While moving my functions to the library file I stumble about an other issue, I would like to understand to get a better grasp of the internals:
In my rules I can use OnOffType, itemRegistry and other types without explicitly importing them. In the library file I had to add “from core.jsr223.scope import itemRegistry, OnOffType, UpDownType, OpenClosedType”
I had the same import in my library file (also I probably should not). But I do not actually use rules or decorators in my library, maybe this is the cause?
Thank you for pointing this out (an issue or PR in the repo would have been better ). Corrected now,
DefaultScriptScopeProvider.java provides a default scope that is imported into all scripts. Modules load with no context, so you need to explicitly import what you need. As you found, the core.jsr223 can be used to access the default scope/preset in modules. Importing the other presets may also be helpful (core.rules imports RuleSimple).
You can do it straight from Guthub. Edit the file, and when you go to save it, there is an option to Create a new branch for this commit and start a pull request. This will create a personal fork of the repo. Navigate to it in your repositories, select Compare, and you will see an option to create a PR. I’ll add this to the docs with some screenshots the next time I submit a PR though GH.
If this is Ok for you, I will add the topics discussed here regarding modules in a short paragraph of the „But how do I“ section of the documentation. That I could use to document creating a PR as well.
As I am quite busy in the next days I will probably need a few days until this is finished.
Is enabling and disabling Jython rules (via Karaf or via RuleManager service in Jython) working for you?
I’ve tried to update rules_registry example with latest release and recent snapshot, but once the rule is disabled and re-enabled it is not being run properly. When called with runNow (without checking for predicates), it will appear to run (IDLE → Running → IDLE) but action is not executed (looks like missing action handler). In the same way, after re-enabling rule is not run on trigger condition.
And I can confirm, that rules can not be remove via rules global but only with ruleRegistry as said previously in this topic (on side note, why these two are different?)
Just a heads up to anyone using the Jython libraries that uses snapshots… don’t upgrade your OH! I’ve been working on updating the libraries due to the ESH migration, but have found an issue where some of the Java classes, which have not yet been fully migrated, are no longer accessible. So for now, it is best not to use the snapshots (or milestones, when they come) until this gets sorted.
2019-04-05 14:31:53.244 [ERROR] [tomation.jsr223.jython.core.triggers] - when: Exception [when: "Channel mqtt:broker:f79d2a84:TriggerIn triggered" could not be parsed because Channel "mqtt:broker:f79d2a84:TriggerIn" is not a trigger]: [Traceback (most recent call last):
File "/etc/openhab2/automation/lib/python/core/triggers.py", line 313, in when
raise ValueError("when: \"{}\" could not be parsed because Channel \"{}\" is not a trigger".format(target, trigger_target))
ValueError: when: "Channel mqtt:broker:f79d2a84:TriggerIn triggered" could not be parsed because Channel "mqtt:broker:f79d2a84:TriggerIn" is not a trigger
What am I doing wrong? It works without a problem when using it a s a trigger in a DSL Rule. When I use a another channel from a Rockerswitch the Jython rule works without a problem. It just doesnt work with the mqtt publish trigger channel.
Thanks for the great work on this.
After looking at the error in the log again I found the responsible line in the triggers.py:
elif target_type == "Channel" and scope.things.getChannel(ChannelUID(trigger_target)).kind != ChannelKind.TRIGGER:
Once I commented it out and restarted Openhab the rule works without an issue.
It looks like the MQTT2 binding doesnt declare the trigger channel right.
Thank you for looking into it. With the two lines commented out its working fine for now. Im really loving Jython combined with the simplified rule definition.
Hello, just a short question, when I try to use the System started trigger I get this:
2019-04-15 16:30:53.582 [ERROR] [tomation.jsr223.jython.core.triggers] - when: Exception [when: "System started" could not be parsed because rule triggers do not currently support target_type "System"]: [Traceback (most recent call last):
File "/etc/openhab2/automation/lib/python/core/triggers.py", line 325, in when
raise ValueError("when: \"{}\" could not be parsed because rule triggers do not currently support target_type \"System\"".format(target))
ValueError: when: "System started" could not be parsed because rule triggers do not currently support target_type "System"
2019-04-15 16:30:53.596 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab2/automation/jsr223/personal/mqtt1.py': TypeError: 'NoneType' object is not callable in <script> at line number 32
Am I doing something wrong? Or is the Readme ahead of the implementation. This is the rule the trigger belongs too. It works fine without the system started trigger.
@rule("StatePublish")
@when("System started")
@when ("Time cron 0 0 0/1 * * ?")
def statepublish(event):
for member in ir.getItem("Stats").members:
membername = ''.join(re.findall("^\S*", str(member)))
memberstate = str(ir.getItem(membername).state)
actions.get("mqtt","mqtt:broker:f79d2a84").publishMQTT("allItemsout/"+membername,memberstate)
StartupTrigger broke after an API change, but ScriptedCustomModuleHandlerFactory was recenty fixed. I’ll mention this restriction in the OP to match the readme, which still looks accurate… or are you referring to something else? I have not updated the libraries so that the StartupTrigger can be used, as there are several changes that are also needed in order to be compatible with the new openhab-core, and there was a critical issue for automation that needed to be resolved before the new OH core could be used.
I planned to put a release out for all of these changes, once the snapshots included the new core, but this is taking longer than expected. I’ll try to get something together before the end of the weekend, but this could be delayed as the OH-Jython-Scripters organization is about to be renamed, so that helper libraries for scripting langauges other than Jython can be added.
Just had another thought… instead of using the StartupTrigger, you can get the result by just calling the function straight out of the script, so that it runs when the file is loaded or saved.
Thank you for the answer, your second suggestion doesnt work for me. If I assign statepublish to None I get a syntax error.
But I can wait for the system started trigger. Thank you again, regards Johannes
