RedOranges
(Red Oranges)
January 22, 2018, 8:32pm
1
I have a group of buttons when one is clicked I want to allow the user to select an option and run a command.
I have the button and modal working, but i cant figure out how to use the user’s choice.
Anyone know a simple way of getting the result of a modal dialog?
<script type="text/ng-template" id="myModalContent.html">
<div class="container popup">
<button type="button" class="btn btn-lg btn-block"
ng-click="$close('Selecttion1')">
Selection 1
</button>
ng-click="$close('Selecttion2')">
Selection 1
</button>
</div>
</script>
ng-click="aVar = openModal('myModalContent.html', false, 'sm')">
Result is {{aVar}}
</button>
ysc
(Yannick Schaus)
January 22, 2018, 8:50pm
2
Unfortunately that’s not possible without using a Javascript controller.
However you can do something like this, it’s not a by-the-book solution but it will work:
ng-click="sendCmd('Item', 'Command1'); $close()">
Selection 1
</button>
ng-click="sendCmd('Item', 'Command2'); $close()">
Selection 2
</button>
</div>
</script>
ng-click="openModal('myModalContent.html', false, 'sm')">
</button>
You can also try the built-in Selection widget, if might be enough for your use case (you can’t customize it much but it’ll display a modal and send commands).
RedOranges
(Red Oranges)
January 22, 2018, 9:34pm
3
Unfortunately, I need to include information from the original button press into the modal dialog so this probably won’t work for me.
I guess I’m going to have to spend time and learn this controller stuff
RedOranges
(Red Oranges)
January 29, 2018, 5:37am
4
@jjones offered me another solution which works quite well, you define a global variable that can be accessed by both.
Here is a link to his solution
