ShellyRelayHandler tried updating the thing status although the handler was already disposed
  • Platform information:
    OH is running in a docker container.
    CleanShot 2024-10-06 at 16.45.12@2x
  • Issue of the topic: please be detailed explaining your issue
The kitchen lights (via a Shelly 2PM) can no longer be controlled via openHAB (nu problem via the Shelly App or the Devices own web-UI).
The thing is shown as online with no apparent problem:
CleanShot 2024-10-06 at 16.36.37@2x
But when I switch the power on or off the item state is updated but the state does not correspond to reality, i.e. the light isn’t switched.
CleanShot 2024-10-06 at 16.39.26@2x
  • If logs where generated please post these here using code fences:
Everytime I attempt to switch the light as described above, the following log is produced in openhab.log
2024-10-06 16:46:30.961 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler ShellyRelayHandler tried updating the thing status although the handler was already disposed.
The OH configuration has not ben modified for months and the light has always been working fine,
I had the same error message from a different binding. A clean-cache and server restart helped.
Yes, restarting the server helped. But it does not remove the root cause. Do you have any idea what might causing this?
Unfortunately not
