Simple Widget to show a svg with value of an item
Hi @ all and good evening,
I’m struggeling since days to create a very simple widget to show an vector graphic picture containing some item values. In the past I managed this with an existing svg in the hab panel. But now I want to try the main Ui because many say this is better customizable.
Can anybody spend a working code snipped?
I have a svg and I can access it via th browser by: {localIP}/static/Solarthermie-Heizung_II.svg
Many thanks in advance
If you already have an image in a location OH has access to, then all you need to do is to put the address of the image in the url property of an oh-image (or oh-image-card).
Good Morning and many thanks for your reply. The svg shows up but place holders are not replaced by the current value of the items. I tried two aproaches:
  • {{itemState(‘Solarthermie_S1_Vorlauf’)}} for example - worked in the hab panel long time ago
  • =(items.Solarthermie_S1_Vorlauf.state) hint from th AI
But both didn’t work. How should the place holder look like in a vector graphic that OH5 can render it and insert the item values?
Try
text: =items\[props.Solarthermie_S1_Vorlauf\].displayState || items\[props.Solarthermie_S1_Vorlauf\].state
Best Regards
Rafal
Please show the configuration you are trying to use.
The old habPanel configurations will not work in MainUI at all, they are based on a completely different system. But, withouth seeing the actual widget configuration you are trying to use, it is impossible for us to know where the errors are.
@ JustinG, of course. This is the very simple code of the widget:
component: oh-image-card
  url: /static/Solarthermie-Heizung_II.svg
and this is the code of the svg I’m using:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<svg
   xmlns:dc="http://purl.org/dc/elements/1.1/"
   xmlns:cc="http://creativecommons.org/ns#"
   xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
   xmlns:svg="http://www.w3.org/2000/svg"
   xmlns="http://www.w3.org/2000/svg"
   xmlns:sodipodi="http://sodipodi.sourceforge.net/DTD/sodipodi-0.dtd"
   xmlns:inkscape="http://www.inkscape.org/namespaces/inkscape"
   width="464.73914"
   height="306.45386"
   viewBox="0 0 122.96223 81.082584"
   version="1.1"
   id="svg8"
   inkscape:version="1.0.1 (3bc2e813f5, 2020-09-07)"
   sodipodi:docname="Solarthermie-Heizung_II.svg">
  <defs
     id="defs2" />
  <sodipodi:namedview
     id="base"
     pagecolor="#ffffff"
     bordercolor="#666666"
     borderopacity="1.0"
     inkscape:pageopacity="0.0"
     inkscape:pageshadow="2"
     inkscape:zoom="3.2276171"
     inkscape:cx="356.74557"
     inkscape:cy="152.57053"
     inkscape:document-units="mm"
     inkscape:current-layer="layer1"
     inkscape:document-rotation="0"
     showgrid="true"
     units="px"
     inkscape:window-width="1920"
     inkscape:window-height="1017"
     inkscape:window-x="522"
     inkscape:window-y="892"
     inkscape:window-maximized="1"
     fit-margin-top="0.5"
     fit-margin-right="0.5"
     fit-margin-bottom="0.5"
     fit-margin-left="0.5">
    <inkscape:grid
       type="xygrid"
       id="grid849"
       originx="16.435496"
       originy="17.200285" />
  </sodipodi:namedview>
  <metadata
     id="metadata5">
    <rdf:RDF>
      <cc:Work
         rdf:about="">
        <dc:format>image/svg+xml</dc:format>
        <dc:type
           rdf:resource="http://purl.org/dc/dcmitype/StillImage" />
        <dc:title></dc:title>
      </cc:Work>
    </rdf:RDF>
  </metadata>
  <g
     inkscape:label="Ebene 1"
     inkscape:groupmode="layer"
     id="layer1"
     transform="translate(16.435496,17.200285)">
    <g
       id="g1100">
      <path
         style="fill:none;stroke:#6ab0d4;stroke-width:0.065;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:4;stroke-dasharray:none"
         d="M 62.177082,-10.583333 56.885416,-2.6461317e-7"
         id="path1058" />
      <path
         d="M 63.499999,-10.583333 58.208332,-2.6461317e-7"
         id="path1060" />
      <path
         d="M 64.822916,-10.583333 59.531249,-2.6461317e-7"
         id="path1062" />
      <path
         d="M 66.145832,-10.583333 60.854166,-2.6461317e-7"
         id="path1064" />
      <path
         d="M 67.468749,-10.583333 62.177082,-2.6461317e-7"
         id="path1066" />
      <path
         d="M 63.499999,-2.6461317e-7 68.791666,-10.583333"
         id="path1068" />
      <path
         d="M 70.114582,-10.583333 64.822916,-2.6461317e-7"
         id="path1070" />
      <path
         d="m 56.356249,-1.3229169 h 10.31875"
         id="path1072" />
      <path
         d="M 67.468749,-2.6458336 H 56.885416"
         id="path1074" />
      <path
         style="fill:none;stroke:#6ab0d4;stroke-width:0.065;stroke-linecap:butt;stroke-linejoin:miter;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
         d="m 57.679166,-3.9687502 10.478154,0"
         id="path1076"
         sodipodi:nodetypes="cc" />
      <path
         d="M 58.208332,-5.2916669 H 68.791666"
         id="path1078" />
      <path
         d="m 59.002082,-6.6145835 h 10.31875"
         id="path1080" />
      <path
         d="M 70.114582,-7.9375002 H 59.531249"
         id="path1082" />
      <path
         d="m 60.324999,-9.2604168 h 10.31875"
         id="path1084" />
    </g>
    <rect
       style="fill:none;stroke:#6ab0d4;stroke-width:0.500001;stroke-miterlimit:1;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:1"
       id="rect833"
       width="21.777416"
       height="41.01226"
       x="2.0350831"
       y="22.487738"
       ry="9.0812864" />
    <text
       xml:space="preserve"
       style="font-size:2.11667px;line-height:1.25;font-family:sans-serif;-inkscape-font-specification:sans-serif;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264584;stroke-opacity:1"
       x="5.9877143"
       y="31.748732"
       id="text837"
       transform="scale(1.0000707,0.9999293)"><tspan
         sodipodi:role="line"
         id="tspan835"
         x="5.9877143"
         y="31.748732"
         style="font-size:2.11667px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264584;stroke-opacity:1">=(items.Pufferspeicher_1_1.state)</tspan></text>
    <text
       style="font-size:2.11667px;line-height:1.25;font-family:sans-serif;-inkscape-font-specification:sans-serif;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1"
       x="6.0257449"
       y="39.815041"
       id="text837-0"
       transform="scale(1.0000707,0.99992931)"><tspan
         id="tspan835-9"
         x="6.0257449"
         y="39.815041"
         style="font-size:2.11667px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Pufferspeicher_1_2.state)</tspan></text>
    <text
       x="5.9140964"
       y="56.927246"
       id="text837-0-7"
         id="tspan835-9-1"
         x="5.9140964"
         y="56.927246"
         style="font-size:2.11667px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Pufferspeicher_1_1.state)</tspan></text>
    <text
       x="5.9785018"
       y="48.272854"
       id="text837-0-9"
         id="tspan835-9-2"
         x="5.9785018"
         y="48.272854"
         style="font-size:2.11667px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Pufferspeicher_1_3.state)</tspan></text>
    <rect
       style="fill:none;stroke:#6ab0d4;stroke-width:0.500002;stroke-miterlimit:1;stroke-dasharray:none;stroke-dashoffset:0;stroke-opacity:1"
       id="rect833-0"
       width="21.777416"
       height="41.01226"
       x="36.430916"
       y="22.487741"
       ry="9.0812864" />
    <text
       x="40.381111"
       y="31.748735"
       id="text837-9"
         id="tspan835-3"
         x="40.381111"
         y="31.748735"
         style="font-size:2.11667px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Pufferspeicher_2_1.state)</tspan></text>
    <text
       x="40.419144"
       y="39.815041"
       id="text837-0-6"
         id="tspan835-9-26"
         x="40.419144"
         y="39.815041"
         style="font-size:2.11667px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Pufferspeicher_2_2.state)</tspan></text>
    <text
       x="40.307495"
       y="56.92725"
       id="text837-0-7-8"
         id="tspan835-9-1-0"
         x="40.307495"
         y="56.92725"
         style="font-size:2.11667px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Pufferspeicher_2_4.state)</tspan></text>
    <text
       x="40.371902"
       y="48.272854"
       id="text837-0-9-5"
         id="tspan835-9-2-3"
         x="40.371902"
         y="48.272854"
         style="font-size:2.11667px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Pufferspeicher_2_3.state)</tspan></text>
    <rect
       style="fill:none;stroke:#6ab0d4;stroke-width:0.499999;stroke-miterlimit:1;stroke-opacity:1"
       id="rect879"
       width="35.71875"
       height="3.4395852"
       x="-9.2604179"
       y="-11.377084"
       ry="0.79374981"
       rx="0.79374981" />
    <rect
       id="rect881"
       width="1.3229166"
       height="17.197916"
       x="-7.9375014"
       y="-7.937501"
       ry="0.66145831" />
    <rect
       id="rect881-2"
       width="1.3229166"
       height="17.197916"
       x="-5.2916679"
       y="-7.9375005"
       ry="0.66145831" />
    <rect
       id="rect881-4"
       width="1.3229166"
       height="17.197916"
       x="-2.6458342"
       y="-7.937501"
       ry="0.66145831" />
    <rect
       id="rect881-2-7"
       width="1.3229166"
       height="17.197916"
       x="-3.1789145e-07"
       y="-7.937501"
       ry="0.66145831" />
    <rect
       id="rect881-6"
       width="1.3229166"
       height="17.197916"
       x="2.6458309"
       y="-7.9375005"
       ry="0.66145831" />
    <rect
       id="rect881-2-2"
       width="1.3229166"
       height="17.197916"
       x="5.2916646"
       y="-7.9374995"
       ry="0.66145831" />
    <rect
       id="rect881-4-4"
       width="1.3229166"
       height="17.197916"
       x="7.9374986"
       y="-7.9375005"
       ry="0.66145831" />
    <rect
       id="rect881-2-7-8"
       width="1.3229166"
       height="17.197916"
       x="10.583333"
       y="-7.9375005"
       ry="0.66145831" />
    <rect
       id="rect881-1"
       width="1.3229166"
       height="17.197916"
       x="13.229167"
       y="-7.9375"
       ry="0.66145831" />
    <rect
       id="rect881-2-4"
       width="1.3229166"
       height="17.197916"
       x="15.875001"
       y="-7.9374995"
       ry="0.66145831" />
    <rect
       id="rect881-4-7"
       width="1.3229166"
       height="17.197916"
       x="18.520834"
       y="-7.9375"
       ry="0.66145831" />
    <rect
       id="rect881-2-7-82"
       width="1.3229166"
       height="17.197916"
       x="21.166666"
       y="-7.9375"
       ry="0.66145831" />
    <rect
       id="rect881-2-7-82-7"
       width="1.3229166"
       height="17.197916"
       x="23.812498"
       y="-7.9375005"
       ry="0.66145831" />
    <rect
       id="rect879-6"
       width="35.71875"
       height="1.8520831"
       x="-9.2604179"
       y="9.5249996"
       ry="0.79374981"
       rx="0.79374981" />
    <text
       x="27.782072"
       y="7.2260327"
       id="text837-1"
         id="tspan835-8"
         x="27.782072"
         y="7.2260327"
         style="font-size:2.11667px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Solarthermie_S2_Ruecklauf.state)</tspan></text>
    <text
       style="font-size:3.52777px;line-height:1.25;font-family:sans-serif;-inkscape-font-specification:sans-serif;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1"
       x="-16.743023"
       y="-14.388922"
       id="text837-1-2"
         id="tspan835-8-4"
         x="-16.743023"
         y="-14.388922"
         style="font-size:3.52777px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Solarthermie_S1_Vorlauf.state)</tspan></text>
    <path
       style="fill:none;stroke:#6ab0d4;stroke-width:0.465;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1;stroke-miterlimit:4;stroke-dasharray:none"
       d="M 60.854166,-10.583333 55.562499,-2.6461317e-7 H 66.145832 L 71.437499,-10.583333 Z"
       id="path1056" />
    <g
       id="g1100-1"
       transform="translate(11.906251)">
      <path
         id="path1058-6" />
      <path
         id="path1060-6" />
      <path
         id="path1062-7" />
      <path
         id="path1064-7" />
      <path
         id="path1066-6" />
      <path
         id="path1068-2" />
      <path
         id="path1070-6" />
      <path
         id="path1072-8" />
      <path
         id="path1074-0" />
      <path
         d="M 57.679166,-3.9687502 H 68.15732"
         id="path1076-7"
      <path
         id="path1078-3" />
      <path
         id="path1080-5" />
      <path
         id="path1082-8" />
      <path
         id="path1084-6" />
    </g>
    <path
       style="fill:none;stroke:#6ab0d4;stroke-width:0.465;stroke-linecap:butt;stroke-linejoin:miter;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
       d="M 72.760419,-10.583334 67.468752,-7.8435855e-7 H 78.052085 L 83.343752,-10.583334 Z"
       id="path1056-5" />
    <g
       id="g1100-4"
       transform="translate(-5.2916655,11.90625)">
      <path
         id="path1058-0" />
      <path
         id="path1060-1" />
      <path
         id="path1062-8" />
      <path
         id="path1064-5" />
      <path
         id="path1066-1" />
      <path
         id="path1068-0" />
      <path
         id="path1070-4" />
      <path
         id="path1072-88" />
      <path
         id="path1074-4" />
      <path
         id="path1076-0"
      <path
         id="path1078-9" />
      <path
         id="path1080-52" />
      <path
         id="path1082-5" />
      <path
         id="path1084-3" />
    </g>
    <path
       d="M 55.562502,1.3229168 50.270835,11.90625 H 60.854167 L 66.145835,1.3229168 Z"
       id="path1056-8" />
    <g
       id="g1100-1-6"
       transform="translate(6.6145841,11.90625)">
      <path
         id="path1058-6-4" />
      <path
         id="path1060-6-9" />
      <path
         id="path1062-7-1" />
      <path
         id="path1064-7-2" />
      <path
         id="path1066-6-2" />
      <path
         id="path1068-2-8" />
      <path
         id="path1070-6-0" />
      <path
         id="path1072-8-9" />
      <path
         id="path1074-0-2" />
      <path
         id="path1076-7-3"
      <path
         id="path1078-3-1" />
      <path
         id="path1080-5-2" />
      <path
         id="path1082-8-4" />
      <path
         id="path1084-6-6" />
    </g>
    <path
       d="M 67.468754,1.3229158 62.177087,11.90625 H 72.760421 L 78.052087,1.3229158 Z"
       id="path1056-5-6" />
    <rect
       style="fill:none;fill-opacity:1;stroke:#6ab0d4;stroke-width:0.465;stroke-miterlimit:4;stroke-dasharray:none;stroke-opacity:1"
       id="rect1285"
       width="11.906253"
       height="15.874998"
       x="76.729164"
       y="19.84375"
       ry="0.66145831" />
    <rect
       id="rect1287"
       width="3.96875"
       height="2.6458333"
       x="80.697914"
       y="23.812502"
       ry="0" />
    <path
       d="M 85.989582,19.843749 V -2.6458336 h 13.229167"
       id="path1289" />
    <path
       d="M 85.989582,2.645833 H 99.218749"
       id="path1291" />
    <path
       d="M 85.989582,7.9374996 H 99.218749"
       id="path1293" />
    <text
       style="font-size:3.52777778px;line-height:1.25;font-family:sans-serif;-inkscape-font-specification:sans-serif;stroke-width:0.264583;fill:#6ab0d4;fill-opacity:1;"
       x="87.3125"
       y="-3.9687507"
       id="text1297"><tspan
         id="tspan1295"
         x="87.3125"
         y="-3.9687507"
         style="stroke-width:0.264583;fill:#6ab0d4;fill-opacity:1;font-size:3.52777778px;">U</tspan></text>
    <text
       style="font-size:3.52778px;line-height:1.25;font-family:sans-serif;-inkscape-font-specification:sans-serif;fill:#6ab0d4;fill-opacity:1;stroke-width:0.264583"
       x="87.323814"
       y="1.3935713"
       id="text1301"><tspan
         id="tspan1299"
         x="87.323814"
         y="1.3935713"
         style="font-size:3.52778px;fill:#6ab0d4;fill-opacity:1;stroke-width:0.264583">V</tspan></text>
    <text
       x="87.458099"
       y="6.6782093"
       id="text1305"><tspan
         id="tspan1303"
         x="87.458099"
         y="6.6782093"
         style="font-size:3.52778px;fill:#6ab0d4;fill-opacity:1;stroke-width:0.264583">W</tspan></text>
    <text
       x="91.242073"
       y="-4.0181842"
       id="text837-1-0"
         id="tspan835-8-5"
         x="91.242073"
         y="-4.0181842"
         style="font-size:3.52777px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Leistung_Phase_1.state)</tspan></text>
    <text
       x="91.309616"
       y="1.2031964"
       id="text837-1-0-9"
         id="tspan835-8-5-7"
         x="91.309616"
         y="1.2031964"
         style="font-size:3.52777px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Leistung_Phase_2.state)</tspan></text>
    <text
       x="91.261604"
       y="6.6931591"
       id="text837-1-0-3"
         id="tspan835-8-5-0"
         x="91.261604"
         y="6.6931591"
         style="font-size:3.52777px;fill:#6ab0d4;fill-opacity:1;stroke:none;stroke-width:0.264583;stroke-opacity:1">=(items.Leistung_Phase_3.state)</tspan></text>
  </g>
</svg>
@ AlienRafał Różynek what do you mean? Add this line in the widget code or in the svg?
Ok, I think I understand. You have been trying to add something to the svg file that will respond to values from OH. That will not work with the MainUI (using the oh-image container).
=items.Solarthermie_S1_Vorlauf.state is a correct form for accessing the state of that item in a widget, but that must be the value of one of the yaml keys in the widget configuration, it does not work in any things else (like inside an svg file).
There is a way to achieve what you want, but it will take just a little more work. You can actually build the svg directly in the widget. This is a moderately advanced use of the widget system, but once you get proficient with it it’s very powerful. There are several examples in the forums for building svg’s. Here are a couple:
(scroll down to the second half of that thread)
Or
or many others.
You also don’t need everything in that svg file. Inkscape adds a lot of extra information. If you go to inkscape and use save as and then select optimized svg, you’ll get a significantly smaller file which will be reasonably easy to convert over to the widget.
This is my widget displaying the heat recovery unit temperatures. You need to define your own fields with values, if I’m not mistaken openHAB doesn’t support fields in SVG, or at least I couldn’t get it to work. I did it this way.
uid: Rekuperator_Temps_Widget_V2
tags:
  - diagram
  - temperature
  - ventilation
props:
  parameters:
    - description: Tytuł widgetu
      label: Title
      required: false
      type: TEXT
    - context: item
      description: Temperatura Czerpnia
      label: Czerpnia Item
      required: false
      type: TEXT
    - context: item
      description: Temperatura Za GWC
      label: Za GWC Item
      required: false
      type: TEXT
    - context: item
      description: Temperatura Wyrzutnia
      label: Wyrzutnia Item
      required: false
      type: TEXT
    - context: item
      description: Temperatura Nawiew
      label: Nawiew Item
      required: false
      type: TEXT
    - context: item
      description: Temperatura Wywiew
      label: Wywiew Item
      required: false
      type: TEXT
timestamp: Nov 29, 2025, 6:32:43 PM
component: f7-card
  title: "=props.title ? props.title : 'Rekuperator - Temperatury'"
  style:
    min-height: 300px
    margin: 15 px
    --f7-card-header-font-size: 16px
    --f7-card-header-font-weight: bold
slots:
  default:
    - component: f7-block
        style:
          padding: 0
          margin: 0
          position: relative
          display: flex
          justify-content: center
          align-items: center
          width: 100%
      slots:
        default:
          - component: div
              style:
                position: relative
                width: 100%
                max-width: 600px
            slots:
              default:
                - component: oh-image
                    url: /static/reku.svg
                    style:
                      width: 100%
                      height: auto
                      display: block
                - component: Label
                    text: =items[props.wywiew].displayState || items[props.wywiew].state
                    style:
                      position: absolute
                      background: rgba(255, 255, 255, 0.9)
                      border: 1px solid
                      border-radius: 4px
                      padding: 2px 6px
                      font-size: 12px
                      font-weight: bold
                      color: "#333333"
                      box-shadow: 0 2px 4px rgba(0,0,0,0.15)
                      transform: translate(-50%, -50%)
                      top: 21%
                      left: 16%
                - component: Label
                    text: =items[props.zagwc].displayState || items[props.zagwc].state
                    style:
                      position: absolute
                      border: 1px solid
                      border-radius: 4px
                      padding: 2px 6px
                      font-size: 12px
                      font-weight: bold
                      color: "#333333"
                      top: 21%
                      left: 66%
                - component: Label
                    text: =items[props.czerpniagwc].displayState || items[props.czerpniagwc].state
                    style:
                      position: absolute
                      border: 1px solid
                      border-radius: 4px
                      padding: 2px 6px
                      font-size: 12px
                      font-weight: bold
                      color: "#333333"
                      top: 21%
                      left: 80%
                - component: Label
                    text: =items[props.nawiew].displayState || items[props.nawiew].state
                    style:
                      position: absolute
                      border: 1px solid
                      border-radius: 4px
                      padding: 2px 6px
                      font-size: 12px
                      font-weight: bold
                      color: "#333333"
                      top: 79%
                      left: 16%
                - component: Label
                    text: =items[props.wyrzutnia].displayState || items[props.wyrzutnia].state
                    style:
                      position: absolute
                      border: 1px solid
                      border-radius: 4px
                      padding: 2px 6px
                      font-size: 12px
                      font-weight: bold
                      color: "#333333"
                      top: 79%
                      left: 80%
Thank you so much JustinG and AlienRafał Różynek. I’m very new to all the Yaml stuff. And I’m just stepping very slowly into it. As far as I understood your explanations and what was written in these threads. I have to use a svg bare of any place holders and add these place holders later. Like this:
 - component: Label
                    style:
                      position: absolute
                      border: 1px solid
                      border-radius: 4px
                      padding: 2px 6px
                      font-size: 12px
                      font-weight: bold
                      color: "#333333"
                      top: 21%
                      left: 16%
or like this:
          - component: Label
              style:
                width: 25%
              text: =items[props.totalPages].state
Did I get this right?
But I don’t understand how the positioning of the text is done.
Exactly,
- component: Label
                    style:
                      position: absolute
                      border: 1px solid
                      border-radius: 4px
                      padding: 2px 6px
                      font-size: 12px
                      font-weight: bold
                      color: "#333333"
                      top: 21%
                      left: 16%
“top” and “left” is position of your placeholder defined in “props” section. You can easily adapt my widget by replacing the SVG and modifying the number of placeholders :slight_smile:
We have described two fundamentally different approaches:
  1. @Alien’s example displays your static svg and then positions html elements on top of that. The html elements contain the dynamic information about oh items. This is easier, but will be harder to make fully responsive.
  2. My approach creates the svg in the widget so that the svg can have the dynamic oh information directly in it.
For example, if I wanted an svg of a green hexagon with some text in it, I can use the following widget where each component is one of the tags in the svg:
component: svg
  width: 100px
  height: 100px
  version: 1.1
  viewBox: "0 0 100 100"
  xmlns: http://www.w3.org/2000/svg
slots:
  default:
    - component: path
        transform: "matrix(1.8122 0 0 1.5694 -75.144 -73.894)"
        d: "m96.648 94.873-27.591 15.93-27.591-15.93v-31.859l27.591-15.93 27.591 15.93z"
        style: "fill:#008000;stroke-width:.59297"
    - component: text
        x: 10
        y: 50
        style: "fill:#000000;font-family:sans-serif;font-size:12px;"
        xml:space: "preserve"
        content: Some text here
If I want that text to be dynamic instead then I can just change the content property to a dynamic expression:
content: =items.myStringItem.state
Thank you again. Now I understood that there are two ways to solve my issue. I will try both and figure out which fits my needs best. But two concluding questions:
@Alien is it possible to do the positioning with exact coordinates where the origing is the top left corner for example of the svg picture?
@JustinG To be honest I’m a lttle bit confused about
why this has to be added?
Short answer:
You really don’t have to add it; it’s just good practice. Your widget svg will be fine without it.
Long answer:
It’s a standard addition to most svg files because it explicitly defines the xml namespace for all standard svg tags (the rules for what makes a tag an svg tag). Since you are using your svg strictly in a browser environment in this case, that namespace is redundant (browsers will include it by default). If you are interested in more detail you can find much information with a quick search for “xml namespaces”.
Yes, that’s how it’s done now, instead of pixels there are percentages to make the widget responsive.
Many thanks for your replys. I will play little bit around with what I’ve learned
After a few days of experimenting, I found that it was easier and faster to use an SVG file, as I had already drawn it. However, I learned that SVG paths or other structures can also be added, especially if you want to create an animated or dynamic image. Ultimately, I use a mixture of both approaches.
Could you show how, (how´s your svg looking now) ?
Of course I opend a new topic. For further improvments :smiley:: Animated SVG in Sitemap
