Issue of the topic: please be detailed explaining your issue
Please post configurations (if applicable):
KNX Items
Sitemap for BasicUi
Hi, I had a stable PI3 running OH2 and the upgraded to OH3. By mistake I upgraded to OH4, and then it failed. Did a clean install using the OH4 image 4.0.3, copied over my sitemaps, kinx items, addon files, thing files.
The Basic UI doesnt seem to be picking up Group Items, from the sitemap. It use to work under OH3
Frame label="Temperatures" {
Group item=Thermostat
Frame label="Ground Floor" icon="groundfloor" {
Group item=GF_Bathroom
Group item=GF_Bedroom
Group item=GF_Office
Group item=GF_Hallway
Group item=GF_Stairwell
Frame label=“Temperatures” {
Frame label=“Ground Floor” icon=“groundfloor” {
No, I havent even looked at the Main UI at all. All my items, and things are on the main ui. Is there a tutorial? What config file would I need to edit?
Could I create say a model.items file, with the new group reference, tags etc. Would that load up, and get my old basic UI, working again?
Also I note on the location tags, that the tags only go up to third floor. I live in a converted tower, and I have 7 floors. This doesn’t help, perhaps I could create a request?
I have now created a model.items using the group syntax’s and tags, and it loading the locations on the basicui. The strange thing is if I use a bathroom tag, the basicui, will not pickup the icon, but If I shorten it to bath it will load the bathroom icon.
When I do get round to writing an items file with the scemantic model coding, would I need to delete my default item map?
