checked the version of my Home Manager 2.0 and it’s the same. I read about, that SMA did a bigger update in the last 2 days. But I think your issue is older.
What I know is, that mostly network issues are the problem, when the thing doesn’t come up. Also, if everything is working in the right way, auto discovery should find your HomeManager directly, after installing the binding.
Communication is running over Multicast. If you are using vLans, or Multicast is blocked, you will not get this working.
I don’t like Auto Updates because of unforeseeable issues, thus it’s deactivated. After reading change log , I enabled Update for Home Manager to get latest version, so let’s see if this change something.
