Simple Selection Widget up to 11 buttons (or more)
I have always liked the simplicity of the selection tool used in sitemaps, and wanted a similar Main UI widget for use in lists. Using the visible property, the buttons are only visible if you populate the value to be displayed. Like sitemap mapping, just add commands and display values. I chose 11 buttons as I often set dimmers this way (see below), but more can be added, and of course you can use less than 11. There is likely a better way to do this, still looking…
Screenshots
Changelog
Version 0.3
  • added dynamic icon
Version 0.2
  • added options for color, active color, and active text color
Version 0.1
  • initial release
Resources
uid: Selection New
tags: []
props:
  parameters:
    - description: The name to show
      label: Title
      required: false
      type: TEXT
    - context: item
      description: An item to control
      label: Item
      required: false
      type: TEXT
    - description: Icon name only OH supported
      label: Icon
      required: false
      type: TEXT
    - description: Color of selection widget (blank=default)
      label: Color
      required: false
      type: TEXT
    - description: Color of selection widget fill when button is selected (blank=default)
      label: Active Color
      required: false
      type: TEXT
    - description: Color of text when button is selected (blank=default/white)
      label: Active Text Color
      required: false
      type: TEXT
    - description: The Button 1 command
      label: Button 1 Command
      required: false
      type: TEXT
    - description: The Button 1 value
      label: Button 1 Value
      required: false
      type: TEXT
    - description: The Button 2 command
      label: Button 2 Command
      required: false
      type: TEXT
    - description: The Button 2 value
      label: Button 2 Value
      required: false
      type: TEXT
    - description: The Button 3 command
      label: Button 3 Command
      required: false
      type: TEXT
    - description: The Button 3 value
      label: Button 3 Value
      required: false
      type: TEXT
    - description: The Button 4 command
      label: Button 4 Command
      required: false
      type: TEXT
    - description: The Button 4 value
      label: Button 4 Value
      required: false
      type: TEXT
    - description: The Button 5 command
      label: Button 5 Command
      required: false
      type: TEXT
    - description: The Button 5 value
      label: Button 5 Value
      required: false
      type: TEXT
    - description: The Button 6 command
      label: Button 6 Command
      required: false
      type: TEXT
    - description: The Button 6 value
      label: Button 6 Value
      required: false
      type: TEXT
    - description: The Button 7 command
      label: Button 7 Command
      required: false
      type: TEXT
    - description: The Button 7 value
      label: Button 7 Value
      required: false
      type: TEXT
    - description: The Button 8 command
      label: Button 8 Command
      required: false
      type: TEXT
    - description: The Button 8 value
      label: Button 8 Value
      required: false
      type: TEXT
    - description: The Button 9 command
      label: Button 9 Command
      required: false
      type: TEXT
    - description: The Button 9 value
      label: Button 9 Value
      required: false
      type: TEXT
    - description: The Button 10 command
      label: Button 10 Command
      required: false
      type: TEXT
    - description: The Button 10 value
      label: Button 10 Value
      required: false
      type: TEXT
    - description: The Button 11 command
      label: Button 11 Command
      required: false
      type: TEXT
    - description: The Button 11 value
      label: Button 11 Value
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Jan 13, 2023, 8:57:14 AM
component: oh-list-item
  icon: =props.icon
  title: =props.thetitle
  iconUseState: true
  item: =props.item
slots:
  after:
    - component: f7-segmented
        color: =props.color
        style:
          display: inline-flex
          flex-direction: row
          justify-content: flex-end
      slots:
        default:
          - component: oh-button
              action: command
              actionCommand: =props.commandbutton1
              actionItem: =props.item
              active: "=(items[props.item].state === props.commandbutton1) ? true : false"
              color: "=(items[props.item].state === props.commandbutton1) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton1
              text-color: "=(items[props.item].state === props.commandbutton1) ? props.activetextcolor : ''"
              visible: "=props.valuebutton1 ? true : false"
              action: command
              actionCommand: =props.commandbutton2
              active: "=(items[props.item].state === props.commandbutton2) ? true : false"
              color: "=(items[props.item].state === props.commandbutton2) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton2
              text-color: "=(items[props.item].state === props.commandbutton2) ? props.activetextcolor : ''"
              visible: "=props.valuebutton2 ? true : false"
              action: command
              actionCommand: =props.commandbutton3
              active: "=(items[props.item].state === props.commandbutton3) ? true : false"
              color: "=(items[props.item].state === props.commandbutton3) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton3
              text-color: "=(items[props.item].state === props.commandbutton3) ? props.activetextcolor : ''"
              visible: "=props.valuebutton3 ? true : false"
              action: command
              actionCommand: =props.commandbutton4
              active: "=(items[props.item].state === props.commandbutton4) ? true : false"
              color: "=(items[props.item].state === props.commandbutton4) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton4
              text-color: "=(items[props.item].state === props.commandbutton4) ? props.activetextcolor : ''"
              visible: "=props.valuebutton4 ? true : false"
              action: command
              actionCommand: =props.commandbutton5
              active: "=(items[props.item].state === props.commandbutton5) ? true : false"
              color: "=(items[props.item].state === props.commandbutton5) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton5
              text-color: "=(items[props.item].state === props.commandbutton5) ? props.activetextcolor : ''"
              visible: "=props.commandbutton5 ? true : false"
              action: command
              actionCommand: =props.commandbutton6
              active: "=(items[props.item].state === props.commandbutton6) ? true : false"
              color: "=(items[props.item].state === props.commandbutton6) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton6
              text-color: "=(items[props.item].state === props.commandbutton6) ? props.activetextcolor : ''"
              visible: "=props.commandbutton6 ? true : false"
              action: command
              actionCommand: =props.commandbutton7
              active: "=(items[props.item].state === props.commandbutton7) ? true : false"
              color: "=(items[props.item].state === props.commandbutton7) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton7
              text-color: "=(items[props.item].state === props.commandbutton7) ? props.activetextcolor : ''"
              visible: "=props.commandbutton7 ? true : false"
              action: command
              actionCommand: =props.commandbutton8
              active: "=(items[props.item].state === props.commandbutton8) ? true : false"
              color: "=(items[props.item].state === props.commandbutton8) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton8
              text-color: "=(items[props.item].state === props.commandbutton8) ? props.activetextcolor : ''"
              visible: "=props.commandbutton8 ? true : false"
              action: command
              actionCommand: =props.commandbutton9
              active: "=(items[props.item].state === props.commandbutton9) ? true : false"
              color: "=(items[props.item].state === props.commandbutton9) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton9
              text-color: "=(items[props.item].state === props.commandbutton9) ? props.activetextcolor : ''"
              visible: "=props.commandbutton9 ? true : false"
              action: command
              actionCommand: =props.commandbutton10
              active: "=(items[props.item].state === props.commandbutton10) ? true : false"
              color: "=(items[props.item].state === props.commandbutton10) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton10
              text-color: "=(items[props.item].state === props.commandbutton10) ? props.activetextcolor : ''"
              visible: "=props.commandbutton10 ? true : false"
              action: command
              actionCommand: =props.commandbutton11
              active: "=(items[props.item].state === props.commandbutton11) ? true : false"
              color: "=(items[props.item].state === props.commandbutton11) ? props.activecolor : ''"
              outline: true
              style:
                height: auto
                width: auto
              text: =props.valuebutton11
              text-color: "=(items[props.item].state === props.commandbutton11) ? props.activetextcolor : ''"
              visible: "=props.commandbutton11 ? true : false"
Cool! :slight_smile:
Small improvement:
icon: =props.icon
iconUseState: true
item: =props.item
Then we have dynamic icon.
Thanks for that. Added.
