Simple string in sitemap shows error
weather.items:
String OutTempValue { http=“<[https://raspberrypi/zamg.php:1200000]” }
default.sitemap:
Text item=OutTempValue label=“Temperatur in Grad Celsius: [%]” icon=“temperature”
Website gets only the value back. example: " 1.1 ";
I want to get in default.item:
1.1 Grad Celsius
at the moment it shows “Err”
Probably should be:
Text item=OutTempValue label="Temperatur in Grad Celsius: [%.1f]" icon="temperature"
Now it shows only -
‰. 1f declares float. I think I need simple String!
Below an example that is working for me. As you see, I have the “[%.1f °C]” already in my .items file:
.items:
Number KNX_GV_Keuken_Temp1_8_0_1  "Temperatuur Keuken 1 [%.1f °C]" 	<temperature>  { knx="<8/0/1" }
.sitemap:
Text item=KNX_GV_Keuken_Temp1_8_0_1  label="Temperatuur keuken [%.1f °C]"
