Hi Simon,
see a small syntax issue within the label for charging and not charging. Is this something i can influence? Do not remember that i had this earlier with the initial binding. Language setting here is German.
Thanks for your support in advance.
BR Willi
{"link":"https://myopenhab.org/rest/items/kon2bksiPhone12_Ladezustand","state":"NotCharging","stateDescription":{"pattern":"%s","readOnly":true,"options":[{"value":"NotCharging","label":"Lädt nicht"},{"value":"Charged","label":"Aufgeladen"},{"value":"Charging","label":"Lädt"},{"value":"Unknown","label":"Unbekannt"}]},"commandDescription":{"commandOptions":[{"command":"NotCharging","label":"Lädt nicht"},{"command":"Charged","label":"Aufgeladen"},{"command":"Charging","label":"Lädt"},
Also see this syntax issue within the thing settings, see thing type?
