Preamble: I solved the problem by changing trigger-type to “changed”. In my context this is not only a workaround, but also the better configuration. However, I still consider this as a bug, so that’s why I’m writing about it here.
Today I updated from 2.5M4 to 2.5M6.
Since the update, rules that are triggered by an update-trigger, are executed many times (16?) for each update:
20:59:12.735 [INFO ] [jsr223.jython.Thermostat ] - Schalte Heizung für IaniZ ein.
20:59:12.797 [DEBUG] [jsr223.jython.Thermostat ] - Thermostat
20:59:12.863 [DEBUG] [jsr223.jython.Thermostat ] - Getting item IaniZ_temp
20:59:12.990 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.006 [DEBUG] [jsr223.jython.Thermostat ] - Getting item IaniZ_solltemp
20:59:13.054 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.071 [DEBUG] [jsr223.jython.Thermostat ] - Getting item IaniZ_heatauto
20:59:13.120 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.137 [DEBUG] [jsr223.jython.Thermostat ] - Getting item IaniZ_heizung
20:59:13.177 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.195 [INFO ] [jsr223.jython.Thermostat ] - Prefix IaniZ: Ist: 22.53 - Soll: 22.799999999999972 - Zustand: ON [Automatik: ON]
20:59:13.246 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.262 [DEBUG] [jsr223.jython.Thermostat ] - Bereits eingeschaltet
20:59:13.292 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.339 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.382 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.430 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.472 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.524 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.587 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.649 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.696 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.739 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.777 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.821 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.859 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.904 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:13.943 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:13.998 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:14.036 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:14.078 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:14.117 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:14.165 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:14.208 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:14.253 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:14.293 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:14.338 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:14.383 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:14.433 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:14.473 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
20:59:14.515 [DEBUG] [jsr223.jython.Thermostat ] - Heizungs-Mode: IaniZ_heizung updated to ON
20:59:14.556 [DEBUG] [jsr223.jython.Thermostat ] - Prefix IaniZ: Zustand: ON [Automatik: ON]
The rule looks like this:
@rule("Thermostat-Modus setzen")
@when("Member of gHeatAuto received update")
@when("Member of gHeater received update")
def therm_mode_changed(event):
#plog = logging.getLogger("RULES.Heating.Mode")
therm_temp_changed.log.debug("Heizungs-Mode: " + str(event))
item = event.getItemName()
prefix = item[:item.index("_")]
item_mode = prefix+"_heatmode"
item_switch = prefix+"_heizung"
item_auto = prefix+"_heatauto"
switch_state = itemRegistry.getItem(item_switch).getState()
auto_mode = itemRegistry.getItem(item_auto).getState()
therm_temp_changed.log.debug(u"Prefix %s: Zustand: %s [Automatik: %s]" % (prefix, unicode(switch_state), unicode(auto_mode)))
newModeStr = "Auto_" if auto_mode==ON else "Manual_"
newModeStr += "ON" if switch_state==ON else "OFF"
events.sendCommand(item_mode, newModeStr)
Loading the rule shows, that a trigger is only generated once:
20:54:35.584 [DEBUG] [jsr223.jython.core.triggers ] - when: target=[Member of gHeatAuto received update], target_type=Member of, trigger_target=gHeatAuto, trigger_type=received update, old_state=None, new_state=None
20:54:35.646 [DEBUG] [jsr223.jython.core.triggers ] - when: target=[Member of gHeater received update], target_type=Member of, trigger_target=gHeater, trigger_type=received update, old_state=None, new_state=None
20:54:35.725 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-BadOG_heizung-received-update_66818eb0147411eaa9eb0281f4918d2c]
20:54:35.790 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-GrBad_heizung-received-update_668c1600147411eaa8f50281f4918d2c]
20:54:35.843 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-IaniZ_heizung-received-update_669564d1147411ea91020281f4918d2c]
20:54:35.935 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-Flur_heizung-received-update_669df04f147411eabf150281f4918d2c]
20:54:36.003 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-GZ_heizung-received-update_66ac482e147411eaaade0281f4918d2c]
20:54:36.055 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-AldoniZ_heizung-received-update_66b5e51e147411ea830b0281f4918d2c]
20:54:36.111 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-BadUG_heizung-received-update_66bdfb70147411ea83150281f4918d2c]
20:54:36.167 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-Kueche_heizung-received-update_66c6d50f147411ea95ef0281f4918d2c]
20:54:36.295 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-WZ_heizung-received-update_66ceeb5e147411ea9aba0281f4918d2c]
20:54:36.363 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-SZ_heizung-received-update_66e29a70147411eaa6fa0281f4918d2c]
20:54:36.420 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-GZ_heatauto-received-update_66ed21c0147411ea88750281f4918d2c]
20:54:36.484 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-IaniZ_heatauto-received-update_66f5d44f147411ea98be0281f4918d2c]
20:54:36.575 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-GrBad_heatauto-received-update_6703b700147411eab3590281f4918d2c]
20:54:36.633 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-Kueche_heatauto-received-update_670dc921147411ea9fed0281f4918d2c]
20:54:36.693 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-WZ_heatauto-received-update_671717f0147411eab45e0281f4918d2c]
20:54:36.749 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-AldoniZ_heatauto-received-update_671f5551147411eab3460281f4918d2c]
20:54:36.810 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-SZ_heatauto-received-update_6728a41e147411ea94300281f4918d2c]
20:54:36.878 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-BadUG_heatauto-received-update_67330461147411ea9b030281f4918d2c]
20:54:36.936 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-Flur_heatauto-received-update_673bde00147411eaaed50281f4918d2c]
20:54:36.992 [DEBUG] [jsr223.jython.core.triggers ] - when: Created item_trigger: [Item-BadOG_heatauto-received-update_6744b79e147411eaaee60281f4918d2c]
20:54:37.039 [DEBUG] [jsr223.jython.core.rules ] - Added rule [Thermostat-Modus setzen]
