Hi. I’d like to have smooth transitions from one state (e.g. low brightness or off or red-color) to another ( high brightness, another color).
Currently, that is not “built-in”. Change color/brightness will do that “immediately”.
A workaround is to use OpenHab code and send a lot of http requests to each target-shelly with changing states (flooding the log etc).
Another approach (which I would prefer) is to have a transition timer built into the device. It is available in the Shelly dimmer, but not in the RGBW2.
I contacted the Shelly Support, but it seems this topic has not been added to the feature-list because people don’t think to need it.
How is it for you guys, don’t you need that?
If this thread becomes some love(likes), this might convince the developers@Shelly to add a transition timer to the feature list.
Best regards
PhiL
