Good morning (o;
Have a Shelly Pro 4PM relay switch here and installed the Shelly binding…
Discovery of the device doesn’t work when doing a “Scan”…but when adding the device manually with its IP address I get in the logs:
2022-11-09 11:52:47.216 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.initializeThing(ShellyBaseHandler.java:226) ~[?:?]
at org.openhab.binding.shelly.internal.handler.ShellyBaseHandler.lambda$0(ShellyBaseHandler.java:160) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
And the Shelly is then listed with “Configuration pending”:
Is this Shelly binding not compatible with the Pro 4PM?
I assume my ordered 3EM will also not work then…
