Sitmap using setpoint of QuantityType item
setpoint
sitemap
quantitytype
Tags: #<Tag:0x00007f51e0309a38> #<Tag:0x00007f51e0309790> #<Tag:0x00007f51e0309588>
(Raphael Löffel) #1
Hi
I changed my temperature items to QuantityType numbers. Within my sitemap I use setpoint to edit the related item. If I try to edit the item by using the Android App, the wheel/setpoint editor will always start at the defined minimal value. I would expect to start at the actual value. Without using QuantityType the behavior is as expected.
Items:
Number:Temperature Roller_Settings_Cooling_Ambient_Limite "Kühlen Aussen Limite [%.1f °C]" <temperature> (gRoller_Settings, gPersistence_Restore)
Sitemap:
Setpoint item=Roller_Settings_Cooling_Ambient_Limite minValue=10.0 maxValue=25.0 step=1.0
Should I use QuantityType only for measurement items and not for setting items like setpoints?
(Danny Baumann) #2
See Setpoint selection dosen't start on current value
(Raphael Löffel) #3
@maniac103
Thanks for the hint.
Today I received the V2.6.9 update of the Android App. I can confirm that issue is now fixed.
