- Platform information:
- Hardware: J4125/RAM 8gb /128gb ssd
- OS: Linux Openhab123 5.19.0-46-generic #47-Ubuntu SMP PREEMPT_DYNAMIC Fri Jun 16 13:30:11 UTC 2023 x86_64 GNU/Linux
- Java Runtime Environment: openjdk version “11.0.17” 2022-10-18
OpenJDK Runtime Environment Temurin-11.0.17+8 (build 11.0.17+8)
OpenJDK 64-Bit Server VM Temurin-11.0.17+8 (build 11.0.17+8, mixed mode) - openHAB version: 3.4.1
- Issue of the topic: please be detailed explaining your issue
I have a Shelly Flood (firmware: 20230913-112632/v1.14.0-gcb84623) connected via binding to Openhab 3.4.1. After some time the Shelly status changes to ERROR:COMM, device isn’t available or not responding. When I simulate a water alarm I don’t get an error message to my telegram.
This is the script I’m using:
var ScriptExecution = Java.type(“org.openhab.core.model.script.actions.ScriptExecution”);
var telegramAction = actions.get(“telegram”, “telegram:telegramBot:xxxxxxxxxxxxxxxx”)
if (itemRegistry.getItem(‘Shelly_Flood_Feuchtigkeitsalarm’).getState() == ‘ON’)
telegramAction.sendTelegram(“Shelly Flood: Water!”)
When I change ON against OFF and execute the script manually an alarm is send to telegram.
Do you have any idea what I’m doing wrong?
Thanks in advance.
