Thanks for the tip.
For what is worth I made it work, it was a simple as creating a Thing with a switch and a color channel, for the switch one set the “Custom On/Open value” to “on” (lowercase) and the off/closed to “off”.
Then for the switch one, incoming transformation: JS:shelly_bulb_switch_input.js
For the color one, incoming: JS:shelly_bulb_color_input.js and outgoing: JS:shelly_bulb_color_output.js.
Then just create the files in transformation:
JS:shelly_bulb_switch_input.js:
(function(i) {
shellyInput = JSON.parse(i);
return shellyInput.ison ? "on" : "off";
})(input)
JS:shelly_bulb_color_input.js:
(function(i) {
return shellyInput.red + "," + shellyInput.green + "," + shellyInput.blue;
})(input)
JS:shelly_bulb_color_output.js:
(function(i) {
var rgb = i.split(",");
shellyOutput = {
"ison": true,
"mode": "color",
"red": rgb[0],
"green": rgb[1],
"blue": rgb[2]
return JSON.stringify(shellyOutput);
})(input)
All this of course using the version @David_Graeff mentioned. I upgraded with a simple sudo openhabian-config to change to the testing channel.
I know this is cumbersome and it would me ten times better to have homie support, but at least its better than nothing.
