SkyQ Receiver Binding [4.0.0;4.2.0)
SkyQ Binding
This binding provides control and status information functions for SkyQ receivers.
Supported Things
SkyQ receiver.
Discovery
Currently no discovery is implemented
Thing Configuration
Use the UI to add the receiver as a thing and provide the following configuration options
Parameter Required Default Description
Hostname yes N/A The IP address of the SkyQ receiver to control
MAC Address no “” (empty string) The MAC address of the SkyQ receiver to control
Enable Configurable Preset no true Enables the configuration of the channel preset (see below)
Refresh Interval yes 30 The interval for refreshing the item states in seconds
Retry Polling yes 60 The interval for retrying the connection to the recevier after it went offline
Status Check Interval yes 60 The interval for checking if the receiver is reachable (online)
Channels
Channel Type Description
control#controlCommand String Sends a remote control command to the device (see below)
control#channelPreset String Holds list of channels from receiver and allows switch to a selected channel. The list and order of the channels can be configured through a file (see below).
control#channelFavorites String Holds list of favorite channels from receiver and allows switch to a selected channel.
control#power Switch Switches the receiver ON or OFF. The receiver has to be in standby mode for this to work.
statusChannels#currentChannelTitle String Shows current live TV channel title if available
statusChannels#powerStatus String Shows power state ON, OFF, or STANDBY
statusChannels#currentTransportState String State of current transport stream (PLAYING etc)
Control commands
The control#controlCommand channel supports the following commands that are defined as state options:
Value Label Description
power Power
select Select
backup Back/Up
dismiss Dismiss
channelup Channel up
channeldown Channel down
interactive Interactive
sidebar Sidebar
help Help
services Services
search Search
tvguide TV guide
home Home
i i
text Text
up Up
down Down
left Left
right Right
red Red
green Green
yellow Yellow
blue Blue
0 0
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
9 9
play Play
pause Pause
stop Stop
record Record
fastforward Fast forward
rewind Rewind
boxoffice Box office
sky Sky
Defining macros
The controlCommand channel supports sending multiple commands to the device. This allows the definition of macros by the following procedure:
  1. Define a String typed item linked to the controlCommand channel
  2. Add State Description metadata to the item
  3. A macro is defined by each option (line) within the Options section. The option value represents the semicolon separated sequence of commands of the macro, and the label the macro name.
  4. A special command sleep is used to delay the sending of the commands by a fixed but short period. This might be required for certain sequences of commands because sometime some commands are swallowed by the box.
Example
State options that define macros for opening the prime video app of for showing the top series page
interactive;down;down;down;select=prime video
home;sleep;down;down;down;sleep;right;right=Top Series
Note the sleep command here which is required to get reproducable results.
Configurable channel presets
To ease the selection of a large number of TV preset channels, the channels for selection can be filtered and sorted by use of a configuration file.
This feature can be enabled by setting the thing configuration Enable Configurable Presets and saving the new configuration.
If this feature is enabled, the complete channel list as requested from the receiver on each initialization will be stored
as a csv formatted file /userdata/config/skyq/channel_presets.csv.
To filter and sort the channels list, edit the file and set the value of the last column named Rank as follows:
Rank value Effect
< 0 channel is excluded
0 channel is added to end of preset list
> 0 channel is added in the order of the rank value
Channels with same rank value will be ordered by the display number.
A refresh of the preset channels after a change of the csv file can be triggered by issuing the command --REFRESH-- which is added as first
pseudo channel to the list.
Full Example
skyq.things:
Thing skyq:skyqreceiver:skyq1 [ hostname="192.168.1.2", configurablePresets=true, retryInterval=60, checkStatusInterval=60, refreshInterval=30 ]
skyq.items:
String sky_command "[%s]" {channel="skyq:skyqreceiver:skyq1:control#controlCommand"}
Main UI Examples
Control command cell
When clicked, a control command is send to the receiver on selection from a drop down list
YAML definition of cell
component: oh-label-cell
  action: options
  actionItem: SkyQReceiver_ControlReceiverCommand
  expandable: false
  item: SkyQReceiver_ControlReceiverCommand
  stateAsHeader: true
  title: Control Receiver Comman
Preset cell
When clicked, a custom widget is opened with a list of the possibly filtered and ordered list of channels.
This list can be further filtered. On selection of a channel item, the receiver will switch to this channel.
  action: popup
  actionModal: widget:widget_tv_preset
  actionModalConfig:
    item: SkyQReceiver_ChannelPreset
    prop1: Select channel
  expandable: false
  title: TV Channel
YAML definition of custom widget
uid: widget_tv_preset
tags: []
props:
  parameters:
    - description: A text prop
      label: Prop 1
      required: false
      type: TEXT
    - context: item
      description: An item to control
      label: Item
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Nov 19, 2021, 5:34:29 PM
component: f7-card
  title: =props.prop1
slots:
  default:
    - component: f7-list
        virtualList: true
      slots:
        before-list:
          - component: oh-input-item
              icon: f7:search
              iconColor: gray
              outline: true
              placeholder: Suche
              type: text
              variable: channelFilter
        default:
          - component: oh-repeater
              filter: loop.option.label.toLowerCase().includes(vars.channelFilter.toLowerCase()) == true
              for: option
              fragment: true
              itemOptions: =props.item
              sourceType: itemStateOptions
            slots:
              default:
                - component: oh-list-item
                    action: command
                    actionCommand: =loop.option.value
                    actionItem: =props.item
                    popupClose: true
                    title: =loop.option.label
Changelog
Version 4.0.0
  • Adoptions for OH 4.0
  • Fix issue with refreshing Sky TV channels
Version 3.4.0
  • Improved power on/off handling
  • Fixed issues with non-refreshing states
  • Added macro feature for control commands
Version 3.2.0-1
  • Fixes issues with up command not working
Version 3.2.0
  • Initial stable release
Resources
https://github.com/andan67/openhab-addons/releases/download/openhab-addons-skyq-4.0.0/org.openhab.binding.skyq-4.0.0.kar
I get everytime the info into the log that channels and services will be refreshed. Can i stop this kind of information, because flooding of log?
This issue should be fixed in this (4.0) version. However, this fix hasn’t been backported yet into the 3.x version (its on my todo list).
2023-08-11 20:40:17.929 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (308)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(402)] : Error during instantiation of the implementation object
java.lang.IllegalArgumentException: argument type mismatch
	at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
	at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77) ~[?:?]
	at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
	at java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:499) ~[?:?]
	at java.lang.reflect.Constructor.newInstance(Constructor.java:480) ~[?:?]
	at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:326) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1002) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:975) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:920) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:220) ~[org.eclipse.osgi-3.18.0.jar:?]
	at java.security.AccessController.doPrivileged(AccessController.java:318) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:217) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:118) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:534) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:660) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2612) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2078) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2061) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:336) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:304) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1232) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1152) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:959) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:895) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1184) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:116) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:123) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:961) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:937) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:874) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:262) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:500) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) ~[?:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:671) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:310) ~[?:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:593) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:74) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:460) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) ~[osgi.core-8.0.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:949) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.start(Module.java:486) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
2023-08-11 20:40:18.050 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:4.0.1 (163)[org.openhab.core.config.discovery.internal.PersistentInbox(131)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402}
2023-08-11 20:40:18.057 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:4.0.1 (163)[org.openhab.core.config.discovery.internal.PersistentInbox(131)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402} for reference ThingHandlerFactory
2023-08-11 20:40:18.064 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (308)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(402)] : Error during instantiation of the implementation object
2023-08-11 20:40:18.141 [WARN ] [.thing.internal.GenericThingProvider] - bundle org.openhab.core.model.thing:4.0.1 (206)[org.openhab.core.model.thing.internal.GenericThingProvider(234)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402}
2023-08-11 20:40:18.145 [WARN ] [.thing.internal.GenericThingProvider] - bundle org.openhab.core.model.thing:4.0.1 (206)[org.openhab.core.model.thing.internal.GenericThingProvider(234)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402} for reference ThingHandlerFactory
2023-08-11 20:40:18.150 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (308)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(402)] : Error during instantiation of the implementation object
2023-08-11 20:40:18.217 [WARN ] [core.thing.internal.ThingManagerImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingManagerImpl(262)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402}
2023-08-11 20:40:18.223 [WARN ] [core.thing.internal.ThingManagerImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingManagerImpl(262)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402} for reference ThingHandlerFactory
2023-08-11 20:40:18.226 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (308)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(402)] : Error during instantiation of the implementation object
2023-08-11 20:40:18.299 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingRegistryImpl(263)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402}
2023-08-11 20:40:18.302 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingRegistryImpl(263)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402} for reference ThingHandlerFactory
2023-08-11 20:40:20.637 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2023-08-11 20:41:09.576 [INFO ] [ar.internal.handler.ThingBaseHandler] - VSSZZZKLZNR023885: Reverse address lookup based on vehicle's geo position is enabled (using OpenStreetMap)
2023-08-11 20:41:10.989 [INFO ] [ar.internal.handler.ThingBaseHandler] - Ibiza: Reverse address lookup based on vehicle's geo position is enabled (using OpenStreetMap)
2023-08-11 20:41:55.447 [INFO ] [ion.script.ui.SchlafzimmerSwenButton] - valueFS
2023-08-11 20:41:56.252 [INFO ] [ion.script.ui.SchlafzimmerSwenButton] - ----
2023-08-11 20:41:56.489 [INFO ] [ion.script.ui.SchlafzimmerSwenButton] - TimerEnd
2023-08-11 20:41:56.497 [INFO ] [ion.script.ui.SchlafzimmerSwenButton] - 1
2023-08-11 20:42:48.308 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'miio:generic:16D5DC17' are missing in the respective registry for more than 120s. In case it does not happen immediately after an upgrade, it should be fixed in the binding.
2023-08-11 20:43:01.167 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (308)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(402)] : Error during instantiation of the implementation object
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:2204) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:466) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:398) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:304) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1258) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1152) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:1012) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1192) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:241) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:952) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:915) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:140) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:994) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:844) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:825) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:589) ~[?:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:722) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:492) ~[?:?]
	at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:652) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$300(Activator.java:74) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:490) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132) ~[?:?]
	at org.apache.felix.scr.impl.Activator.bundleChanged(Activator.java:255) ~[?:?]
	at org.eclipse.osgi.container.Module.doStop(Module.java:658) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.stop(Module.java:521) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:472) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.stopBundle(BundleInstallSupportImpl.java:171) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.stopBundle(FeaturesServiceImpl.java:1165) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:783) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
	at java.lang.Thread.run(Thread.java:833) ~[?:?]
2023-08-11 20:43:01.220 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:4.0.1 (163)[org.openhab.core.config.discovery.internal.PersistentInbox(131)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402}
2023-08-11 20:43:01.223 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:4.0.1 (163)[org.openhab.core.config.discovery.internal.PersistentInbox(131)] : DependencyManager : invokeUnbindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402} for reference ThingHandlerFactory
2023-08-11 20:43:01.230 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (308)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(402)] : Error during instantiation of the implementation object
2023-08-11 20:43:01.286 [WARN ] [.thing.internal.GenericThingProvider] - bundle org.openhab.core.model.thing:4.0.1 (206)[org.openhab.core.model.thing.internal.GenericThingProvider(234)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402}
2023-08-11 20:43:01.288 [WARN ] [.thing.internal.GenericThingProvider] - bundle org.openhab.core.model.thing:4.0.1 (206)[org.openhab.core.model.thing.internal.GenericThingProvider(234)] : DependencyManager : invokeUnbindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402} for reference ThingHandlerFactory
2023-08-11 20:43:01.295 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (308)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(402)] : Error during instantiation of the implementation object
2023-08-11 20:43:01.357 [WARN ] [core.thing.internal.ThingManagerImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingManagerImpl(262)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402}
2023-08-11 20:43:01.360 [WARN ] [core.thing.internal.ThingManagerImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingManagerImpl(262)] : DependencyManager : invokeUnbindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402} for reference ThingHandlerFactory
2023-08-11 20:43:01.366 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (308)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(402)] : Error during instantiation of the implementation object
2023-08-11 20:43:01.424 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingRegistryImpl(263)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402}
2023-08-11 20:43:01.437 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingRegistryImpl(263)] : DependencyManager : invokeUnbindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=799, service.bundleid=308, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=402} for reference ThingHandlerFactory
I get this at start of openhab. Is that fixed?
Edit: Its longer as aspected. I’ve removed the binding, cause I’m invastigating an OOM.
If I remember correctly I’ve seen that issue when OH 4 had been started with Java 11. I’d suggest to check your Java runtime version (should be 17).
Without 17 you can’t install openhab. So I upgraded the system to 17.
The issue might also be caused by an incomplete removal of the old marketplace binding version.
See openHAB 4.0 Milestone discussion - Setup, Configuration and Use / News & Important Changes - openHAB Community for similar error messages concerning marketplace bindings and hints for resolving the problem.
There something wired…
2023-08-13 09:39:36.224 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (314)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(415)] : Error during instantiation of the implementation object
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:445) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:464) ~[org.eclipse.osgi-3.18.0.jar:?]
	at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:165) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1160) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1041) ~[?:?]
2023-08-13 09:39:36.290 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:4.0.1 (163)[org.openhab.core.config.discovery.internal.PersistentInbox(131)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=826, service.bundleid=314, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=415}
2023-08-13 09:39:36.293 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:4.0.1 (163)[org.openhab.core.config.discovery.internal.PersistentInbox(131)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=826, service.bundleid=314, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=415} for reference ThingHandlerFactory
2023-08-13 09:39:36.299 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (314)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(415)] : Error during instantiation of the implementation object
2023-08-13 09:39:36.376 [WARN ] [.thing.internal.GenericThingProvider] - bundle org.openhab.core.model.thing:4.0.1 (206)[org.openhab.core.model.thing.internal.GenericThingProvider(234)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=826, service.bundleid=314, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=415}
2023-08-13 09:39:36.378 [WARN ] [.thing.internal.GenericThingProvider] - bundle org.openhab.core.model.thing:4.0.1 (206)[org.openhab.core.model.thing.internal.GenericThingProvider(234)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=826, service.bundleid=314, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=415} for reference ThingHandlerFactory
2023-08-13 09:39:36.381 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (314)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(415)] : Error during instantiation of the implementation object
2023-08-13 09:39:36.446 [WARN ] [core.thing.internal.ThingManagerImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingManagerImpl(262)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=826, service.bundleid=314, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=415}
2023-08-13 09:39:36.464 [WARN ] [core.thing.internal.ThingManagerImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingManagerImpl(262)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=826, service.bundleid=314, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=415} for reference ThingHandlerFactory
2023-08-13 09:39:36.466 [ERROR] [ing.skyq.internal.SkyQHandlerFactory] - bundle org.openhab.binding.skyq:4.0.0.202307291633 (314)[org.openhab.binding.skyq.internal.SkyQHandlerFactory(415)] : Error during instantiation of the implementation object
2023-08-13 09:39:36.571 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingRegistryImpl(263)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=826, service.bundleid=314, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=415}
2023-08-13 09:39:36.573 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:4.0.1 (212)[org.openhab.core.thing.internal.ThingRegistryImpl(263)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory}={service.id=826, service.bundleid=314, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.skyq.internal.SkyQHandlerFactory, component.id=415} for reference ThingHandlerFactory
I’ve removed the binding and it isn’t. Then i install again this binding and i get this error.
