hi, i have 15 lights at room 3x5 i created groups etc just im looging something like multiswich (or something like that) so i can “touch” and turn on/off single light. Somehing like that
X X X
X X X
is is even possible or someone have any idea to do this ?
In sitemaps, no, there is nothing like that directly supportable at this time.
There is working ongoing to add a button grid type widget but it’s not complete.
In the mean time, you could get something like that using a proxy Item, rule, and Switch elements with mappings.
In the mappings map the button to the Item name to toggle. That Item name gets sent to the proxy Item which triggers a rule to command the Item with that name ON or OFF based on what state it’s in.
And the new button grid will be stateless, that is a set of buttons, each sending a different command to an item.
