Hello there.
I just recieved an harmony hub and wanted to create a sitemap button to controll it. As discribed in the docs i created a simple Switch with the required actions as mappings (via UI not the Editor) and every think worked perfectly.
A few days later i was working on the same sidemap again but was using the editor instead of the ui. Unexpectetly the editor was showing me an error in a line i didnt even changed. After some tests i could narrow it down to the button mentioned above.
Actually the error message is quite obvious. The problem is that the command of the command-value-pair for the button-mapping is containing an space and the editor cant handle that.
To fix the problem i tried to quote the command just like the keys were and this fixed the error generated by the editor. But after this change the sitemap-button didnt work any more (probably because the wrong commands were send to the item).
If thats not a bug but me doing something wrong i would be happy if anyone could tell me how to do it right. Otherwise if you agree with me i can create an issue for this problem.
Also it would be nice if someone whos running a version of Openhab 3.2.0 could try to reproduce it to check if the error is still there. The code needed for the sitemap switch can be found down below.
Platform information:
- Hardware: PI4
- OS: Raspbian
- Java Runtime Environment: 11
- openHAB version: 3.1.0
Please post configurations (if applicable):
Items configuration related to the issue
Can be provided later if needed. -
Sitemap
Switch mappings=[Fire TV=“Amazon”,Fernsehen=“TV”,Musik hören=“Musik”]
Error generated by Editor:
Error: Syntax error at line 3 col 26: Switch mappings=[Fire ^ Unexpected WS token: " ". Instead, I was expecting to see one of the following: A equals token based on: Mapping → MappingCommand ● %equals MappingLabel Mappings → ● Mapping WidgetAttrValue → %lbracket _ ● Mappings _ %rbracket WidgetAttr → WidgetAttrName ● WidgetAttrValue WidgetAttrs → ● WidgetAttr Widget$ebnf$1 → Widget$ebnf$1 ● WidgetAttrs Widget → %nlwidget _ ● Widget$ebnf$1 Widgets → Widgets _ ● Widget Sitemap → %sitemap _ SitemapName __ SitemapLabel __ %lbrace _ ● Widgets _ %rbrace Main → _ ● Sitemap _
