I’m using the OH3 editor to create my sitemap which is working just fine for me.
I have chosen to use Sliders for my roller shutters as they accept a direct position.
I have seen the “Switch enabled” slider and because it was not obvious what it would be doing, I went to look at the documentation:
switchEnabled is not described but switchSupport is which seems equivalent and is described like this:
Classic UI: If specified, a short press on the “up” or “down” button switches the item “on” or “off” (0 or 100) respectively.
Android app: If specified, a short press on the item row (except the slider itself) switches the item “on” or “off”.
However, setting switchEnabled to true does not seem to have any effect in the Basic UI or in the Android App.
I mean, in the Android app I tried taping on the item row but it did not seem to have any effect.
And in BasicUI, there is not even an up or down button.
I am only aware of an Android implementation for now and classic ui is not equal to basic ui.
Also classic ui is no longer a part of openHAB since version 3.0.
We will remove the classic ui reference therefore.
