My OH 3.2 runtime on Raspberry Pi 4 uses Java 11.0.9.1 (Zulu11.43), and on my Windows dev machine Oracle Java Runtime 11.0.2 (18.9). Have you just recently upgraded to OH 3, because OH3 requires Java runtime 11 and 'I doubt it could run with any lower version.
Thanks for that @andan. I’m lucky to have a server running VMWare and just decided to create a fresh install. Tried the binding and it’s working as expected, so clearly it’s something not quite right with my existing server. Time for a migration it seems.
Thanks for responding and keep up the good work. I look forward to seeing where you go with this.
I have an interesting issue… Command Up doesn’t work. Left right down work but up doesn’t work. Are you know why? Using 3.2.0 installed binding via market and setup via gui.
ChannelState and TransporState are UNDEF.
I can confirm that the up issue is a bug. I will provide a fix shortly.
Are you experiencing other issues or strange behaviour? I’m asking because you mentioned the Channel and Transport states. These are initially set to UNDEF until the physical state is retreived from the device.
Not yet, but that is on my to do list (assuming this is possible at all).
Unfortunately, there is no official documentation regarding the control of the SkyQ receiver over IP, and I’m completley relying on the work of others. This means I can’t make any promises regarding the supported featues of the binding going forward.
Great, UP Command works now.
TransportState and ChannelTitle stay UNDEF. I’ve tried with pause at live tv and play but TransportState stay on UNDEF. I don’t get any ChannelTitle. Stay also on UNDEF. Using this with freeTV channels and payTV. Are you know which TV channel work with it?
I’m also in Germany and I use the binding since several months, nothing changed, it is still working. I just never could get the statusChannels#currentChannelTitle and statusChannels#currentTransportState to work. I tried reinstalling several times but finally gave up.
The issue with the current title and transport state channels will be fixed in the next release of the binding, which I plan to make available within the next 1-2 weeks.
This release will also include some minor enhancements (e.g. defining macros for control commands, improved power on/off handling, show current programm information).
