Sun (raised / set) indicator
There were some changes with openHAB2 and the sunrise / sunset events have been left out for yet another feature which is sadly not finished yet.
That said, here’s a workaround you may use for now:
things/astro.thing
astro:sun:home  [ geolocation="50.12345,10.12345", interval=300]
astro:moon:home [ geolocation="50.12345,10.12345", interval=300]
items/astro.items
DateTime SunsetTime "Sunset [%1$tH:%1$tM]" <sun> (Astro) { channel="astro:sun:home:set#start" }
DateTime SunriseTime "Sunrise [%1$tH:%1$tM]" <sun> (Astro) { channel="astro:sun:home:rise#end" }
Number   SunElevation  "Elevation [%.1f °]"  <sun>  (Astro) { channel="astro:sun:home:position#elevation" }
Switch   NightState    "Night"
rules/astro.rules
rule "OpenHAB system started - astro"
    System started
    createTimer(now.plusSeconds(180)) [ |
        logInfo("RULE", "--> astro init")
        if (now.isAfter((SunsetTime.state as DateTimeType).calendar.timeInMillis) ||
            now.isBefore((SunriseTime.state as DateTimeType).calendar.timeInMillis)
            logInfo("RULE", "--> Night_State ON")
            postUpdate(NightState, ON)
        } else {
            logInfo("RULE", "--> Night_State OFF")
            postUpdate(NightState, OFF)
rule "Update NightState"
    Item SunElevation changed
    if(SunElevation.state >  0){
        if(NightState.state != OFF) postUpdate(NightState, OFF)
    } else {
        if(NightState.state != ON) postUpdate(NightState, ON)
With this combination you will get an item “NightState” which is ON at night and OFF by day. The first rule is needed to set NightState after openHAB was started or reloaded, the second will switch NightState at sunrise/sunset.
In yet another rule you can now react on the item NightState. You can either trigger a rule at sunrise or sunset or use NightState inside a rule as a condition.
Examples:
rule "Night has started"
    Item NightState changed to ON
    logInfo("RULE", "It's getting dark!")
rule "Bathroom door opened"
    Item BathDoor changed to OPEN
    if (NightState.state == ON) {
        sendCommand(BathLight, ON)
