I’ve searched through as many forums and tutorials I could find but I am stumped. I’m still learning OpenHab so I’m probably overlooking something. The situation is, I have a SmartSense Multi Sensor that was connected through Smart Things. One day it lost connection with the app so I decided to use this opportunity to migrate it to OpenHab (which I’m still tinkering with). After resetting the pairing, I can eventually get PaperUI to recognize it. But under Control, it doesn’t show any metrics. I’ve added items manually through SSH but it doesn’t change those metrics. Going through DEBUG, I get a bunch of timeouts and an error that the address cannot be found.
2018-07-05 18:26:45.628 [DEBUG] [internal.ZigBeeNodeServiceDiscoverer] - 000D6F000E35A237: Node SVC Discovery running
2018-07-05 18:26:45.632 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX CMD: ManagementLqiRequest [0/0 -> 47892/0, cluster=0031, TID=E9, startIndex=0]
2018-07-05 18:26:45.636 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - TX APS: ZigBeeApsFrame [sourceAddress=0/0, destinationAddress=47892/0, profile=0000, cluster=49, addressMode=DEVICE, radius=31, sequence=233, payload=00 00]
2018-07-05 18:26:45.639 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee send: XBeeTransmitRequestExplicitCommand [frameId=null, ieeeAddress=000D6F000E35A237, networkAddress=47892, sourceEndpoint=0, destinationEndpoint=0, cluster=49, profileId=0, broadcastRadius=0, options=[ENABLE_APS_ENCRYPTION], data=00 00]
2018-07-05 18:26:45.643 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeTransmitRequestExplicitCommand [frameId=253, ieeeAddress=000D6F000E35A237, networkAddress=47892, sourceEndpoint=0, destinationEndpoint=0, cluster=49, profileId=0, broadcastRadius=0, options=[ENABLE_APS_ENCRYPTION], data=00 00]
2018-07-05 18:26:45.646 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeTransmitRequestExplicitCommand [frameId=253, ieeeAddress=000D6F000E35A237, networkAddress=47892, sourceEndpoint=0, destinationEndpoint=0, cluster=49, profileId=0, broadcastRadius=0, options=[ENABLE_APS_ENCRYPTION], data=00 00]
2018-07-05 18:26:45.652 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 16 11 FD 00 0D 6F 00 0E 35 A2 37 BB 14 00 00 00 31 00 00 00 20 00 00 39
2018-07-05 18:26:50.504 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 8B FD FF FD 00 24 02 55
2018-07-05 18:26:50.507 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeTransmitStatusResponse [frameId=253, networkAddress=65533, transmitRetryCount=0, deliveryStatus=ADDRESS_NOT_FOUND, discoveryStatus=ROUTE_DISCOVERY]
2018-07-05 18:26:55.643 [DEBUG] [internal.ZigBeeNodeServiceDiscoverer] - 000D6F000E35A237: Node SVC Discovery ManagementLqiRequest response CommandResult [TIMEOUT]
2018-07-05 18:26:55.647 [DEBUG] [internal.ZigBeeNodeServiceDiscoverer] - 000D6F000E35A237: Node SVC Discovery request NEIGHBORS failed. Retry 72, wait 197542ms before retry.
The same thing seems to be happening with a SmartSense Motion Sensor as well. I’m concentrating on this one hoping the solution is a two bird one stone kind of thing.
