My POP smoke detector and siren is randomly sounding starting this night waking the family. I can see in the openHAB app that it is not triggered by the smoke detector. I guess it is some other device triggering it. In HABmin I have set some other devices to point to the smoke detector as Lifeline under Association group. My thought was to make the smoke detector as some sort of hub since it is closer to some sensors than the controller and the detector has the ability to route messages. Im I wrong in using the lifeline like so? Can that be the cause of the siren sounding?
Does the network arrange it self in the heal so I don’t have to worry about it?
Here is the log when the siren started sounding:
2017-04-28 07:53:23.923 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 1C 03 25 03 FF 34
2017-04-28 07:53:23.932 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-04-28 07:53:23.939 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=28, callback=0, payload=00 1C 03 25 03 FF
2017-04-28 07:53:23.944 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=28, callback=0, payload=00 1C 03 25 03 FF
2017-04-28 07:53:23.949 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], dest=28, callback=0, payload=00 1C 03 25 03 FF
2017-04-28 07:53:23.951 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-04-28 07:53:23.953 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Application Command Request (ALIVE:DONE)
2017-04-28 07:53:23.954 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: resetResendCount initComplete=true isDead=false
2017-04-28 07:53:23.956 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: Incoming command class COMMAND_CLASS_SWITCH_BINARY, endpoint 0
2017-04-28 07:53:23.957 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 28: SECURITY not supported
2017-04-28 07:53:23.959 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 28: Received COMMAND_CLASS_SWITCH_BINARY V1 SWITCH_BINARY_REPORT
2017-04-28 07:53:23.960 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 28: Switch Binary report, value = 255
2017-04-28 07:53:23.962 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2017-04-28 07:53:23.963 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-04-28 07:53:23.965 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SWITCH_BINARY, value = 255
2017-04-28 07:53:23.968 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 28: Updating channel state zwave:device:152b12ad:node28:switch_binary to ON [OnOffType]
2017-04-28 07:53:23.974 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Commands processed 1.
2017-04-28 07:53:23.975 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 28: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@13f016b.
