I’ve setup simple rule to change my current Voltage value returned from KNX from mV to V. So, it’s just dividing the Voltage value by 1000 and update new item with that new value.
However, I don’t see that this rule is fired at all. No log info etc.
Here is my rule:
rule "Voltage calculation" //divide by 1000 for better visualization
//Item Bus_Voltage received update
Time cron "0 */5 * * * ?"
var Number Volt = Bus_Voltage.state as DecimalType
var Number xx = Volt/1000
postUpdate(Bus_Voltage_Visu, xx)
logInfo("Rules", "Voltage value updated to: "+Bus_Voltage_Visu.state)
and items:
Number Bus_Voltage "Napięcie [%.1f V]" <voltage> (Power) {knx="10/0/3"}
Number Bus_Voltage_Visu "Napięcie [%.1f V]" <voltage> (Power)
I see that original voltage value in mV is coming from KNX and gets updated correctly for Bus_Voltage item:
2017-03-08 14:18:57.619 [DEBUG] [.binding.knx.internal.bus.KNXBinding] - Wrote value ‘29941.760000000002’ to datapoint ‘command DP 10/0/3 Bus_Voltage, DPT main 0 id 9.001, low priority’
I tried your code (with changed items to fit my system) like this:
Item E10_1 received update or Time cron "0 */5 * * * ?"
var Number Volt = E10_1.state as DecimalType
postUpdate(TestNumber, xx)
logInfo("Rules", "Voltage value updated to: "+TestNumber.state)
and I’m getting this log:
19:06:01.373 [INFO ] [eclipse.smarthome.model.script.Rules] - Voltage value updated to: 0.00129900
Exactly. This was it. I see it’s impossible to declare variables in other places in .rules file than on top of it.
I had the earlier rule with 2 variables defined like:
var Number counter = 0
var Number lastCheck = 0
I moved them to top of the file and see that problem is gone.
