Hi guys,
I noticed a simple problem on setting up a Setpoint in sitemap in my example for a temperature switch. Example:
Setpoint item=wz_wt_setTmp minValue=10 maxValue=22 step=0.5
No further rules, no complicated setup. A simple Item:
Number wz_wt_setTmp "Solltemperatur [%.1f °C]" <temperature> (wz) {channel="homematic:HG-HM-TC-IT-WM-W-EU:03ac69b4:OEQ1674380:2#SET_TEMPERATURE"}
Now, when clicking up or down arrows the Temperature is NOT changed on every click, instead I need 6-8 clicks to change from 18°C to 20°C. It depends a little on the speed klicking up or down.
After that it is possible that the binded Thermostat has not the 20°C, instead has 20.5°C .
The reason for this is easy found: on every click on a up or down arrow an http request from the UI is fired immediatelly. Think this is simply too much requests in a short time causing this problem. I also found in the log that sometimes the given “commands” are simply fired twice (see below), I think its a reason of the many http requests.
In my Opinion this is a problem with the Setpoint functionality, but is there anyone facing the same problem or anyone having an idea to fix this? For example giving the Setpoint Feature a little “delay” before triggering a http request.
Thanks for any comment or help…
Log for this Example (simplyfied)
[INFO ] Item ‘wz_wt_setTmp’ received command 18.5
[INFO ] wz_wt_setTmp predicted to become 18.5
[INFO ] wz_wt_setTmp changed from 18.00 to 18.5
[INFO ] Item ‘wz_wt_setTmp’ received command 18.5 — second click fires same value as first click
[INFO ] Item ‘wz_wt_setTmp’ received command 19
[INFO ] wz_wt_setTmp predicted to become 19
[INFO ] wz_wt_setTmp changed from 18.5 to 19
[INFO ] Item ‘wz_wt_setTmp’ received command 19.5
[INFO ] wz_wt_setTmp predicted to become 19.5
[INFO ] wz_wt_setTmp changed from 19 to 19.5
[INFO ] Item ‘wz_wt_setTmp’ received command 19.5 — this click also fires same value as click before
[INFO ] Item ‘wz_wt_setTmp’ received command 20
[INFO ] wz_wt_setTmp predicted to become 20
[INFO ] wz_wt_setTmp changed from 19.5 to 20
[INFO ] Item ‘wz_wt_setTmp’ received command 20.5
[INFO ] wz_wt_setTmp predicted to become 20.5
[INFO ] wz_wt_setTmp changed from 20 to 20.5 — now the UI just reached the “20”
