I have the same error.
“Validation issues found in configuration model ‘myHome.sitemap’, using it anyway”
The first line of my sitemap file is
sitemap myHome label=“myHome”
There are no name conflicts and all entries within frames.
It doesn’t really matter as everything is working fine but I’d just like to clean it up if possible.
Any suggestions?
There’s something wrong with it. The rest of the message might tell you more.
If you can’t share the file, you can try commenting chunks out to pin it down.
