u can always test rules with TimeCRON
you have 2x “end” at the end of your rule - you need to close each rule with “end” before you start with the next rule
also you have (on) and (OFF) - its case sensitive ![]()
rule "turn outside lighting on"
// Channel ‘astro:sun:local:set#event’ triggered START or
Time cron "0/5 * * * * ?" // every 5 Seconds 0:05 / 0:10 / 0:15
Outside_garage_lights.sendcommand(ON)
rule "turn outside lighting off"
Time cron "0/10 * * * * ?" // every 10 Seconds 0:10 / 0:20 / 0:30
Outside_garage_lights.sendcommand(OFF)
but maybe you are looking for a “NIGHT STATE” Switch - check this out:
