The states are written to all different tables every minute, i checked that in the database. Now i want to show a chart with the temperature in the livingroom during the last 24h.
My items file contains this:
Number Temp_Wohnzimmer_akt “Ist-Temperatur [%.1f °C]” (EG_Wohnzimmer) {homematic=“address=MEQ1812709,channel=4, parameter=ACTUAL_TEMPERATURE”}
Which gives the correct current temperature, shown in the sitemap and also written to database. In the sitemap this looks like:
When using rrd4j you can indeed list the items with commas separating them but you would put the chart on your sitemap using an Image element, not a Chart element. But when using the Chart element you can only provide one Item at a time. If you need more than one Item in the chart, you must put those Items into a Group and use the Group as the “item=”.
You set the default persistence in openhab.cfg near the top. The parameter is persistence:default and it should be set to mysql. Otherwise you would add a “service=mysql”.
Thanks for your answer.
I changed the persistence line
The name of the default persistence service to use
persistence:default=mysql
The mysql location looks like this:
############################ SQL Persistence Service ##################################
the database url like ‘jdbc:mysql://:/’ (without quotes)
mysql:url=jdbc:mysql://192.168.0.17/openhab
the database user
mysql:user=openhab
the database password
mysql:password=openhab
the reconnection counter
#mysql:reconnectCnt=
the connection timeout (in seconds)
#mysql:waitTimeout=
OpenHAB is still writing all items to the database but I could not show any historical data in a chart. I removed the comma seperation, it should now show only one data set. For a first test this would be fine.
