Hello Community,
I think I have to report an error ![]()
I have an SMA inverter with the “SMA Sunny Home Manager 2.0” energy meter.
The Home Manager can be read out with the binding “SMA Energy Meter Binding”.
This has worked more or less well so far.
Since openHAB 4.2.1, however, nothing works anymore.
No more values are read out.
What have I tried so far?
Examined the multicast traffic
=> The traffic arrives and I can intercept it via Wireshark, for example. (At first I suspected a router update as the problem, but this is not the case) -
Created the Thing again
=> Always gets stuck in the Unknown status -
Restarted openHAB
=> Did not help -
Cleared the cache
=> Did not help -
Reinstalled the binding
=> The following error appears in the error log when uninstalling:
2024-08-15 11:08:38.986 [WARN ] [$UnstoppableScheduledExecutorService] - shutdownNow() invoked on a shared thread pool 'OH-binding-smaenergymeter-listener'. This is a bug, please submit a bug report
java.lang.IllegalStateException: null
at org.openhab.core.common.ThreadPoolManager$UnstoppableExecutorService.shutdownNow(ThreadPoolManager.java:242) ~[?:?]
at org.openhab.binding.smaenergymeter.internal.packet.DefaultPacketListenerRegistry.shutdown(DefaultPacketListenerRegistry.java:67) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:568) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:245) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:687) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:531) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.disposeImplementationObject(SingleComponentManager.java:421) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.deleteComponent(SingleComponentManager.java:165) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.ungetService(SingleComponentManager.java:1043) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$2.run(ServiceFactoryUse.java:273) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$2.run(ServiceFactoryUse.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
at java.security.AccessController.doPrivileged(AccessController.java:318) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryUngetService(ServiceFactoryUse.java:270) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.ungetService(ServiceFactoryUse.java:167) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.ungetService(ServiceConsumer.java:53) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.ungetService(ServiceRegistrationImpl.java:632) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.ungetService(ServiceRegistry.java:613) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.ungetService(BundleContextImpl.java:703) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.safeUngetService(SingleRefPair.java:109) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.ungetServiceObjects(SingleRefPair.java:74) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$AbstractCustomizer.ungetService(DependencyManager.java:231) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.close(DependencyManager.java:1426) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.deactivate(DependencyManager.java:1568) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateDependencyManagers(AbstractComponentManager.java:1280) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:854) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:825) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:589) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:722) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:492) ~[?:?]
at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:652) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$300(Activator.java:74) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:490) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132) ~[?:?]
at org.apache.felix.scr.impl.Activator.bundleChanged(Activator.java:255) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:949) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.Module.doStop(Module.java:658) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.container.Module.stop(Module.java:521) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:472) ~[org.eclipse.osgi-3.18.0.jar:?]
at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.stopBundle(BundleInstallSupportImpl.java:171) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.stopBundle(FeaturesServiceImpl.java:1165) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:783) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1069) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:1004) ~[?:?]
My system:
- Raspberry Pi 4B
- Java version
openjdk 17.0.9 2023-10-17 LTS
OpenJDK Runtime Environment Zulu17.46+19-CA (build 17.0.9+8-LTS)
OpenJDK 64-Bit Server VM Zulu17.46+19-CA (build 17.0.9+8-LTS, mixed mode, sharing) - openHAB 4.2.1 (release build)
After reinstalling the binding about 5 times, I was able to manually add the Home Manager again.
It is now shown as online.
The automatic discovery did not work. Not even by pressing the SCAN button.
Apparently there is a problem with V4.2.1 ![]()
