SMA ennexOS
Hi guys,
is there anyone out there which is already developing an SMA API based Addon?
I know that there is the possibility to get all the neccesary informations out from the SMA Energy Meter Binding and also from the modbus communication to each inverter. I’m comming now in trouble that my SMA EV Charger 22 has no Modbus implemented because it is the “private” Version.
I have had a look into the documentaion and I beleive it will be a good idea to use the API of the “new” ennexOS portal.
The API is well documented and the only negative thing i found is that the rate limit is set up to 5 Minutes.
I’m not a Java guy so that project would be much too big for me and i will start the discussion if this would make sense and maybe we will find a guy who has the expierience to implement all the neccesary thing in an official Binding :slight_smile:
