I’m in the middle of migrating from OH 2.5 to OH 3.2 and started playing around with the custom widgets.
Now I would like to build a simple widget just showing the state of an item, where the state can have up to five different values, e.g:
Raining: true, false
Heating Status: comfort, standby, night
Home Status: home, sleeping, away, holiday
etc.
My goal is to have one widget, where I can set different icons (up to five) depending on values also given in props, e.g.:
home status = “home”, show icon “house” in color “green”
What’s working right now is to set an icon visible/not visible when I check against a given value in the widget code like:
- component: oh-icon
icon: =props.icon_1_name
visible: "=(items[props.item_name].state === 'home') ? true : false"
style:
color: =props.icon_1_color
Now, to get the things a bit more configurable, I would like to check against the value of a prop, like
visible: "=(items[props.item_name].state === props.item_value_1) ? true : false"
style:
where e.g. item_value_1 is set to “home” in props.
The second code snipped is not working…
Is this possible?
Any hint would be great.
Thanks a lot in advance.
