Hi.
Is it possible to have some conditional jump for masking some sitemap lines ?
I have a toogled switch button in sitemap
I need to mask both lines, if usercode is not equal 1.
Only one line shall be displayed if usercode equal 1
and nothing shall be displayed if usercode is not equal 1
Switch item=TRANSFER mappings=[OFF="OFF"] icon="battery" visibility=[usercode==1, TRANSFER==ON]
Switch item=TRANSFER mappings=[ON="ON"] icon="battery" visibility=[usercode==1, TRANSFER==OFF]
Thanks.
vzorglub
(Vincent Regaud)
December 11, 2018, 7:28am
2
See:
In particular the last paragraph.
What you are trying to do is an AND
in the visibility conditions and the sitemaps don’t support that.
You will need to create and rule and use a third “dummy” item to set the visibility.
Thanks, solved with Frame visibility
Frame visibility=[userlevel==1] {
Switch item=TRANSFER mappings=[OFF="OFF"] icon="battery" visibility=[TRANSFER==ON]
Switch item=TRANSFER mappings=[ON="ON"] icon="battery" visibility=[TRANSFER==OFF]
vzorglub
(Vincent Regaud)
December 11, 2018, 9:52am
4
Clever way to kind of create an AND
condition in the sitemap. Good
