Ahh, that makes sense.
Exactly!
Exactly!
Hi Kim,
Thanks. The ip adress of the devices i put correctlyā¦ Sure.
I have running the knx binding working well and seem similar.
Maybe i have to restartā¦ I will checkā¦ Because i cannot find the things in paper ui.
Maybe when i add them via paper ui, but then i donāt need the things fileā¦
Will checkā¦
Saludos,
Oliver
A thing which isnt available via PaperUI could indicate you need to restart openhab/binding. I have seen it many times.
Keep an eye on the logfile (tail log) each time you make changes. YouĀ“ll be promted as soon as there seem to be a problem.
Hi again,
i added the things via paper uiā¦ now they are onlineā¦ but the items still are empty.
You also have a āSMA.mapā I think where battery charge status is defined and shown in some wayā¦can you upload ist also please?
Oliver
tjek your poller and make sure the register is correct.
Ahh ofcouseā¦
// Device Type
9098=STP 5000TL-20
9099=STP 6000TL-20
9100=STP 7000TL-20
9102=STP 9000TL-20
9103=STP 8000TL-20
9281=STP 10000TL-20
9282=STP 11000TL-20
9283=STP 12000TL-20
9326=Sunny Boy Storage 2.5
// Condition
35=Fault
303=OFf
307=Ok
308=On
455=Warning
// Recommended action:
336=Contact manufacturer
337=Contact installer
338=invalid
887=none
// Grid relay/contactor:
51=Closed
311=Open
16777213=Information not available
// Operating status:
295=MPP
381=Stop
443=Constant voltage
1392=Fault
1393=Waiting for PV voltage
1467=Start
1469=Shut down
1480=Waiting for utilities company
2119=Derating
ON=On
// Battery oper. status:
2291=Battery standby
2292=Charge battery
2293=Discharge battery
Status battery application area:
2614=Own consumption area
2615=State of charge conservation area
2616=Backup power area
2617=Deep discharge protection area
2618=Deep discharge area
Just save the above in a file called SMA.map
You also most probably need divide1000.js and smalimit.js.
divide1000.js
// Wrap everything in a function
(function(i) {
return parseFloat(i) / 1000;
})(input)
// input variable contains data passed by openhab
smalimit.js
(function(i) {
if(i < 0) return "UNDEF";
})(input)
All three files goes into the transform folder.
Cool thanksā¦ Try it later when at home
Saludos,
Oliver
Hi Kim,
still something wrongā¦
ā2019-11-15 22:17:05.479 [WARN ] [rm.AbstractFileTransformationService] - Could not transform ā-ā with the file āSMA.mapā : Target value not found in map for ā-āā
i get no valuesā¦ have no ideaā¦
the things are now online - i added the two inverter manually via paper uiā¦ - but i have no idea whats still getting wrongā¦
SMA.map and other files i have nowā¦can you sent me maybe a zip with your whole config via personal message? i will post the solution completly later when i have success.
kind regards,
Oliver
Have you looked in openhab.log
You should see either errors or your modbus pollers being initialized. Show us, please.
Hi Kim,
so i got it working!
Now I only have to check which values would be the most necessary or maybe are missing some valuesā¦ will check the excel file.
Only thing which could be nicer are the missing icons. How you implemented the āgroupsā that the icons are showing up?
Do you have the icons?
Kind regards,
Oliver
Hi Oliverā¦ Great you got it working.
As for the icons, I use sitemap/icons for testing purpose only, as IĀ“m working on a totally other GUI using Habpanel and SVG files. This GUI is still far from finished, and still lack my PV system.
In my sitemap I use a mix of the default icons, and some icons IĀ“ve found on flaticonsā¦
This is how my sitemap page lookā¦ You would probably prefere to do your own choise of icons.
Looks good!
Habpanel is my next projectā¦
I bought a huawei t5 and want to fix in on the wallā¦ maybe with possibility to get it off easilyā¦ so maybe wireless chargingā¦ but read lot of articels its not worth and working well.
So the solarpanel icon looks niceā¦ maybe you can put in here also and I downloads itā¦
But how you get it working that if you specify the icon is shown automatically ?
Vie map also??
Saludos,
Oliver
As said, the icons is a mix of the default icons in openhab
And some I have found on flaticons https://www.flaticon.com/search?search-type=icons&word=solar+panel&license=&color=&stroke=¤t_section=&author_id=&pack_id=&family_id=&style_id=&category_id=
Thats just default for items. Put the icon name inside the in the items line. Then they will show on sitemaps.
