Did anybody wrote a script/rule to dial out via SIP protocol which could be published here?
Use case is quite easy: In case of fire alarm I want openHAB to connect via SIP to my Fritzbox and dial a mobile phone number.
No text-to-speech and no playing of wav/mp3 files required. Just dialing out.
I remember once being successful with linphone. But this was years ago and I do not have the code anymore.
Look for the linphone-deamon, it is a CLI you could call with the exec-binding.
Another option would be Jami, here you find some details on how to get it up and running on a Raspberry Pi.
Good luck
thanks thomas. will give it a try. however, if anybody is out there who wrote a python script please let me know
Have a look at Call phone with Fritzbox binding and fritzconnection if that helps.
Rule:
rule "VoIP Call on Klingel"
Item Klingel changed from OFF to ON
executeCommandLine("/opt/sipcmd/sipcmd -P sip -u voip-user -c 1234 -a Klingel -w 10.10.80.9 -x 'c**610;h'")
thanks, but Iād prefer to set it up as a SIP connection rather than a proprietary interface
yeah, I saw that, too. But I found out that this tool is not supported anymore and does not run on latest unix versions
I try it in Docker with Ubuntu 18.4 and FritzOS 7.25 and it works.
Perhaps this is an Alternative.
Which SIP client do you suggest under openhabian? I guess it should be possible to trigger the calls without much hassle ā¦
I was also looking for a simple solution to send simple messages from OpenHab to my internal phones (using SIP). I stumbled across the simple Python script FemtoSIP (GitHub - astoeckel/femtosip: Minimal Python SIP implementation ringing phones as a door bell replacement).
This can be used easily with the exec-binding:
~/openhab/python $ ./femtosip.py --user MYSIPUSER --password "MYSIPPASSWD" --gateway 192.168.178.1 --call '**614' --display hello
2023-09-26 11:06:15,358 request: INVITE sip:**614@192.168.178.1
2023-09-26 11:06:15,876 response: SIP/2.0 100 Trying
2023-09-26 11:06:15,879 response: SIP/2.0 183 Session Progress
2023-09-26 11:06:30,879 request: CANCEL sip:**614@192.168.178.1
2023-09-26 11:06:31,741 response: SIP/2.0 487 Request Cancelled
It works like a charm!
BTW: Offcourse after configuring the user MYSIPUSER in my VoIP configuration (FritzBox).
sip
Interesting. Do you know if this script can ring an external device (by dialing out instead of calling internal function **9)?
Yes, it works for any number that the SIP user is allowed to dial.
