Hello Community,
I have the following setup:
I have a shelly that turns on a light for me. I can also switch on the light directly at the Shelly. Furthermore, I can also switch on the light via KNX.
If I now switch the light via KNX or via OpenHAB, the status of the light is updated cleanly. However, if I use the switch that is connected directly to the Shelly, the status of the light is only correct in OpenHAB. However, the status change is not changed via KNX. How can I change this?
Here is my script:
Things:
#in KNX.things
Type switch-control : SKinderzimmer1 "Kinderzimmer 1 | Steckdose Nachttischt" [ga="24/6/59+24/6/159"]
#in shelly.things
Thing shelly:shelly1:SRelay3 "Shelly Nachttischlicht" @ "Kinderzimmer1" [deviceIp="123.456.789.1", userId="user", password="Geheim", eventsCoIoT=false]
Item:
Switch KNX_S_Kinderzimmer1 "Kinderzimmer 1 | Nachttischlampe[%s]" <light>{ channel="shelly:shelly1:SRelay3:relay#output", channel="knx:device:bridge:generic:SKinderzimmer1" }
Thank you for every hint.
