creates a Thing for the Tuya Cloud Project that gets the status ONLINE, but the tuyaDevice Thing shows CONFIGURATION_ERROR “No channels added and schema not found.”.
Adding the discovered Thing in the UI does work (after adding the IP address and protocol version. It shows the same YAML-configuration in the Code-tab as the config-file Thing, except for the added Channels. One difference I noticed is that the working tuyaDevice Thing has two additional discovered Thing Properties: mac and category (not in the YAML-config).
No idea. I always recommend to use discovery and managed configuration. File-based configuration is the source of 90% of the trouble we have with binding configuration.
Thing tuya:project:infraheater "Tuya Cloud Project" @ "Office" [accessId="{{tuya_id}}",schema="smartLife",password="{{tuya_password}}",dataCenter="https://openapi.tuyaeu.com",countryCode="31",accessSecret="{{tuya_secret}}",username="{{tuya_user}}"]
Thing tuya:tuyaDevice:infraheaterheater "Infrared Heater" @ "Office" [protocol="3.3", productId="{{heater_product_id}}", deviceId="{{heater_device_id}}", ip="{{heater_ip}}", localKey="{{heater_local_key}}"] {
Channels:
Type switch : switch "Paneel Aan/Uit" [dp=1]
Type number : temp_set "Doeltemperatuur" [dp=2]
Type number : temp_current "Huidige temperatuur" [dp=3]
The Thing Channels just needed dp= parameter and the temperature channels can also take two other parameters (min= and max=) which seem to represent a temperature range.
I see this in logs [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Request failed: Result{timestamp=1705332850312, code=1106, msg=permission deny, success=false, result=null}, no token received
I checked Secret and ID 5 times and they are correct. I got no errors with curl.
Hi all!
Stupid question, but how do you start the discovery service? In OpenHab UI I go to Settings > Things press on +, select Tuya Smarthome/J binding, see this:
And press scan. Correct?
In my case, it doesn’t find anything. The project binding is ok.
(I’m using OH4.1.1 with the new fixed json from @J-N-K today )
Thanks for any answer!
I don’t understand why my dimmer switch (Gosund) don’t work.
I can switch it ON/OFF from Openhab and the physical button.
I can use the physical dimmer and it modified the bright_value in Openhab.
But when I modify the bright_value in Openhab, nothing happen.
I have 2 of them, and it’s exactly the same behavior for both.
Each Things have been added by the Binding, using the scan button.
Here’s the configuration of the channel :
I have nothing in the logs except the value changed in the events.log :
2024-02-28 08:08:47.530 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Bar_Light_bright_value' received command 59
2024-02-28 08:08:47.531 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Bar_Light_bright_value' predicted to become 59
2024-02-28 08:08:47.532 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bar_Light_bright_value' changed from 36 to 59
I suspected a missconfiguration between the item, the min/max value, the fact that it’s a dimmer, etc…
But I tried a lot of configuration and find nothing…
Can someone help me ?
Here’s the TRACE log I have from Openhab;
Everything seems to work, I can do an update from the Smart Life app, fom Tuya Platform, from Postman…
But the “bright_value” command from Openhab just didn’t work.
This looks like a DEBUG entry. Before you should see a TRACE entry with something like decoded raw payload. Can you share that one? [B@2737708e indicates the payload is a byte array, which is odd.
I am trying to use the binding with a Tuya RainPoint irrigation Hub (that have and integrated Switch) with irrigation controllers, but it is impossible to control. The binding detects all, it seems “online” (except Gateway), no errors on Debug log, but doesn’t receive any data or change state of switch or irrigaiton.
I have tried also with TinyTuya with Python, but same “bad” result.
I have searching information, and it seems that any of both not support devices “not directly connected” to the WiFi. In this case, the devices are connected to Gateway that is the device connected to WiFi. Anybody knows more about that? This issue can be resolved (or any workaround)?
I recently tried setting up a Tuya Zigbee hub to see if that could be an alternative solution, but since the Zigbee child devices didn’t have their own IP addresses they remained offline. This sounds like it might be a similar issue.
These threads on Home Assistant and LocalTuya might provide some hints, but it sounds like lots of people have struggled with this.
Thanks @rpwong , exactly that seems the same issue.
Just yesterday test the only working solution that I found, that is binding Tuya App with Alexa, and so actuate to the irrigation through Alexa. But, is very very bad solution: I only see the irrigation as a switch, but can’t see anymore, not integrated switch on Gateway, not any of the available parameters on irrigation controller as flow, timers, battery, etc…
