I have the binding all set up and working correctly with a number of Smartlife / Tuya devices, the main ones I use are the D06 WiFi contact Door Window sensors, however I now have an issue.
The previous devices I purchased were labeled as a D06 and found correctly by the binding to the inbox - these devices all show the productid as ebfzb5zjnealolkb however the ‘new’ D06s I have purchased are all being identified as p6sqiuesvhmhvv4f
They are still found by the inbox, but when added state “CONFIGURATION ERROR No Channels added and schema not found.”
Interesting that the ‘old’ D06 show in the smart life app as ‘Open’ or ‘Closed’, the ‘new’ show as ‘On’ and ‘Off’, so there is definitely a difference, however the boxes for the devices are identical and looking at the devices they appear to be too!!
Does anyone know what do I need to do in order to get the new devices working in OpenHAB?
Many Thanks
