Hmmmm, i think thats not the expecting result
Any ideas?
Any ideas?
Problem seems to be solved, patience was the key
But the sun position is not correct, i think its because of a wrong shape of the house. How do you create it? The basic form is correct, but it seems to be inverted. How do i align the shape correctly?
Edit: Problem solved…
@pmpkk I have to give you a really big “Thank You” for your great theme and this script
Would you be so kind to tell my how and where in the shaddow.py you inserted the icons?
Needs to be Sun_Elevation
I do not use hab panel yet but I want to add exactly this once I have my habpanel set up.
But in additon to that…what I currently try to do is to automate my rollershutters and I think it could be possible to realize with parts of your script.
What I wan to do is the following:
I want to automatically close the rollershutters if the sun is shining through the window.
So my question is how can I use this script to achive this? Could you lead me the right way ? I am quite new to python code and do not understand much of it.
kind regards,
salexes
All you need for that task is the azimuth angle from the astro binding:
Eventuell hilft das:
var Number diffToFasade = 30 // Quasi Abweichung von Nord deiner Hausausrichtung
rule "Update Fassade"
Item Sun_Height_ext changed or
Item Sun_Azimut_ext changed
logDebug("Sun","Update Fassade")
var height = Sun_Height_ext.state
var azimut = Sun_Azimut_ext.state
var eastFasadeIn = ( 90 - 90 + diffToFasade ) //For example: -26.09 or 333,91 - because 0 and 360 is north
var eastFasadeOut = ( 90 + 90 + diffToFasade ) //153,91
var southFasadeIn = ( 180 - 90 + diffToFasade ) //63,91
var southFasadeOut = ( 180 + 90 + diffToFasade ) //243,91
var westFasadeIn = ( 270 - 90 + diffToFasade ) //153,91
var westFasadeOut = ( 270 + 90 + diffToFasade ) //333,9
var northFasadeIn = ( 360 - 90 + diffToFasade ) //243,91
var northFasadeOut = ( 360 + 90 + diffToFasade ) //386,09 or 63,91 - because 360 and 0 is north
postUpdate(Sun_Fasade_Illum_East, if (azimut > (eastFasadeIn.remainder(360)) && azimut < (eastFasadeOut.remainder(360)) && height > 18) ON else OFF)
postUpdate(Sun_Fasade_Illum_South, if (azimut > (southFasadeIn.remainder(360)) && azimut < (southFasadeOut.remainder(360)) && height > 18) ON else OFF)
postUpdate(Sun_Fasade_Illum_West, if (azimut > (westFasadeIn.remainder(360)) && azimut < (westFasadeOut.remainder(360)) && height > 18) ON else OFF)
postUpdate(Sun_Fasade_Illum_North, if (azimut > (northFasadeIn.remainder(360)) && azimut < (northFasadeOut.remainder(360)) && height > 18) ON else OFF)
Auf die Änderungen der Sun_Fassade_Illum_* wird dann jeweils in einer Regel der/die Rolläden gefahren.
Same here …
How did you solve it?
I “inverted” my y-coordinate
100 - your “y” and then insert this into the shaddow.py
As others have said in order to manage your shutters you really just need to check the sun azimuth and elevation. I do this for my shutters and it works perfectly all year round!
Cheers,
Patrick
Thx, that’s it!
I had some free time and started to play around with Habpanel. I installed the scripts and created the plot of my house shape two days ago and let it run to build up a persistence history (used the code to use OpenHAB persistence). This morning, I added the widget and am not getting it to work, I am getting just a blank space on the panel where the widget should be.
This is what I am seeing in my log:
2018-01-27 08:42:32.991 [INFO ] [lipse.smarthome.model.script.Shaddow] - Successfully got state from OpenHab: Sun_Azimuth
Successfully got state from OpenHab: Sun_Elevation
Successfully got state from OpenHab: Sunrise_Azimuth
Traceback (most recent call last):
File "/etc/openhab2/scripts/shaddow.py", line 249, in <module>
main()
File "/etc/openhab2/scripts/shaddow.py", line 235, in main
s = shaddow()
File "/etc/openhab2/scripts/shaddow.py", line 44, in __init__
self.sunrise_azimuth = float(self.oh.getState('Sunrise_Azimuth'))
ValueError: could not convert string to float: NULL
I had the same problem (among others). What is your item persistence like? Is the Sunrise_Azimuth rule being fired? The error is saying the item value is NULL, not a nice numerical value it can easily convert to a float.
Looks like it is running successfully, and this error went away, but now I am getting errors like:
2018-01-29 07:20:19.912 [INFO ] [lipse.smarthome.model.script.Shaddow] - Successfully got state from OpenHab: Sun_Azimuth
Successfully got state from OpenHab: Sunset_Azimuth
Successfully got data from Persistence
328.2649999999999863575794734060764312744140625
File "/etc/openhab2/scripts/shaddow.py", line 250, in <module>
main()
File "/etc/openhab2/scripts/shaddow.py", line 244, in main
s.generateSVG()
File "/etc/openhab2/scripts/shaddow.py", line 218, in generateSVG
svg = svg + self.generatePath(LIGHT_COLOR,'none',[self.degreesToPoint(DEGS[0],WIDTH/2+5), self.degreesToPoint(DEGS[0],WIDTH/2+11)])
File "/etc/openhab2/scripts/shaddow.py", line 103, in degreesToPoint
d2 = 180 - d
TypeError: unsupported operand type(s) for -: 'int' and 'unicode'
I am new to python so I am looking at the shadow.py in Atom. I didn’t change the shadow.py file except to add the code for the OpenHAB REST persistence call, which appears to be working. I am still showing my shaddow.svg as a 0 kb sized file.
The error indicates that you are subtracting a int with text, which is off course impossible.
I also you previously had an issue with the conversion of string to float.
I guess the problem is originating from OpenHAB.
EDIT: The problem must occur while getting the persistence data from the influx database since the value of DEGS[0] is not numeric.Can you check the data that is in your database?
Greetings,
Frederic
Thanks Frederic, I appreciate you taking the time to look at my issue. Right now, I am getting these values from OpenHAB:
Sunrise Azimuth = 114
Sunset Azimuth = 244.9900000000000090949470177292823791503906…
Sun Azimuth = 128.23 °
Sun Elevation = 11.49 °
I am pulling the data from the OpenHAB Persistence, not from Influx (I would prefer not to use influx, just don’t like it). I am guessing that the problem lies with the Sunset Azimuth, but I don’t know why that would be pulling so many decimal position…
and
Sihui,
I copied the code provided by Schmidmuc, and used his implementation for using OpenHAB persistence instead of Influx. I made the relevant changes to the code (only changing the names form SonnenaufgangAzimuth to Sunrise_Azimuth and SonnenuntergangAzimuth to Sunset_Azimuth)
If the returned value from OpenHAB contains the degrees symbol in it then that will be the issue since parsing that to a float will definitely fail.
I would also double check the data you get while querying OpenHAB for the hostorical states.
Maybe add a print after every fetch so you get this:
for h in xrange(0,24,HOURS):
t = datetime.combine(date.today(), datetime.min.time()) + timedelta(hours=-utc_offset+h-24)
tt = datetime.combine(date.today(), datetime.min.time()) + timedelta(hours=-utc_offset+h-23)
a = self.oh.getStateHistoryFromPersistence('Azimuth',t.strftime('%Y-%m-%dT%H:%M:%S') + 'Z',tt.strftime('%Y-%m-%dT%H:%M:%S') + 'Z')
if (a == None): a = 0
DEGS.extend([a])
print str(a)
When you see the result of the print it should become clear that there probably is a non-numerical character in the result.
