alwaysOn:true, ,updatePeriod:70sec
23:01:36.163 [TRACE] [ing.shelly.internal.api.ShellyHttpApi] - shelly4pro-4d02ec: HTTP GET for http://192.168.0.212/status
23:01:36.407 [TRACE] [ing.shelly.internal.api.ShellyHttpApi] - shelly4pro-4d02ec: HTTP Response 200: {"wifi_sta":{"connected":true,"ssid":"Home_WIFI","ip":"192.168.0.212","rssi":-49},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"23:01","serial":2,"has_update":false,"mac":"E415F64D02EC","relays":[{"ison":false,"has_timer":false,"overpower":false,"is_valid":true},{"ison":false,"has_timer":false,"overpower":false,"is_valid":true},{"ison":false,"has_timer":false,"overpower":false,"is_valid":true},{"ison":false,"has_timer":false,"overpower":false,"is_valid":true}],"meters":[{"power":0.0,"is_valid":true,"timestamp":1614466898,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.0,"is_valid":true,"timestamp":1614466898,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.0,"is_valid":true,"timestamp":1614466898,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.0,"is_valid":true,"timestamp":1614466898,"counters":[0.000, 0.000, 0.000],"total":0}],"inputs":[{"input":0},{"input":0},{"input":0},{"input":0}],"update":{"status":"idle","has_update":false,"new_version":"20201019-110845/v1.6.6_4Pro@bad181e4","old_version":"20201019-110845/v1.6.6_4Pro@bad181e4"},"ram_total":47372,"ram_free":18692,"fs_size":83081,"fs_free":17821,"uptime":35483}
23:01:36.409 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly4pro-4d02ec: Update properties
23:01:36.411 [DEBUG] [ly.internal.handler.ShellyBaseHandler] - shelly4pro-4d02ec: Unable to refresh status: Unable to update status
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.initializeThing(ShellyBaseHandler.java:265) ~[bundleFile:?]
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.refreshStatus(ShellyBaseHandler.java:381) [bundleFile:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
Did some extra testing reverted to:
208 â Active â 80 â 3.1.0.202102220729 â openHAB Add-ons :: Bundles :: Shelly Binding
and everything works again
