Dear,
I am currently getting to know OpenHab2.
One of the first things to do was to try to get a notification working with a humidity sensor (a Devolo MT02755).
The rule that I set up - being based on a sample out of this community - is
// This rule file is autogenerated by HABmin.
// Any changes made manually to this file will be overwritten next time HABmin rules are saved.
// Imports
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
// Global Variables
var lastSent = null
rule "Feuchte Kellergang"
Item zwave_device_5e813456_node4_sensor_relhumidity received update
if(lastSent == null || lastSent.before(now.minusMinutes(10))) {
if (zwave_device_5e813456_node4_sensor_relhumidity.state > 70)
sendTelegram("bot1", "Luftfeuchtigkeit im Kellergang > 70%", zwave_device_5e813456_node4_sensor_relhumidity.state.toString)
lastSent = now
I hoped to have it done in the right way, but looking at the logs, I find the following errors:
2017-11-05 14:20:36.760 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'meldung_feuchte_kelgal.rules'
2017-11-05 16:45:59.095 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 4: Already processed another send data request for this callback Id, ignoring.
2017-11-05 16:46:09.133 [ERROR] [.script.engine.ScriptExecutionThread] - Rule 'Feuchte Kellergang': Conversion = '%'
So seemingly, something is tried to be converted, but I do not know what and why - and most important how to deal with it.
Thank you for your help,
best regards,
Connor
