I have been using OpenHAB2 for a while but I am still learning. I decided to upgrade my system using openhabian-config. Everything seemed to work fine except now the system cannot find my sitemaps. The webserver returns an Error 500.
My sitemaps are and have been located in /etc/openhab2/sitemaps. Looking through the docs, should I have $OPENHAB_CONF set? If so, how do I set this?
David
HTTP ERROR 500
Problem accessing /classicui/app. Reason:
Server Error
Caused by:
javax.servlet.ServletException: Sitemap âgarageâ could not be found
I did look in the log file and it basically says the same thing that that my browser shows. It cannot find Sitemap âgarageâ
I have several sitemaps but none of them work. It acts like it now looking in a different directory than /etc/openhab2/sitemaps/
2017-12-05 17:43:30.789 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
at org.eclipse.smarthome.ui.classic.internal.servlet.WebAppServlet.service(WebAppServlet.java:169)[179:org.eclipse.smar
thome.ui.classic:0.9.0.b5]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
Switch item=GarageTwoDoor icon=âgaragedoor-closedâ label=âLarge Garage Door Closedâ visibility=[GarageTwoDoorSensor==âCLOSEDâ]$
Switch item=GarageTwoDoor icon=âgaragedoor-openâ label=âLarge Garage Door Openâ visibility=[GarageTwoDoorSensor==âOPENâ] mappi$
Frame label=âSmall Garageâ {
Text item=GarageOneDoorSensor icon="garagedoor"
Text item=GarageOneDistance icon="water"
Text item=GarageOneHumid icon="water"
Text item=GarageOneTemp icon="temperature"
Text item=GarageOneVechileStatus icon=âcarâ
Frame label=âLarge Garageâ {
Text item=GarageTwoDoorSensor icon="garagedoor"
Text item=GarageTwoDistance icon="water"
Text item=GarageTwoHumid icon="water"
Text item=GarageTwoTemp icon="temperature"
Text item=GarageTwoVechileStatus icon=âcarâ
