Hi there,
i have a problem getting my HUE lights working in a test sitemap.
I configured the Hue Bridge and the HUE lights in the Paper UI, the bridge and the lights show up in Configuration/Things.
Now i try to build a items file and a sitemap
Items File called “Group.item”:
Group gWohnung
Group gFlur (gWohnung)
Group gBad (gWohnung)
Group gKueche (gWohnung)
Group gSchlafzimmer (gWohnung)
Group gWohnzimmer (gWohnung)
Group gSofa (gWohnzimmer)
Group gEsstisch (gWohnzimmer)
Group gDeckenfluter (gWohnzimmer)
Items File called “Flur.item”:
Color flur_l_decke “Flur” <light> (gFlur) [“Lightning”] {channel=“hue:0210:0017881000bb:13:color”}
Sitemap File called “_default.sitemap”
sitemap _default label="Main" {
Frame label="Gruppen" {
Group item=gWohnung label="Wohnung" icon="group"
Frame label="Items" {
Colorpicker item=flur_l_decke
The channel description of the HUE light is copied from the Paper UI.
I run into two problems, when i’m clicking through the Groups on the sitemap, i can’t see the HUE light in the Group “gFlur” and when i try to change the Color of the light direct in the sitemap it does not work.
There are no entries in the logs, so i don’t know how i can get it to work
Cyclopes
