Good evening everyone,
it’s been a few weeks that I have been having problems using the sliders in OH3 on raspberry so I wanted to try the demo version, I have already reinstalled the application and tried it on different IOS devices so don’t recommend the usual "switch off and on again ".
Do any of you have the same problem? Do you know what caused it? If you know how to fix?
PS: I also tried to use an android device and in the normal version of the app by moving the sliders nothing happens but you have to use the beta version for the commands to be given.
I leave you a video of the bug in the demo version which is the same as in mine.
See
Thanks for warning me, unfortunately the solution indicated in the post does not seem to actually be the solution for my case and that of others
