Hi all,
I have three Everspring SM103 which are apparently fully recognised (xml files exist and I can see them fine in Habmin) but they don’t seem to ever detect if the door is opened (rather defeating the point of them).
Taking one of them as an example, I have the following item configuration:
Contact GF_Living_LeftWindow "Ground Floor Left Window" (gGroundFloor,gWindowSensors) { hannel="zwave:device:157b8d41438:node27:sensor_binary" } Number GF_Living_LeftWindow_Bat "Ground Floor Left Window Battery: [%d %%]" <energy> (gBatteryLevels,gGroundFloor) { channel="zwave:device:157b8d41438:node27:battery-level" }
In Habmin I see that the Thing woke up 4 hours ago, but the only channel which is matched is battery (and it says zero battery too, which I find hard to believe).
I went into the channel for the binary_contact and noticed it was set to switch, which doesn’t seem right - so I changed it to Contact and manually paired it with the item GF_Living_LeftWindow. This now seems to have worked, but why was it necessary?
Also, I see that the alarm channel is now matched to GF_Living_LeftWindow too… which isn’t correct surely? I’d expect to need to configure a separate tamper item for this.
Node.xml:
<node> <deviceClass> <basicDeviceClass>ROUTING_SLAVE</basicDeviceClass> <genericDeviceClass>BINARY_SENSOR</genericDeviceClass> <specificDeviceClass>ROUTING_SENSOR_BINARY</specificDeviceClass> </deviceClass> <homeId>0x184c830</homeId> <nodeId>27</nodeId> <version>3</version> <manufacturer>0x60</manufacturer> <deviceId>0x1</deviceId> <deviceType>0x2</deviceType> <listening>false</listening> <frequentlyListening>false</frequentlyListening> <routing>true</routing> <security>false</security> <beaming>true</beaming> <maxBaudRate>40000</maxBaudRate> <nodeInformationFrame> <commandClass>SENSOR_BINARY</commandClass> <commandClass>CONFIGURATION</commandClass> <commandClass>WAKE_UP</commandClass> <commandClass>MANUFACTURER_SPECIFIC</commandClass> <commandClass>VERSION</commandClass> <commandClass>ASSOCIATION</commandClass> <commandClass>BATTERY</commandClass> <commandClass>BASIC</commandClass> <commandClass>ALARM</commandClass> </nodeInformationFrame> <supportedCommandClasses> <entry> <commandClass>SENSOR_BINARY</commandClass> <binarySensorCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <isGetSupported>true</isGetSupported> <types/> </binarySensorCommandClass> </entry> <entry> <commandClass>VERSION</commandClass> <versionCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <libraryType>LIB_SLAVE_ROUTING</libraryType> <protocolVersion>2.78</protocolVersion> <applicationVersion>1.1</applicationVersion> </versionCommandClass> </entry> <entry> <commandClass>CONFIGURATION</commandClass> <configurationCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <configParameters> <entry> <int>1</int> <configurationParameter> <index>1</index> <size>1</size> <value>99</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> <entry> <int>2</int> <configurationParameter> <index>2</index> <size>1</size> <value>1</value> <readOnly>false</readOnly> <writeOnly>false</writeOnly> </configurationParameter> </entry> </configParameters> </configurationCommandClass> </entry> <entry> <commandClass>NO_OPERATION</commandClass> <noOperationCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </noOperationCommandClass> </entry> <entry> <commandClass>BATTERY</commandClass> <batteryCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <batteryLevel>0</batteryLevel> <batteryLow>true</batteryLow> <isGetSupported>true</isGetSupported> </batteryCommandClass> </entry> <entry> <commandClass>MANUFACTURER_SPECIFIC</commandClass> <manufacturerSpecificCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <initSerialNumber>false</initSerialNumber> <deviceManufacturer>96</deviceManufacturer> <deviceType>2</deviceType> <deviceId>1</deviceId> </manufacturerSpecificCommandClass> </entry> <entry> <commandClass>ALARM</commandClass> <alarmCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <alarms> <entry> <alarmType>SMOKE</alarmType> <alarmState> <alarmType>SMOKE</alarmType> <reportedEvents/> <outer-class reference="../../../.."/> </alarmState> </entry> </alarms> <v1Supported>false</v1Supported> <isGetSupported>true</isGetSupported> </alarmCommandClass> </entry> <entry> <commandClass>ASSOCIATION</commandClass> <associationCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <maxGroups>2</maxGroups> </associationCommandClass> </entry> <entry> <commandClass>WAKE_UP</commandClass> <WakeUpCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <targetNodeId>1</targetNodeId> <interval>3600</interval> <minInterval>0</minInterval> <maxInterval>2147483647</maxInterval> <defaultInterval>0</defaultInterval> <intervalStep>0</intervalStep> <lastWakeup>2017-01-02 13:16:10.611 UTC</lastWakeup> <isGetSupported>true</isGetSupported> </WakeUpCommandClass> </entry> <entry> <commandClass>BASIC</commandClass> <basicCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <isGetSupported>true</isGetSupported> </basicCommandClass> </entry> </supportedCommandClasses> <securedCommandClasses/> <associationGroups> <entry> <int>1</int> <associationGroup> <index>1</index> <associations> <associationMember> <node>1</node> <endpoint>0</endpoint> </associationMember> </associations> </associationGroup> </entry> <entry> <int>2</int> <associationGroup> <index>2</index> <associations> <associationMember> <node>1</node> <endpoint>0</endpoint> </associationMember> </associations> </associationGroup> </entry> </associationGroups> <nodeNeighbors> <int>22</int> <int>23</int> </nodeNeighbors> <lastSent>2017-01-02 13:41:54.866 UTC</lastSent> <lastReceived>2017-01-02 13:16:10.611 UTC</lastReceived> </node>
